Old 06-29-2009, 03:20 PM   #161
1. 51/64 inches at 10 feet
2. A
3. 4
4. 26 cases and 17 bottles
5. 0.000000000023%
6. 5
7. Yes
8. 6 (extra credit: 1)
9. 8
10. 0 (Trick question, they already are)
ralpha494 is offline   Reply With Quote
Old 06-29-2009, 03:28 PM   #162
Oops. Forgot to ask one. (kinda like Dennis. Miss his avatar from that other place tho)
What is the maximum size time delay fuse you could use for short circuit/ground fault protection for a 50 Hp, 480 V, 3 phase 3 wire motor?
A. 100 amperes
2. 110 amperes
3. 125 amperes
4. 150 amperes
Old 06-29-2009, 05:09 PM   #163
Wish I was in the water
Greg's Avatar
A. 100 amperes
2. 110 amperes
3. 125 amperes
4. 150 amperes
3. 125 amp fuse calculation comes to 113 amps and 240.6 has standard ratings, so 125A fuse. allowed to go up one for branch circuit, if it is the feeder you down to the 110A fuse.
If you're gonna be stupid, you better be tough.
Old 06-29-2009, 05:16 PM   #164
Greg's Avatar
A switchboard shall have a minimum clearance of _____ft. from a combustible ceiling, unless a noncombustible shield is provided between the switchboard and the ceiling.
A. 3
B. 4
C. 5
D. 6
Old 06-29-2009, 05:21 PM   #165
A. 3
B. 4
C. 5
D. 6
I will go with "A" from art.408.18(A). The question is not worded quite right. It should say "For other than totally enclosed switchboard....
Old 06-29-2009, 05:31 PM   #166
Greg's Avatar
you are correct on both accounts
Old 06-29-2009, 07:46 PM   #167
Simplify this equation (x-a)^2 * (x-b)^2 * (x-c)^2 *....(x-z)^2
No Nec article required.
If you solve it send me a pm with the answer. Let's see how many mathematicians we have out there.
Old 06-30-2009, 06:03 AM   #168
We have a winner --- Ray Cyr
Old 06-30-2009, 08:41 AM   #169
Nice avatar, Dennis. Thanx. If only we could find somebody with a penguin slapping another penguin into the water.
Old 06-30-2009, 04:59 PM   #170
I really like that one. It is one of my favorites. Ralph also got the answer correct.
Old 07-02-2009, 07:17 AM   #171
A closet is 4' wide by 2' deep with a 12" shelf on the back wall. Door is centered in the space and is 24" wide. What is the longest length fluorescent strip one can install over the door or on the ceiling?
A: 12"
B: 18"
C: 24"
D: 36"
E: 48"
F: None of the above
Old 07-02-2009, 02:24 PM   #172
F fffffffffffffffffffff
Old 07-02-2009, 03:14 PM   #173
I'm going to say E depending on style of luminaire, cuz some are longer than 48", in which case D. Final answer. 410.16 (C)(2) and Law of two pieces of matter cannot occupy the same space at the same time.
Is this another trick question like which is longer a full stick of EMT, IMC, rigid aluminum, or rigid steel?
A. EMT
B. IMC
C. Rigid aluminum
D. Rigid steel
Old 07-02-2009, 04:46 PM   #174
Licensed Pro
Magnettica's Avatar
A. EMT
B. IMC
C. Rigid aluminum
D. Rigid steel
That's a crazy question and I think it was on my exam actually.
Is the answer D, Rigid?
Residential appliance outlets shall be installed within _______ inches of the intended location for the appliance.
A) 12"
B) 24"
C) 48"
D) 72"
Old 07-02-2009, 05:13 PM   #175
A. EMT
B. IMC
C. Rigid aluminum
D. Rigid steel
The answer is not D for my question.
Old 07-02-2009, 05:19 PM   #176
What is your reasoning? I am curious
If the closet is 4' wide and 2 feet deep then we must allow 12" minimum for a shelf. Even tho there are no shelves installed to the left or right of the door we must assume an 12" shelf. Thus 12" for each shelf is 24" leaving us with 24". Now we have to allow 6" for a fluorescent light on each side. That is another 12", thus we have 12" left over.
"A" is the correct choice. Art. 410.2 and 410.16
Old 07-02-2009, 05:24 PM   #177
A) 12"
B) 24"
C) 48"
D) 72"
D is the answer. Art. 210.50(C)
Old 07-02-2009, 05:26 PM   #178
A. EMT
B. IMC
C. Rigid aluminum
D. Rigid steel
No it's not a trick question and I will say "A" for your question.
Old 07-02-2009, 05:45 PM   #179
It was a trick question. I didn't even notice 410.2. Jumped at 410.16, thinking I found it.
I don't buy the 6" on each side of the luminaire tho. IMHO, if there isn't a shelf on the side you don't have to stay away from it. So I'm saying a 24" would be legal. (Unless the inspector wouldn't budge.) I change my answer to C.
Do I have any life lines left?
Old 07-02-2009, 05:55 PM   #180
No, it was tricky to find perhaps but not a trick question.
Here is the definition which I know you have read. Where does it say the shelf must be in place. Suppose no shelf is installed at the back of the closet. Are you saying that I can install a light back there? I don't think so.
410.2 Definitions.
Closet Storage Space. The volume bounded by the sides and back closet walls and planes extending from the closet floor vertically to a height of 1.8 m (6 ft) or to the highest clothes-hanging rod and parallel to the walls at a horizontal distance of 600 mm (24 in.) from the sides and back of the closet walls, respectively, and continuing vertically to the closet ceiling parallel to the walls at a horizontal distance of 300 mm (12 in.) or the width of the shelf, whichever is greater; for a closet that permits access to both sides of a hanging rod, this space includes the volume below the highest rod extending 300 mm (12 in.) on either side of the rod on a plane horizontal to the floor extending the entire length of the rod. See Figure 410.2.
Nope, you changed your mind too many times.
journeyman's practice exam icekillah NEC Code Forum 1 01-21-2009 10:35 PM
MikeHolt Practice Exams vs. The Real Thing chollapete General Electrical Discussion 22 01-19-2009 09:41 PM
three point test / clamp test nick General Electrical Discussion 11 10-13-2008 08:29 PM
Practice does not always make perfect electrictim510 General Electrical Discussion 7 09-10-2008 01:38 PM
can I test stillirnin General Electrical Discussion 8 02-14-2008 09:19 PM
Electrician Talk © 2006 - 2010 The Building Network LLC
