Old 02-10-2012, 01:33 AM   #1
zwodubber's Avatar
Default finished stripping wire, off to the scrapyard in the AM
This was the excess 600MCM the boss gave me last week. After working late all week I made sure to get some done each night for three days. Propane torch and utility knife worked pretty good although it took a while to get my technique down.
Now I just have to try not to spend it on tools
zwodubber is offline   Reply With Quote
Old 02-10-2012, 01:42 AM   #2
joe cool's Avatar
So, what did you learn about technique. I've got at least a trash can full of old wire with insulation. Is it worth my time to strip it and how? I live in the country, I could burn it, but that seems environmentally incorrect?
joe cool is offline   Reply With Quote
Old 02-10-2012, 02:00 AM   #3
zwodubber's Avatar
the wire I had was in 8 to 16' lengths. I ran the torch along the wire around 12" then cut off the heated part in one swipe of the blade down the wire. repeat as many times as needed until you get to the end. The jacket simply peeled off the entire length of the cable. I threw the insulation in contractor bags.
Also burning it is not pocket friendly here. Price drops by about half for burned vs. shiny bright. MDShunk did have a suggestion for cleaning burned wire. He posted in a similar thread
Old 02-10-2012, 02:01 AM   #4
Data Tech/Apprentice.
chewy's Avatar
Mmmm... Mill Berry....
Old 02-10-2012, 02:10 AM   #5
erics37's Avatar
I've always pondered this.
Bare bright & shiny copper is worth more per pound than copper still covered with insulation, right? Well, the insulated stuff still has some value, and furthermore, the wire insulation itself adds some weight (not much of course, but still some amount).
So my question is, if you algebraically graphed a linear function of the total value of bare copper over a large range of weight, and then superimposed a similar function of the total value of insulated copper over the same weight range, would there be some point where those two functions crossed, and at what weight would that intersection point occur?
The idea is that although insulated copper wire is worth less, it weighs more than the same amount of bare copper (by linear footage), so at some point, if you had saved up enough, it would theoretically be worth it NOT to strip the wire.
Anyone have any data I might be able to work this up with? The only unknown here is how much the insulation weighs. Maybe if someone can go measure out a 10 or 20 foot piece of 1/0 THHN, weigh it, then strip the insulation off and weigh the copper by itself. That should be enough to extrapolate from.
- Eric
Old 02-10-2012, 02:45 AM   #6
Maybe weigh a foot of the 600 insulated then weigh a foot stripped and do some figuring from there. I've actually wondered the same thing.
mnelectrician is offline   Reply With Quote
Old 02-10-2012, 02:49 AM   #7
zwodubber's Avatar
Here is a chart of bare copper weights
http://www.alanwire.com/awscripts/ma...cgi?ntype=BARE
The Following 2 Users Say Thank You to zwodubber For This Useful Post:
frenchelectrican (02-11-2012), Podagrower (02-10-2012)
Old 02-10-2012, 06:18 AM   #8
1,000,000th Poster
Big John's Avatar
Maybe I don't follow the math, but it seems to me that a smart scrapper would realize that the insulation weight is a fixed percentage, based on that reduce the payment for insulated wire far enough below bare that it would never be more profitable to turn in insulated.
-John
Big John is online now   Reply With Quote
The Following 4 Users Say Thank You to Big John For This Useful Post:
bruce6670 (02-11-2012), sstlouis03 (02-10-2012), SteveO. (02-10-2012), stuiec (02-10-2012)
Old 02-10-2012, 06:46 AM   #9
jrannis's Avatar
We have a guy here that will pay the stripped price for insulated if you have more than 200 or 300 lbs.
The machine they have strips it really fast
"When a your only tool is a hammer, every problem looks like a nail"
jrannis is offline   Reply With Quote
Old 02-10-2012, 07:14 AM   #10
Stab&Shoot's Avatar
Ive done it both ways. I think Eric's theory is correct. I no longer strip it. The .20c per lb more that you get for stripping it yourself is not worth the hassle. Unless of course you have A LOT of extra time on your hands.
