Originally Posted by subelect
Would have been easier to wait for the proper panel, and done it right the first time. I hope he make you eat the costs of the panel change out.
Thanks for your useful input.
Buck, I thought that it would be acceptable to feed a sub panel using the main lugs, but I could not find anything in the Code that addressed this one.
Sparky, he is going to want a few porcel. fixtures and 3 or 4 20 amp ckts for heat lamps. The heat lamps are almost never coincident, but he will want them in multiple locations to make it as flexible as possible. By far, the heaviest loads are all ready taken care of: the branding irons and dehorners at the chute and that 3 hp hydraulic pump. The most load on the subpanel will be 40 amps for a few hours every week in the spring, and then it will be idle the rest of the year. The #2 feeding all of it will be plenty.[/quote]
what happens when he builds something else next to it that needs more juice. Always upsell the product that you are doing. it will be easier for the customer in long run.
And why would you run copper in the air when al is lighter?
