Is a exhaust fan required in a residential laundry room? - Electrician Talk - Professional Electrical Contractors Forum
Old 01-27-2010, 11:44 PM   #1
Rewards Points: 2,000
Default Is a exhaust fan required in a residential laundry room?
I imagine this requirement would be building code. Today I ran into this and am curious about this requirement. Not a hardcore resi guy so have some to learn about it.
Old 01-27-2010, 11:45 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
That would be a local building code, not an electrical issue.
Old 01-27-2010, 11:49 PM   #3
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Never heard of that being required and Long Island has strange people running things..
Old 01-27-2010, 11:54 PM   #4
Semi-Retired
BryanMD's Avatar
west coast energy codes? introducing add'l heat load crap like that.
if it isn't required it's probably a good idea anyway
November 2011: Relocated to Winston-Salem.
May have to change the username suffix.
Old 01-27-2010, 11:56 PM   #5
Vintage Sounds's Avatar
Rewards Points: 3,988
It is a requirement in Ontario AFAIK.
Old 01-27-2010, 11:59 PM   #6
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
You could install a recessed light with built-in exhaust fans. Those things are sharp!
Haven't done one yet but I have one coming up so I'll take a few pictures.
Replies based on NEC 2014
Old 01-28-2010, 12:15 AM   #7
Just trying to figure out if this is a wives tale in Eastern WA or the real deal...
Old 01-28-2010, 11:00 AM   #8
Amish Electrician's Avatar
I believe it's in the 'mechanical code.' A laundry room requires ventilation - which can be a window or a fan.
Amish Electrician is offline   Reply With Quote
Old 01-28-2010, 11:04 AM   #9
Rewards Points: 1,000
I agree with 480sparky. Probably local. Thinking about it, I think our local codes require some sort of ventilation in laundry rooms, either a window or a fan.
Old 01-28-2010, 11:05 AM   #10
Found a document distributed in Western WA:
http://www.ci.edmonds.wa.us/Public_H...B26-Energy.pdf
If that's a state wide building code, sure sounds like it is required.
Old 01-28-2010, 11:06 AM   #11
BEAMEUP's Avatar
Rewards Points: 6
Yup, you need a fan in the laundry room of a residence in Wa state. Building code.
BEAMEUP is offline   Reply With Quote
Old 01-28-2010, 11:33 AM   #12
I've done some digging ....
Yes, it's the "Mechanical Code" that applies here. There are no specific regulations regarding 'laundry rooms.'
Section 401 addresses ventilation, and it requires every 'occupied space' to be ventilated. This can be by window, doors ("natural"), or fans ("mechanical"). Only a few sections later is there a specific requirement for the direct venting of the dryer exhaust.
Old 01-28-2010, 12:04 PM   #13
Rewards Points: 5,198
Default exhaust fan
I heard two female electricians talking about that...but I don't know if they were married.
Old 01-28-2010, 12:44 PM   #14
I believe this to be accurate. Bathrooms and laundry areas have to be ventilated and that can be by the use of an operable window or by mechanical means.
Rick
r_merc is offline   Reply With Quote
Old 01-28-2010, 01:08 PM   #15
Inspector/Electrician
codeone's Avatar
Rewards Points: 250
mechanical code requires ventilation not exhaust, the dryer takes air out of the room needs to draw air from somewhere, this would be if its considered a confined space, also if it was a gas fired dryer.
codeone is offline   Reply With Quote
Old 01-28-2010, 01:51 PM   #16
BEAMEUP's Avatar
Rewards Points: 6
WASHINGTON STATE
VENTILATION AND INDOOR AIR QUALITY CODE
(2006 EDITION)
CHAPTER 51-13
302.2.1 Source Specific Ventilation: Source specific exhaust ventilation is required in each kitchen, bathroom, water closet, laundry room, indoor swimming pool, spa, and other rooms where excess water vapor or cooking odor is produced.
Old 01-28-2010, 02:26 PM   #17
Rewards Points: 264
Whenever we've installed bathroom fans in laundry rooms here people have absolutely loved them. Its not required in Atlanta through.
jbrookers is offline   Reply With Quote
Old 01-28-2010, 04:29 PM   #18
Fried Bologna um um good!
jwjrw's Avatar
Ok what did they love about them? Maybe I'm missing something. I cant think of any advantage to having one there. Ive never noticed any moisture problems in laundry rooms here. Just asking.
Old 01-28-2010, 04:32 PM   #19
Maybe folks in Atlanta are easily amused?
Old 01-28-2010, 04:46 PM   #20
I have a black cat.
Rudeboy's Avatar
It's pretty common to have a lot of moisture in laundry rooms.
I don't like to Save time and money.
switches for fan exhaust wirepuller Residential Electrical Forum 24 01-18-2010 08:23 PM
Exhaust hoods for restaurant sparkplug General Electrical Discussion 10 01-13-2010 10:16 PM
Laundry Areas Shubey NEC Code Forum 19 11-06-2009 01:54 AM
Panel in laundry room lagaceelectric NEC Code Forum 16 10-13-2009 09:21 PM
bathroom exhaust fans trademan Other Codes and Standards 12 05-02-2009 11:42 PM
