Old 01-29-2009, 07:45 PM   #21
Wish I was in the water
Greg's Avatar
I'll post a question even though I didn't answer one. There hasn't been any posted that I could get to in time.
At what percentage for a service, do you calculate a heat pump with a supplemental electric heat. The supplemental heat is not prevented from coming on at the the same time as the heat pump.
A) 100% heat pump/100% supplemental
B) 100% heat pump/65% supplemental
C) The highest of the two, drop the lowest
D) 100% heat pump/50% supplemental
If you're gonna be stupid, you better be tough.
Old 01-29-2009, 08:11 PM   #22
Originally Posted by BuzzKill View Post
2005 c) 460.8
If the allowable current in a copper bus bar is 1000amps psi of cross section, the width of a standard 1/4inch bus bar designed to carry 1500 amps would be____.
a)2"
b)4"
c)6"
d)8"
C--- 6" 1/4 * 6= 1.5
1.5 *1000= 1500.
What is the minimum size EGC that I need to wire a 60 amp circuit that has the ungrounded conductors upsized to a #2 copper for VD. Assume a #6 would have been needed before the VD.
Old 01-29-2009, 08:17 PM   #23
If we are talking dwelling units then Art. 220.82 (C) (3) . Ans. B
Old 01-29-2009, 08:28 PM   #24
Greg's Avatar
250.122 (B)
#6 awg
Therefore #8 increased by 40% = a #6awg
Old 01-29-2009, 08:31 PM   #25
Greg's Avatar
correct
Old 01-29-2009, 09:29 PM   #26
Motor Repair&Control Shop
electro916's Avatar
2005 NEC
When can a feeder from service equipment to a remote panelboard be permitted to run in flexible metal conduit?
electro916 is offline   Reply With Quote
Old 01-29-2009, 10:00 PM   #27
250.122 (B)
#6 awg
Not sure how you got your answer . Where did the #8 come from? Where did the 40 % come from?
#6 = 26240 cir mil
#2 = 66360 cir mil
66360/26240 means that #2 is 2.53 times larger than a #6 not 40%-- am I doing something wrong?
A #10 is needed for an egc with a 60 amp breaker without upsizing the conductor. So a
#10 = 10380 cir mil
Multiply this by 2.52 and we get 26261 cir mil.
Table 8 says we need a #4
Old 02-05-2009, 01:29 AM   #28
Default Question
What is the maximum overload protection for a 2hp single phase 115volt motor?
a) 27.6 amps
b)30amps
c)31.2amps
d)35amps
Luke.Anderson is offline   Reply With Quote
Old 02-05-2009, 07:03 AM   #29
a) 27.6 amps
b)30amps
c)31.2amps
d)35amps
I am terrible with these question but I would have said none of the above based on 430.32(C). Table 430.248 states 2hp means 24 amps. 24*1.4=33.6. Now I have no knowledge of what increments of overloads protection are available-- If I were to guess it would be (B) or (C).
Old 02-05-2009, 10:15 AM   #30
Greg's Avatar
a) 27.6 amps
b)30amps
c)31.2amps
d)35amps
Assuming the motor does not have a service factor of 1.15 or a temp rise of 40c the answer would be C 31.2 amps.
Old 02-05-2009, 11:12 AM   #31
lectric_hand6855's Avatar
(C) it is
What is the minimum conductor size that can be used in this capacitor circuit?
The capacitor is rated at 50A, the conductors are to be copper THHN rated at 90*C ran in conduit.
lectric_hand6855 is offline   Reply With Quote
Old 02-05-2009, 04:49 PM   #32
If you would I would love to understand this as I am weak in this area. Could you or someone else please explain further with code reference.
Never mind I found it.
Old 02-06-2009, 12:18 AM   #33
Ok heres one: What is the maximum amount of time that christmas lights can be left up for?
A. 180 days
B. 60 days
C. 45 days
D. 90 days
E. 365 days
Old 02-06-2009, 02:40 AM   #34
A. 180 days
B. 60 days
C. 45 days
D. 90 days
E. 365 days
(D) 590.3 B
“If it weren't for electricity we'd all be watching television by candlelight.”
Old 02-06-2009, 02:43 AM   #35
Old 02-06-2009, 04:19 AM   #36
sherman's Avatar
Originally Posted by electro916 View Post
2005 NEC
Only on fridays. I am sorry I couldnt resist.
sherman is offline   Reply With Quote
Old 02-07-2009, 09:00 PM   #37
Rodentia Rattus
BuzzKill's Avatar
Luke had the right response to Greg's repeat of my original question, it is c: "maximum" is the key word here...430.32(c) is the right code ref (2005 NEC).
New question!!
A 3-phase delta-wye transformer 480/208/120v has a 45kva load; the secondary line current would be aprox.____ and the primary would be aprox.____.
a) 54.1
b) 31.2
c) 73.4
d) 125
BuzzKill is online now   Reply With Quote
Old 02-08-2009, 08:16 AM   #38
Greg's Avatar
Not to split hairs but I had the right response. Luke has the plagiarism violation.
Old 02-08-2009, 09:25 AM   #39
I would have to say this is not correct. The information is not given to assume the motor is nor a 1.15 service factor or 40C or less. Given the question what is the max. overload with no other info I would still respond 140% not 130%. If thequestion had stated the motor had a service factor of less than 1.15 and a marked temp rise of greater than 40C than I would agree.
Old 02-08-2009, 10:56 AM   #40
Greg's Avatar
I agree but on a Prometric test if they do not give you that data you would go with the 130% answer. Test facilities will generally give you that additional info if they are looking for the 140% answer.
journeyman's practice exam icekillah NEC Code Forum 1 01-21-2009 11:35 PM
MikeHolt Practice Exams vs. The Real Thing chollapete General Electrical Discussion 22 01-19-2009 10:41 PM
three point test / clamp test nick General Electrical Discussion 11 10-13-2008 09:29 PM
Practice does not always make perfect electrictim510 General Electrical Discussion 7 09-10-2008 02:38 PM
can I test stillirnin General Electrical Discussion 8 02-14-2008 10:19 PM
