Weve been changing some of our bulbs out around the house to the compact fluorescent bulbs for awhile now, but last night i noticed that when i turned the switch off that they flickered for almost a good minute. Anybody know what causes this?
The switches are just normal toggle switches from the 70's 80's. Its only this one light in my kitchen that ive noticed it. I havent checked to see if its done it again ive just noticed that one time.
Yes. Many electronic switches use the switch leg as a grounding conductor. There's a very small current flow through the circuit, which is low enough not to light an incandescent filament, but can cause problems with CFLs. Either reinstall the incandescent lamp, or replace the switch with a normal one.
Flourescents have a burn in time. The first time you fire it up,,,it can flicker, burn dim, blink. But after ther initial burn in, they should act normal. I think it amounts to getting the gases to the perfect pressure.
It's a phenomenon called "Electronic Dieseling". Its akin to turning your car engine off and it continues to chug along for a few seconds.
The solution is to completely disassemble the ballast and clean all the electron carbonization from between the windings. Reassemble the ballast, being sure to dull any sharp bends of the electron flow pipes. Then when restarting, make sure you use an hertzane electron additive to raise the electrons sparkrtronic flash point. This should prevent future events of electronic dieseling...
Why don't you get your DMM out and see if there is any input voltage going to the ballast? Then measure the outputs to the lamps. If you have input voltage, you have a power switching problem.
If you have voltage at the ballast outputs, you have a ballast problem. If that is the case, try replacing one ballast in one fixture. If that fixture now turns off normally, then you know what you have to do..
Good luck!:thumbsup:
If they "glow" and there is definitely no power going into or out of the ballasts, then the source is probably external (like a strong RF or EMF). Do you live near a microwave transmitter or under high tension powerlines? Other than that, I have no other explanation.
Related Threads
Electrician Talk
2.3M posts
93.1K members
Since 2007
