Failed an inspection - Electrician Talk - Professional Electrical Contractors Forum
Old 02-09-2012, 10:04 PM   #1
gold's Avatar
Rewards Points: 2,048
Send a message via Yahoo to gold
Default Failed an inspection
Nothing serious but I never been called on either of these two things.
1 breaker lock on the dishwasher. I have one of those small screw on type gadgets but he wants one that can be locked off.
2 Garbage disposal wire. This one strikes me as odd here we usually just run nm right to the g/d but he wants it protected from physical damage with smurf tube.
Agree disagree? What do you use on d/w breakers for locks. How (or why bother) do you protect nm from physical damage under a sink.
South Jersey btw
Define "Anger Management"
“Free at last, Free at last, Thank God almighty we are free at last.”
gold is offline   Reply With Quote
Old 02-09-2012, 10:08 PM   #2
Rewards Points: 2,050
Default seal
We've had to put sealtight under sink to disposal for years. Normal here. Lock on dishwasher I had an inspector tell me to do that just 1 time. made no sense but I just did it
Old 02-09-2012, 10:08 PM   #3
jbfan's Avatar
Rewards Points: 88
How do you protect it with smurf tube?
"The problem isn't that Hillary Clinton lies. We all know she lies. The problem is that her supporters don't seem to care"
jbfan is offline   Reply With Quote
Old 02-09-2012, 10:10 PM   #4
mbednarik's Avatar
Rewards Points: 1,030
i use cords and plugs for each. simple easy way for installation and service.
mbednarik is online now   Reply With Quote
The Following 2 Users Say Thank You to mbednarik For This Useful Post:
captkirk (02-12-2012), Magnettica (02-13-2012)
Old 02-09-2012, 10:11 PM   #5
just slide it over nm (1/2 inch) and use 90 degree sealtight fitting into disposal
The Following User Says Thank You to Cletis For This Useful Post:
jbfan (02-09-2012)
Old 02-09-2012, 10:11 PM   #6
gold's Avatar
I never had to put a lock on a dw. This was a first for me as well I'm trying to find it in the book but it escapes me. Physical damage part I don't see how smurf tube will make it better.
Old 02-09-2012, 10:14 PM   #7
rdr
Expatriate in Training
rdr's Avatar
Why lock a dishwasher on?
Just lock them all.
VOILA! No more trips!
rdr is offline   Reply With Quote
Old 02-09-2012, 10:14 PM   #8
Default ?
Makes it a little better prone to things bumping up against it for years and all that soap stuff down there splashing. Lately, I've found it easier to put a jbox at rear of undercabinet and come out with mc whip to disposal. Easier to hook up and good protection.
Old 02-09-2012, 10:22 PM   #9
I have always been under the impression that if the dishwasher had a on/off switch a lock/service switch wasn't required.
burndy is offline   Reply With Quote
Old 02-09-2012, 10:26 PM   #10
gold's Avatar
I think this is what I'm going to do.
Any idea WTF I have to put a lock on it?
Old 02-09-2012, 10:29 PM   #11
Rewards Points: 210
That's how we do it.
The Following User Says Thank You to Chris1971 For This Useful Post:
Teaspoon (02-10-2012)
Old 02-09-2012, 10:46 PM   #12
Rewards Points: 530
That is a good point, wouldn't that unit switch serve considering it discosnnects all ungrounded conductors? Too lazy to open book.
Old 02-09-2012, 10:49 PM   #13
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
I Don't see a need for a lock either, Just make it cord and plug.
Semi-Ret Electrician (02-12-2012)
Old 02-09-2012, 11:10 PM   #14
Rewards Points: 864
Here they want the breaker lock on the dishwasher because it is usually hardwired without a line of sight disconnecting means. Electric water heaters can ding you here too.
Disposals never really had to protect the wire in smurf etc. I do know from a past coworker that you need to watch the cords make sure that they are the heavier duty appliance type not cheapie light replacement type. He got dinged on that, we do it right 'cause we do it twice...
Sparky J is offline   Reply With Quote
Old 02-09-2012, 11:14 PM   #15
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
what part of georgia are you from anyway???
I'd rather be sleeping.
Old 02-09-2012, 11:16 PM   #16
That Guy
Mr. Sparkle's Avatar
Rewards Points: 2,002
If the DW has a manual mechanical on/off switch you don't need the lock but.........what type of panel?
Old 02-09-2012, 11:28 PM   #17
gold's Avatar
Seimans if I recall.
It has an electronic on/off
Old 02-09-2012, 11:35 PM   #18
di11igaf's Avatar
Rewards Points: 276
Just lock them all.
It would be to lock the breaker open.
If you were joking then my bad
IBEW
There's no place like ~/
di11igaf is offline   Reply With Quote
Old 02-09-2012, 11:36 PM   #19
jbfan's Avatar
Rewards Points: 88
The 64 dollar question!!!
Old 02-09-2012, 11:37 PM   #20
Rewards Points: 2,012
South Jersey btw
#1 - Is this a 'new' inspector ?
My guess, yes, perhaps 30-40 yrs old. Code suave - and wants you to know it.
Be nice, 'IT' may be around a while (). Yet stand your ground. You must know the 'code' as well.
#1-A - If you installed a rec and cord - There's your disconnect.
#2 - Technically - Yes. you should have that in flex or something, then you must secure it.
But it seems like he wants to do his 'job' . Justify the public funds paying him/her (all well and good).
Remember though - What was 'ACCEPTED' - before - may not be now. . So know your 'code'. Never!!! get in a gun fight with a knife.
New sheriff.
Napolean - Ask - politely - for any code references that you may feel in conflict with your install.
But always in a manner to let the Inspector 'off' the hook.
(Makes them feel better and less likely to bust yo arse later. Not that they ever would).
The Following User Says Thank You to leland For This Useful Post:
Restoration (02-10-2012)
failed inspection ratrod56 General Electrical Discussion 32 10-19-2011 07:36 PM
Failed inspection today...lol NolaTigaBait NEC Code Forum 11 08-11-2011 01:48 PM
Failed inspection Midnitel NEC Code Forum 44 04-07-2011 06:20 AM
Failed inspection today???? bighills NEC Code Forum 44 01-27-2011 08:55 PM
I failed for what? joe cool General Electrical Discussion 23 06-04-2010 01:25 PM
