Closed Thread
Old 03-02-2008, 06:12 PM   #1
Default General Contractor with a new trailer
I bought an Interstate Load Runner covered cargo trailer…. Dimensions are 8.5x16.
I want to put some outlets in it…to charge batteries, run a microwave, some fluorescent lights, and run an air compressor. I am somewhat knowledgeable but….
My question to you. How do I get power into run the trailer assuming the source would be an external outlet, like temp power at a construction site.
My thoughts. An outdoor type receptacle on the outside of the trailer (just like an outside on a house). But, the receptacle would have to have prongs (male). This is because you would be using the female end of the extension cord to plug in. Is this possible, or do I need a ‘male to male’ extension cord?
Then from there, you run the wiring into a small breaker box…like with 4 circuits. Then just run the power around the trailer..
What do you think?
Thank you in advance.
akgillette1@comcast. is offline
Old 03-02-2008, 06:25 PM   #2
And also.....can I put a few batteries in line to run the lights off of when it's not plugged in?
Old 03-02-2008, 06:26 PM   #3
Just what I was thinking, but I would use a piece of SO type cord 25 or 30 feet long hard-wired to the small load center, that way you will always have a cord to plug in.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline
Old 03-02-2008, 06:27 PM   #4
threewire's Avatar
Your profile says your a general contractor, your best bet is to get your electrician to do it for you, they should be able to set you up something safe, effective, and easy to use.
threewire is offline
Old 03-02-2008, 06:29 PM   #5
Not Banned Yet
BryanMD's Avatar
You're on the right trail.
The issue is how much power the GC will let you tap.
Assuming (at best) he'll have the EC put another 2P breaker into his temp power panel for you then you would need to furnish a length of correctly sized wire to run from the panel to your trailer.
At the temp panel YOUR wire would get connected to the breaker.
At your trailer you connect it to your "sub panel" with all interior wiring in the trailer done as you desire/need. No plugs at either end.
OSHA and/or the county may have issues too (gfi etc).
At the next job though you may have to come up with another option.
March 2010: On the road with my RV. California is first primary destination then it is off to Eastern OR, Northern ID and Western MT for drycamping and fly fishing until Labor Day.
BryanMD is offline
Old 03-02-2008, 06:32 PM   #6
Thanks for posting on ElectricianTalk.com. The Moderators/Admin of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
As stated in the sign up page, ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries. Many of our professionals are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
Also you might want to register at www.contractortalk.com. Posting this in the electrical section is most likely not out of line. Most of us are members there as well.
Speedy Petey is offline
Closed Thread
General Trade Information eWa_9 General Electrical Discussion 1 06-11-2008 05:44 PM
Trailer Conduit Rack? Hotty Toddy Tools, Equipment and New Products 9 05-16-2008 03:03 PM
general help WalkOfDoom General Electrical Discussion 16 04-30-2008 07:26 PM
cali general electriician certificate jason007 General Electrical Discussion 3 03-05-2008 05:41 PM
UL General Guide aka UL White Book MDShunk Other Codes and Standards 0 01-14-2007 12:35 PM
