Old 04-23-2012, 11:29 AM   #1
Question GFCI's and neutrals.
Can one neutral 120v single phase be shared with two separate GFCI's on two separate 20 amp circuits?
I have installed this application and when trying to use the GFCI's they imediately trip. I am thinking that each GFCI needs it's own neutral and cannot be shared.
Thanks
99Kilowatt is offline   Reply With Quote
Old 04-23-2012, 11:35 AM   #2
NRA Member
backstay's Avatar
It depends.
When "deleted" called the Seals, they killed Bin Laden. When the Seals called "deleted", he denied them.
backstay is online now   Reply With Quote
The Following 2 Users Say Thank You to backstay For This Useful Post:
nolabama (04-23-2012), wildleg (04-23-2012)
Old 04-23-2012, 12:17 PM   #3
Angry
It depends.
10,000 comedians out of work and I have to listen to you.
Old 04-23-2012, 12:23 PM   #4
mbednarik's Avatar
it can be shared on the line side but not the load.
mbednarik is online now   Reply With Quote
Old 04-23-2012, 12:25 PM   #5
animal lover /rat bastard
wildleg's Avatar
read the following, it explains how they work, which should tell you why your gfis are tripping (maybe)
http://ecmweb.com/mag/electric_gfcis_work/
Old 04-23-2012, 12:34 PM   #6
976-EVIL
mcclary's electrical's Avatar
Ooops
Old 04-23-2012, 12:39 PM   #7
Chief Electron Relocator
This will not work:
You need to either separate the neutral after the first GFCI:
Or install a 2-pole GFCI breaker:
cultch (04-23-2012), wildleg (04-23-2012)
Old 04-23-2012, 12:54 PM   #8
A gfci receptacle is easy just don't connect the shared neutral to the load side of the gfci. If it is a mwbc and you are using GE panels then you can share the neutral at the panel otherwise you must use dp gfci. Ge will allow 2 sp gfci breakers- no other company can you do that.
Shockdoc (04-24-2012)
Old 04-23-2012, 12:57 PM   #9
1,000,000th Poster
Big John's Avatar
I sure wish someone would make a drawing explaining this.
-John
Big John is online now   Reply With Quote
Old 04-23-2012, 01:04 PM   #10
NRA Member
backstay's Avatar
-John
All these posts and my first one said it all.
Old 04-24-2012, 03:30 PM   #11
Thanks!
GFCI's on Fridge Seriously M7B General Electrical Discussion 17 01-25-2011 03:22 AM
Learned something new about GFCI's... Marshall175 General Electrical Discussion 27 05-16-2010 09:56 AM
Gfci's in garages. Rudeboy Residential Electrical Forum 60 01-18-2010 07:50 PM
GFCI's Absolutetruthz General Electrical Discussion 25 06-03-2008 06:21 AM
CopperWire GFCI's? YoungSparky General Electrical Discussion 8 05-24-2008 04:57 PM
