Old 07-23-2009, 09:42 PM   #1
Default Feeding underground in block walls
The job I am on required quite a few outlets, both electrical and data, to be fed from underground, including a dozen or so in a free standing wall, with nothing to be fed from above...
what I did was saw a notch in the footing big enough to 90 up into the block. There was alot of sawing, but i don't see anyother way.
As this is my first job from start to finish, I was wondering if there is some other way to get up into to wall than sawing into the footing...or is this pretty standard?
Marshall175 is offline   Reply With Quote
Old 07-23-2009, 09:46 PM   #2
Unlimited Lic.Electrician
william1978's Avatar
The slabs that I have roughed they run block up to floor level and before they poured those block cells full I would knock a hole in them with a hammer and stub up the pvc. Did a ton of schools like this. It always worked great.
Old 07-23-2009, 09:47 PM   #3
Do you have a picture of what you doing?
Old 07-23-2009, 09:59 PM   #4
mattsilkwood's Avatar
yea a pic would be great, i cant see where you would have to cut the footer.
Old 07-23-2009, 10:02 PM   #5
In northern climates, where the footer is way deep because of the frost line, we don't have this issue. In more southern areas, where the footer can be close to just below grade, notching the footer may, indeed, be necessary.
Old 07-23-2009, 10:11 PM   #6
maybe im just not seeing it right but the footer will always be below ff so there is no need to notch the footer to get into the wall.
Old 07-23-2009, 10:14 PM   #7
That sorta depends on the size of the sweep, depth of the pipe, and the depth of the footer.
Old 07-23-2009, 10:16 PM   #8
Seen your member
Check your A Sheets for a cross-section of the wall. Usually, the first course of CMUs is below the floor, so unless you're working with something larger than 1¼", you can get a bend into the lowest course and still not have to deal with the footings.
Old 07-23-2009, 10:17 PM   #9
Unless the slab and the footer is a monolithic pour.
Old 07-23-2009, 10:25 PM   #10
yea but the op said rec and data so im thinking 1" tops.
Old 07-23-2009, 10:31 PM   #11
Seen your member
Then it's gonna get expensive.
It took me a while to find one, but here's a photo of what I mean:
Where the CMUs are cut will be below the floor, so you can pretty much cut or bust up the bottom course if this is what you have. The pipes on the upper right are resting on the poured floor in that area. Your A Sheets should have details of a wall cross section.
Old 07-23-2009, 10:34 PM   #12
me to
Old 07-24-2009, 05:46 AM   #13
it would have been great if the first course was below grade, and in one area, it was. The entire rest of the building, though, the bottom of the first course was grade, hence, having to notch the footing....
yes, mostly 3/4" and 1".....occasionally a 1 1/2" for a tv
Old 07-24-2009, 09:21 AM   #14
drsparky's Avatar
Next time plan ahead and get conduit in place before the pour.
Old 07-24-2009, 10:56 AM   #15
BDB
Yes, what drsparky said
Proud Father of a US Army Solider
BDB is offline   Reply With Quote
Old 07-24-2009, 11:12 AM   #16
Not Peter D
Bob Badger's Avatar
I have never done a building with CMUs that are below the slab. We would have to notch out the foundation wall (not the actual footing) to get inside the CMUs.
Bob Badger is online now   Reply With Quote
Old 07-24-2009, 12:51 PM   #17
Exactly what I was going to say. Always install conduit before the slab is poured. Always.
Old 07-24-2009, 08:49 PM   #18
Fine and dandy, but sometimes the EC isn't even hired when that sort of work is being done.
Old 07-24-2009, 08:56 PM   #19
Seen your member
Or the one that did get hired didn't get to the job site on time, so you get a call to clean up the mess.
Conduit in block sparkysteve General Electrical Discussion 39 10-05-2009 12:29 AM
New guy on the block shockey 1 Introductions 4 03-25-2009 10:51 PM
12-2 feeding 12/3 subelect NEC Code Forum 4 11-09-2008 08:56 PM
New Guy on the block rnspark Introductions 7 07-10-2008 05:24 PM
mental block stillirnin General Electrical Discussion 9 01-25-2008 09:16 PM
