Old 10-23-2008, 12:43 PM   #1
AKM
Default Fishing wire old house
I am new to the trade. Any way of not opening holes in old plaster when pulling romex for new branch circuits in old houses. IE pulling romex around corners in finished ceilings/walls
AKM is offline   Reply With Quote
Old 10-23-2008, 02:10 PM   #2
chenley's Avatar
Run it up in the attic or below in the crawlspace/basement. There's no real good way to go around a corners without cutting the sheetrock. Get yourself a whip bit and fish stix.
Old 10-23-2008, 02:27 PM   #3
When I did residential I have removed baseboard trim, removed siding, as mentioned the basement and attic, special drill bits and institution, experience and a certain amount of luck.
Old 10-23-2008, 02:32 PM   #4
chenley's Avatar
Luck plays a big role, had a problem a few days ago where I could not get the fish tape down a wall. I was hitting a vent pipe for the jacuzzi, toilet, sink whatever. Took a washer and some string and threw it down the wall and it went right past the pipe.
Old 10-23-2008, 04:42 PM   #5
village idiot
piette's Avatar
I carry 20' of jack small chain for that very reason. The jack chain drops straight down the wall with enough weight to keep it heading down and gives you a great way to tie your wires on to pull back up.
Jeff
piette is offline   Reply With Quote
Old 10-23-2008, 05:01 PM   #6
Fished around a corner one time, first try and had it. The I dropped the fish tape and it fell out. It took me 45 minutes to get it back to where I could catch it.
Old 10-23-2008, 05:12 PM   #7
gilbequick's Avatar
Fishing old houses sometimes takes a lot of patience. Sometimes you get them quick, sometimes it might take you a couple of hours for one pull. Sometimes you just can't get away from cutting a hole.
The toughest houses I've had to fish wires in are the old plaster walls that are framed with timbers, not 2X4's. Since the wood isn't always flat the fish sticks and tapes catch and bend and it can be a pitb, but it just takes patience. One thing that has helped me a good bit are the attatchments that go on your fish stick that looks like a cooking wisp. It'll go over bumps and cross braces a lot easier.
Avoid going around corners if you can. If you can't, fish the attic or crawlspace, or do like Brian said and take off the baseboard if you have to.
Also get a good helper. Someone who sucks will drive you crazy with frustration, and many times they'll do more damage to walls and ceilings than help.
Old 10-23-2008, 05:19 PM   #8
Tuckahoe Sparkplug's Avatar
I learned the hard way early on a lesson in how older houses were constructed when I attempted to install some outlets too close to the corners. They often ran angle braces in the corners blocking the void between the studs. Imagine dropping a jack chain in a wall from the attic only to find a brace running above the hole you just cut for the outlet.
A bad day of fishing is always better than a good day at work.
Tuckahoe Sparkplug is offline   Reply With Quote
Old 10-23-2008, 05:40 PM   #9
I just finished a job fishing outlets and switches in a 1800's house.
There was a hand hewn 6x6 about 2 foot down on the front and back walls.
The side walls had the 2x4 angle bracing in it.
And some of the interior walls were 2x4 on the flat!
It took 4 days to do 3 bedrooms, 1 bath, and a hall light.
The plaster was soo brittle, the only way to keep from totally distroying it was to use an angle grinder to cut it.
Not to mention the attic was blown in cellulose.
This was the worst fishing job I ever did.
heel600 is offline   Reply With Quote
Old 10-23-2008, 05:53 PM   #10
Bababoee
captkirk's Avatar
You have to do what jim carrey did in the cable guy. Talk to the house and ask it where its sweet spot is..... Try to find the least obtrusive way to go between floors. Maybe between the chimney stack, or through closets. There is almost always a way you just need to find it. I have become somewhat of an expert with this. People/GC's are sometimes amazed when I add old work cans without holes everywhere. Its a skill that you develop like any other. Gaining a good understanding of different framing styles also helps. If I go into a house that has a truss system, I smile cause I know its gonna be a good day, or a house that has ballon framing and no insulation is also an easyier retrofit. Some guys are great with pipe work. Its all relative with what you do day to day.
Old 10-23-2008, 06:47 PM   #11
THe best houses are balloon frame, studs run from sill plate in the basement to the attic and no insulation.
Old 10-23-2008, 07:02 PM   #12
Wiremold
bobelectric is online now   Reply With Quote
Old 10-23-2008, 07:31 PM   #13
think i'll stick to big comm/ industrial
Old 10-23-2008, 09:10 PM   #14
gilbequick's Avatar
I hear lifetime commercial guys saying they'll never do that residential crap all the time. If you don't want to, fine, but it's never a bad thing learning something new. Be as well rounded of an electrician as you can be and if push comes to shove you'll have more doors open when you need them, even if they're only temporary.
Old 10-23-2008, 09:26 PM   #15
william1978's Avatar
I wouldn't like wiring house's full time but if that is what I needed to do to feed my family that is what I would do. If I had it my way all I would do is large commercial work.
Old 10-23-2008, 09:35 PM   #16
Licensed Journeyman
nolabama's Avatar
houses can be fun but i prefer commercial work - for going around a corner the basboard can sometimes be the easist - remodels suck because i never have a helper that will go under a house and be worth a darn ( i make them go into the attic and stay after they pull that though)
nolabama is online now   Reply With Quote
Old 10-24-2008, 07:35 AM   #17
Winner winner chicken dinner. I agree 110%
Old 10-25-2008, 01:36 AM   #18
Cheetah Speed System
electrician1957's Avatar
Let's see if I got this right, you just registered at this site and have 1 post. You are "new to the trade" and yet for some inexplicable reason, there is no Journeyman or senior electrician in your life to answer these questions. Therefore since you are "new to the trade" and apparently are working alone (an unenviable position, to be true), you must ask real electricians how to do this type of work.
Your whole shtick has DIY written all over it.
electrician1957 is offline   Reply With Quote
Old 10-25-2008, 05:53 AM   #19
Patience Persistance and Practice. I amaze my self sometimes with the fishing crap I do. No F-ing way has been uttered on many occasion
Marco Electric is offline   Reply With Quote
Old 10-25-2008, 08:08 AM   #20
JohnJ0906's Avatar
When it comes to fishing wires, my helper and I like to say, "Sometimes it's good to be good, sometimes it's good to be lucky!"
There has been a few times I have looked at a job and figured on 5 holes or so, and done it with 0.
John from Baltimore
"One day at a Time"
The house from HELL! Speedy Petey Code Violation Discussion 55 02-11-2013 04:15 PM
new house new builder ralph General Electrical Discussion 9 10-02-2008 09:37 AM
hours to wire house rebel34 General Electrical Discussion 22 02-19-2008 07:46 PM
House Wiring Help please FwuffyTheBunny General Electrical Discussion 2 07-12-2007 10:50 PM
New house service... Dayne Services and Service Equipment 17 06-03-2007 09:36 PM
