Old 05-06-2011, 11:23 AM   #1
Default gas water heater
Wirlpool gas water heaters have left hand threads on their thermocouple and guess what nobody makes a left hand thermpcouple. I have a conversion kit coming overnited from wirpool.
Mr Rewire is offline   Reply With Quote
Old 05-06-2011, 12:32 PM   #2
976-EVIL
mcclary's electrical's Avatar
If nobody makes one, where did the original come from?
Old 05-06-2011, 12:55 PM   #3
Heavily Armed Member
HARRY304E's Avatar
Probably the factory..
Old 05-06-2011, 01:02 PM   #4
It was a factory mistake Wirlpool designed their themocouple to be left hand thread but nobody made a replacement that was left hand thread so the made a conversion kit.
Old 05-06-2011, 01:29 PM   #5
976-EVIL
that's my point, he said nobody makes it
Magnettica (05-06-2011)
Old 05-06-2011, 01:29 PM   #6
976-EVIL
Is this a new machine that has never ran?
Old 05-06-2011, 01:30 PM   #7
HARRY304E's Avatar
Yes i see that now from post #4.
Old 05-06-2011, 01:32 PM   #8
Fond of three phase
I didn't think Whilpool made their own water heaters. I thought it has a private labeled product made by a firm that makes heater heaters as their main product line.
retiredsparktech is offline   Reply With Quote
Old 05-06-2011, 02:00 PM   #9
mgraw's Avatar
Whirlpool water heaters are made by AWHC. The left hand threads were not a mistake. It was something AWHC tried on several brands and then went back to right hand threads. They did make replacement thermocouples for a while and then went to the adapter.
mgraw is online now   Reply With Quote
Old 05-06-2011, 03:12 PM   #10
They give you the adapter kit for free just finished installing it.
Old 05-06-2011, 06:43 PM   #11
976-EVIL
Why is an electrician installing a gas water heater?
Old 05-06-2011, 06:44 PM   #12
To make money and please a customer...?
Old 05-06-2011, 06:46 PM   #13
976-EVIL
Only a failing electrician would do plumbing, and I'm sure he doesn't have a gas or plumbing license...
Old 05-06-2011, 06:46 PM   #14
I've done it a few times. Only for friends and family though.
Old 05-06-2011, 07:11 PM   #15
That's a lame and ignorant statement.
JohnR (05-07-2011)
Old 05-06-2011, 07:14 PM   #16
I concur. The mechanical skills required to install or change out a water heater are nothing that an electrician cannot handle. I don't make it a point to regularly change water heaters because I hate to do plumbing, but it's not beyond the realm of the skill level set most of us possess.
Old 05-06-2011, 07:22 PM   #17
The gas line is a flexible hose, similar to what a homeowner would disconnect when cleaning behind their stove. Soldering pipes is not hard, I guess I just assumed that most electrician were mechanically inclinedand can do tasks like this.
It's not just about doing other trade's work, it's about doing ANY work. As long as you are still charging what you would for electric, who cares what you do? I have changed door locks, hung shelves, reinstall Windows OS, hung Christmas decorations, etc. at customer's houses. It seems like many people think electricians can do everything else, I find that to be a good thing, I'd much rather do anything I listed than crawl thru an attic or crawlspace.
Old 05-06-2011, 07:37 PM   #18
You don't even need to solder anymore. Sharkbite fittings!
Old 05-06-2011, 07:46 PM   #19
976-EVIL
The two of you are something...I never said it was hard, I never said it was beyond the realm of what we know, it's just NOT electrical, that's all my statement is based. An electrician does not do plumbing. If someone called my phone and asked to install a gas water heater,,,I would not even slightly consider it
unionwirewoman (05-08-2011)
Old 05-06-2011, 09:15 PM   #20
PGW Professional
Magnettica's Avatar
Actually, plumbing + electrical + HVAC = $$$$$$$$$$$$$$$$$$$$$$$$$$$$
It's not a secret really.
Gas Water Heater Dennis Alwon General Electrical Discussion 67 03-27-2011 08:09 PM
the hot water heater subelect General Electrical Discussion 15 11-30-2010 03:23 AM
#12 to water heater Xknob&Tube Residential Electrical Forum 18 06-21-2010 07:21 AM
water heater daisymay39 General Electrical Discussion 3 01-17-2010 07:45 PM
OCP on Water Heater william1978 General Electrical Discussion 31 12-02-2008 09:32 PM
