f40t12 to f32t8 - Electrician Talk - Professional Electrical Contractors Forum
Old 05-12-2010, 06:24 PM   #1
Fried Bologna um um good!
jwjrw's Avatar
Default f40t12 to f32t8
I have a customer that wants to change to t-8 fixtures(2x4 lay ins). Are retrofit kits the cheapest way to go? If so who makes the best ones? Also this is a business are there any tax credits for upgrading to more energy efficient lights?
Old 05-12-2010, 06:52 PM   #2
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
I think retros are the easiest way. Just buy a 3/4 lamp ballast , gut the old ones and install the ballast and lamps...pretty easy...Check with your poco , they may offer a rebaye also the fed does as well.
Old 05-12-2010, 06:56 PM   #3
jwjrw's Avatar
I was looking for a kit that has sockets and a ballast. All of these fixtures have at least 1 socket broke. So you are saying you just buy an electronis ballast and lamps?
Old 05-12-2010, 07:01 PM   #4
child please.....
Rewards Points: 14
Yeah, then just replace which sockets are bad...if there is only 1 or 2 bad sockets, then it's worth it....When you start changing out more than that, it may be more economical to change the entire troffer...I've seen at HD , 3 lamps troffer with a whip for under 50 bucks...
Old 05-12-2010, 07:03 PM   #5
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
You can use the same sockets for the T-8 lamps
Old 05-12-2010, 07:05 PM   #6
jwjrw's Avatar
Yea I know they are the same. You just need to know if you have the longer or shorter ones.
Old 05-12-2010, 08:20 PM   #7
child please.....
Rewards Points: 14
bp-lp....bi pin low profile sockets for lay-ins....Oh yeah and use shunted sockets or use the jumper for non shunted
Old 05-12-2010, 08:26 PM   #8
Rewards Points: 3,855
I can change out a whole fixture more cheaply than I can replace just ballasts and whatever broken tombstones there are. With a simple ballast change, you're still left with dirty refractors and reflectors.
I've never really found a retrofit "kit" that I like. Most of my customers are going from 4-lamp T12 troffers with the prismatic refractor to 3-lamp T8 troffers with an 18-cell prismatic reflector. There's not really a good kit for that. For 50 bucks my cost and about 7 minutes a fixture, I've got the whole thing changed.
Old 05-12-2010, 08:29 PM   #9
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
yeah seems to me replacing the entire fixture is a better, easier method...less labor should counter any increase in fixture cost.
I'd rather be sleeping.
Old 05-12-2010, 08:31 PM   #10
child please.....
Rewards Points: 14
I still find it easier to retrofit....but I will say that I've been selling people on the cell parabolics lately...they are awesome...
Old 05-12-2010, 08:32 PM   #11
The worst part about changing an entire fixture is all the dirt, debris, and other junk that might be on top of them. Occasionally, you'll find one that's almost locked in place by ductwork and pipes that went in after the fixture was put in, but a little bit of clever ceiling dismantling can normally get it out and back in.
Old 05-12-2010, 08:33 PM   #12
child please.....
Rewards Points: 14
I can retrofit at a cost of about $20 a fixture plus labor...a new parabolic troffer with lamps and whip is around 65-70 plus labor....still cheaper and faster to retrofit imo.
Old 05-12-2010, 08:36 PM   #13
You don't need a whip on a fixture that is to replace an existing fixture, and you're buying lamps no matter what. AND.. you cannot retrofit an existing fixture for 20 bucks if they're bi-level switched. PLUS, you're still left with a dirty fixture to clean at the end of the process.
Old 05-12-2010, 08:38 PM   #14
child please.....
Rewards Points: 14
Yeah, I know I don;t NEED a whip...just saying.... I don;t know what "bi-level " switching is either.... To each his own...there are times when I find retrofitting economical and there are times when I don't...
Old 05-12-2010, 08:41 PM   #15
Y.... I don;t know what "bi-level " switching is either....
Two switches for the same fixture. In a T12, it would be the outside lamps on one switch, and the inside lamps on the other switch. In a T8, it would be one lamp on one switch, and the other two lamps on the second switch.
Old 05-12-2010, 08:42 PM   #16
BuzzKill's Avatar
oh yeah, for office work so you can read your computer
Old 05-12-2010, 08:47 PM   #17
I know, but I was more specifically objecting to your apples to oranges comparison. You spec'd the ballast only for your retrofit price, and you spec'd a fixture with an unnecessary whip and lamps that you'd have to buy anyhow for the replacement price. You made the replacement cost seem more expensive than it really is.
Old 05-12-2010, 08:49 PM   #18
I've managed to upsell to bi-level switching in a heck of a lot of offices that didn't have them before. In a 3-lamp T8 fixture, that really give you three options; high, medium, and low. High, with both switches on. Medium, with the one switch on for two lamps, and low, with just the one switch on for the one lamp. People think that's cool.
You can talk all day about "optimal lighting levels", but the reality is that every person is different. People even appreciate the option of different lighting levels at different times of the day, and for certain tasks.
Old 05-12-2010, 08:49 PM   #19
child please.....
Rewards Points: 14
JUst trying to sell the retrofits...its the salesman in me...and yeah, I kinda figured you meant switching half the fixture.
Old 05-12-2010, 08:50 PM   #20
child please.....
Rewards Points: 14
How do you do this with 1 ballast?