Stab&Shoot is offline   Reply With Quote
Old 02-10-2012, 07:28 AM   #11
Good luck with the scrap.
GA is on a campaign to regulate the sale of scrap.
The major change wanted is to wait two weeks before being paid.
Water and women are in short supply! There's not enough dope for us all to get high! Jimmy Buffett!
jbfan is offline   Reply With Quote
Old 02-10-2012, 07:38 AM   #12
Going_Commando's Avatar
Last time we scrapped wire, insulated larger than 1/0 was 2.35/lb or so and bare bright was 3.48/lb. Definitely paid off to strip it. Lately, I just wrap the wire around a bumper, pull tight with one hand, and run a sharp utility knife blade down it, and then the insulation will peel right off unless it is really old wire.
Going_Commando is online now   Reply With Quote
Old 02-10-2012, 07:45 AM   #13
Heavily Armed Member
HARRY304E's Avatar
Always scamming to take the money away from the little guy...
Having a 2 week waiting period does nothing but punish the little guy.
If a guy show's up with a 1,000' roll of 750's copper then that should be a red flag.
Old 02-10-2012, 07:52 AM   #14
Hippie's Avatar
If its bigger than #2 ill strip it otherwise its too much trouble. I would rather not risk cutting myself stripping out some #10, def not worth it lol
Hippie is offline   Reply With Quote
Old 02-10-2012, 08:03 AM   #15
976-EVIL
mcclary's electrical's Avatar
It's not .20 more. It's normally at least a dollar a pound more.
The Following 3 Users Say Thank You to mcclary's electrical For This Useful Post:
bruce6670 (02-11-2012), sparky970 (02-10-2012), sstlouis03 (02-10-2012)
Old 02-10-2012, 08:16 AM   #16
Last time I scraped wire, I had an option of a check that day, or coming back the next business day for cash.
My son scraped a van that day and received cash.
Old 02-10-2012, 08:54 AM   #17
Sideways Sparky
farlsincharge's Avatar
Looks like the price of copper has risen pretty good over the last month. I took a beating on some stuff took in around November.
What prices have you guys been seeing lately?
farlsincharge is offline   Reply With Quote
Old 02-10-2012, 09:05 AM   #18
Podagrower's Avatar
Around here we have bare bright, insulated, and covered. Covered is thhn or such, and insulated is NM types. Smaller than #4, I will strip if I have time, smaller than #8 I almost never strip. It's pretty easy to up your income on 2 wire romex by grabbing the ground and using it to rip the sheath, gets you 1 bare bright, and 2 covered, as opposed to insulated.
I took in several hundred feet of control cable that was 7 conductor 14 gauge, with an outer jacket. No way was I going to strip it, but getting paid for the insulation on it was probably worth it.
Podagrower is offline   Reply With Quote
Old 02-10-2012, 09:26 AM   #19
Actually thieves will cut short pieces off of a roll of large size wire as fast as they will try to steal the whole roll.
I think a waiting period is a great deterent, (not that it will solve all theft problems) most crack and meth heads won't bother if they have to wait a couple weeks. On the other hand, the little guy that's legal can put the new toy on lay a way and pick it up later.
Fibes is offline   Reply With Quote
Old 02-10-2012, 09:45 AM   #20
Buy American
crazymurph's Avatar
A draw knife works great for stripping large wire. Put one end of wire in vice (or other secure means), have a partner stand behind you and hold wire taught. Pull draw knife towards you to strip wire. You and partner keep working away from vice.
crazymurph is offline   Reply With Quote
Stripping wire with your dykes pawirenut General Electrical Discussion 304 07-26-2012 03:20 PM
Most common wire gauges for stripping - residential JBC1 Tools, Equipment and New Products 13 01-14-2012 10:56 PM
Wire stripping machines Chris1971 Tools, Equipment and New Products 18 01-06-2012 01:21 AM
stripping romex cthermond General Electrical Discussion 108 05-06-2011 04:55 PM
Stripping Romex mikeg_05 General Electrical Discussion 75 04-16-2010 07:54 PM
