fluorescent light question - Electrician Talk - Professional Electrical Contractors Forum
Old 07-13-2009, 09:48 AM   #1
Default fluorescent light question
if a fluorescent light doesn't come on until you touch the light could that mean that the ballast is going bad? of that the bulb is going bad
bacon8685 is offline   Reply With Quote
Old 07-13-2009, 09:54 AM   #2
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
A few lights I've seen ih the past require a ground to light. It's possible you're grounding the light and making it light. It's also posssible that you're jiggling it when you touch it and completing a loose connection. Does it do it every time? Did it just start or is this a new install?
Old 07-13-2009, 09:58 AM   #3
this is a old light, its a 4'. There are a total of 5 lights ties to one switch and recently when the switch is turned on only one bulb will come on until i touch them. the second i touch the end one by one they come on. i was figureing it is a bad ballast since they are all tied together, could one bad ballast cause that sort of reaction.
Old 07-13-2009, 10:21 AM   #4
Toronto Sparky's Avatar
Rewards Points: 1,008
I find that replacing the lamp fixes that.
I am thinking the the static in your hand helps to get the electrons moving.
Don't fight .. Play nice!
Old 07-13-2009, 12:01 PM   #5
lectro88's Avatar
Default touching lamp
I've have this problem at my mothers house. Just a slight touch to the lamp seems to excite the gases. I relpaced the old keyless over the sink with a 3' single lamp electronic ballast T12 fixture. This was the new tecnology then 13yrs ago. And there was no ground in the cable, its an old house. I beleive the static or minimal ground from the touch starts the ballast. First Post Guys.
lectro88 is offline   Reply With Quote
Old 07-13-2009, 12:21 PM   #6
I also have a probelm with another set of lights, in one of our offices the light swtich has to constantly flipped on and off until it comes on. Would a bad ballast also cause that, or could it be a bulb issue. I'm trying to get insite into these probelms to secure my suspicions.
Old 07-13-2009, 12:38 PM   #7
Lamps are cheap..
Try them first
Old 07-13-2009, 04:29 PM   #8
Larry Fine's Avatar
Rewards Points: 150
Send a message via AIM to Larry Fine
I believe it's lack of proper fixture/ballast grounding.
I laid in bed last night, looking up at the stars, and
I said to myself, "Where the hell is my ceiling?!"
Larry Fine, Master Electrician and
Electrical Contractor, Richmond, Va
Larry Fine is offline   Reply With Quote
Old 07-13-2009, 04:43 PM   #9
I own stock in FotoMat!
Rewards Points: 6,520
Ditto.
Old 07-13-2009, 09:32 PM   #10
Rewards Points: 300
Ditto.
X3, need a ground.
Old 07-13-2009, 09:40 PM   #11
Rewards Points: 1,000
I also think it is bad grounding and yes, new bulbs usually help -- for a while.
Old 07-13-2009, 10:05 PM   #12
kbsparky's Avatar
Damp ambient conditions and dusty or dirty bulbs can make them sluggish starting.
Try removing the bulbs, and wiping them down with a damp cloth, then a dry cloth, and replacing.
We have had better results with clean bulbs.
-KB
Old 07-14-2009, 11:24 PM   #13
CFL
Rewards Points: 940
What about that coating that the manufacturer puts on the lamps? It's suppose to help them light right? But I guess if it's real dirty you don't have a choice.
CFL is offline   Reply With Quote
Old 07-15-2009, 08:14 AM   #14
My back hurts
Rewards Points: 25
What coating?? Do you mean the coating on the inside of the lamp?
John
JES2727 is offline   Reply With Quote
Old 07-17-2009, 09:57 AM   #15
I have tried replacing the buld and ballast in all of them. I guess the next step is to check the ground should i check it from the switch or the fixture. or both i've never experienced this if you change the bulbs and ballast normmally that always works for me
flourescent light question icandrawem2 General Electrical Discussion 18 03-20-2010 12:42 PM
Pulse Start MH Light fixture Question KEI Lighting Design 2 06-24-2009 11:12 PM
Fluorescent Light Ballast gatzke General Electrical Discussion 1 12-20-2008 09:15 AM
Street light power consumption question Rob1984 General Electrical Discussion 7 11-06-2008 05:59 PM
Question about installed light fixture & ceiling fan tallford78 General Electrical Discussion 3 07-07-2007 06:31 PM
