engine block heater trips gfi - Electrician Talk - Professional Electrical Contractors Forum
Old 12-20-2013, 01:11 PM   #1
Default engine block heater trips gfi
A customer of mine at his shop is tripping gfis with his diesel engine block heater. Plugged into a non gfi outlet it works fine. The heater is for a 2000 f-450. Anyone experience this before?
finster is offline   Reply With Quote
Old 12-20-2013, 01:26 PM   #2
Rewards Points: 162
Heater coil may have a little leakage causing gfi to trip
BlackHowling is offline   Reply With Quote
The Following User Says Thank You to BlackHowling For This Useful Post:
BBQ (12-20-2013)
Old 12-20-2013, 01:29 PM   #3
Its brand new though. And its been a pattern with his other trucks.
Old 12-20-2013, 01:37 PM   #4
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 250
If you've got a good GFCI tester, confirm the proper trip point of the GFCI:
Or else, just move to a different GFCI and see if the problem follows it. It if it does, the block heater has a >4mA ground fault.
Big John is online now   Reply With Quote
The Following 3 Users Say Thank You to Big John For This Useful Post:
BBQ (12-20-2013), bruce6670 (12-20-2013), Semi-Ret Electrician (12-22-2013)
Old 12-20-2013, 01:38 PM   #5
Rewards Points: 1,458
check resistance with meter between hot and ground on heater, you should get infinite, even if it is brand new it can be defective
Old 12-20-2013, 02:02 PM   #6
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 2,510
We had them here years ago. When the block heaters went bad it hurt like a mother some mornings until we installed GFCI's.
You can guess what was wrong.
Old 12-20-2013, 02:48 PM   #7
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,114
You didnt have shoes on.
I HAVE THE RIGHT TO OFFEND ANYONE I PLEASE. YOU HAVE THE RIGHT TO BE OFFENDED, YOU DO NOT HAVE THE RIGHT TO SHUT ME UP.
Old 12-20-2013, 03:06 PM   #8
Wirenuting's Avatar
We parked the trucked nose to tail and touching 2 was shocking at times. The guy in the garage who made the cords for the plugs was nice enough to solidly ground the trucks frame. The bad part was the conduit that ran down the walls and loading dock was rotted and falling apart in spots. There was no ground wire run back to the panel.
Old 12-20-2013, 03:09 PM   #9
Ambassador of Amps
TOOL_5150's Avatar
thats really not a good situation right there.
The Following User Says Thank You to TOOL_5150 For This Useful Post:
Wirenuting (12-20-2013)
Old 12-20-2013, 03:21 PM   #10
motherplucker
chicken steve's Avatar
Rewards Points: 2,052
95% of my 'gfci tripping' calls are simply due to them doing their job
in fact, i really think there should be a 'thank your gfci day' for all the incessant complainers out there to realize they may not have been around to beeeaatch w/o them
chicken steve is online now   Reply With Quote
The Following 5 Users Say Thank You to chicken steve For This Useful Post:
Big John (12-20-2013), dthurmond (12-20-2013), Semi-Ret Electrician (12-22-2013), wildleg (12-21-2013), Wirenuting (12-20-2013)
Old 12-20-2013, 03:24 PM   #11
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 250
Originally Posted by chicken steve View Post
95% of my 'gfci tripping' calls are simply due to them doing their job.
True of virtually every protection scheme I can think of: GFCIs, fuses, motor overloads, breakers, protective relays, you name it. Rule #1: It's most likely not a problem with the protective device.
The Following 5 Users Say Thank You to Big John For This Useful Post:
chicken steve (12-20-2013), jrclen (12-22-2013), Semi-Ret Electrician (12-22-2013), wendon (12-20-2013), Wirenuting (12-20-2013)
Old 12-20-2013, 04:04 PM   #12
BBQ
Salty Member
BBQ's Avatar
But what is depressing is that often the same people who would never even consider doing away with any of those items have no problem with getting rid of the GFCI.
Old 12-20-2013, 04:24 PM   #13
Ambassador of Amps
TOOL_5150's Avatar
Thats not depressing, thats natural selection.
Old 12-20-2013, 04:33 PM   #14
Deep Cover's Avatar
Rewards Points: 2,024
I installed an outside GFI for a block heater a couple years back. Months after, our office person called me and asked why I put a GFI in for the block heater. I said, well, because it's required to be a GFI. She told me that I had to go back and change it out to a regular receptacle because most block heaters will trip a GFI. She also told me that an inspector told them it was OK.
I told her to have someone else do it. She did. Not for this reason in particular, but I do not work there anymore.
Deep Cover is offline   Reply With Quote
Old 12-20-2013, 06:35 PM   #15
Cl906um's Avatar
Rewards Points: 800
i know its off subject a bit, but in my house my garage door openers, my basement freezer, and sump pump are not on gfi's. to me, i want all these systems to work. i have heard that newer motors aren't supposed to nuisance trip. why chance it. whether it being a buttload of spoiled meat, or having to get out of my car when its snowing to beat hell, to come home to a flooded basement. i liked the old ways. have a single outlet for each. maybe i will do assured grounding quarterly on all these...
Old 12-20-2013, 08:11 PM   #16
wendon's Avatar
Rewards Points: 50
Does your state have an exception for that?
wendon is online now   Reply With Quote
Old 12-21-2013, 02:28 AM   #17
Dan Wheeler's Avatar
Rewards Points: 77
I just had a call about a month ago or so saying their outside receptacle was not working.
Went there and found the hot wire was corroded.
Told them I had to put in a gfci and did.
Got call next day, saying their block heater was tripping it, they said anything they plug in would not work.
Went back thinking maybe faulty gfci, pressed reset and plugged stuff in, all worked fine, even ran my heat gun.
Told caretaker what was happening and they said to leave it, renter probably had their cord sitting in water, or block heater, was old diesel truck.
Dan Wheeler is offline   Reply With Quote
The Following User Says Thank You to Dan Wheeler For This Useful Post:
BBQ (12-21-2013)
Old 12-21-2013, 03:31 AM   #18
five.five-six's Avatar
Rewards Points: 5,026
When I was in the aquarium hobby I had some very long winded inter-webs arguments with people that hated GFIC, every now and then one of them would stop posting here or there. No obituary or nothing, they just stopped posting.
five.five-six is online now   Reply With Quote
Old 12-21-2013, 06:07 AM   #19
BBQ
Salty Member
BBQ's Avatar
Yeah, for sure.
It would be much better for you or a family member to get a shock or even killed vs replacing some spoiled meat or the hell of stepping out of the car in the snow.
I am sure you have the sump pump on battery back up and auto generator as well in case of utility failure.
MTW (12-21-2013)
Old 12-21-2013, 07:52 AM   #20
BBQ
Salty Member
BBQ's Avatar
As long as it happens to the person who takes out the GFCI I agree with you.
Replace Engine VS ...Not Deep Cover Off Topic (Non Trade) 43 11-25-2013 09:20 AM
Kohler engine RIVETER Off Topic (Non Trade) 4 11-09-2013 09:48 AM
New/Better Search Engine A Little Short Off Topic (Non Trade) 15 01-23-2013 05:55 PM
Engine heater receptacles MadDawg Canadian Electrical Code Forum 24 12-01-2012 08:12 PM
SPA Jets Work, Heater Trips Breaker daviddeke Residential Electrical Forum 2 02-12-2011 10:31 PM
