Old 10-05-2011, 07:25 PM   #1
Phosphate Coated as of 05
dronai's Avatar
Default Gfi receptacle with alarm
Service call today, had a Gfi receptacle with an alarm ! First time for me. How long has this product been out ?
Old 10-05-2011, 07:29 PM   #2
976-EVIL
mcclary's electrical's Avatar
Never seen one, but I've homemade them before. I used an icecube on load side terminals feeding a light.
Old 10-05-2011, 07:40 PM   #3
dronai's Avatar
I can't even find one online ? I will post a picture of it tomorrow.
Old 10-05-2011, 07:42 PM   #4
1,000,000th Poster
Big John's Avatar
Dronai, stupid question but are you positive it was a GFCI? I've seen surge-supression receptacles that had a buzzer built in but never a GFCI and I couldn't find it online, either.
Would be great, though. There've been a lot of threads here lately asking how you'd know if your GFCI failed where your fridge/sump pump was plugged in.
-John
Before posting, ask yourself "How hard would I get punched if I said this in person?"
Big John is online now   Reply With Quote
Old 10-05-2011, 07:51 PM   #5
goose134's Avatar
Yeah, I think Big John might be right. A lot of TVSS recepts have the alarm on them.
A professional in an amateur world.
Old 10-05-2011, 11:03 PM   #6
Registered Big Member
mxslick's Avatar
-John
Either that or it was a GFCI where the trip coil was buzzing...I've had that happen before.
Freshly manscaped for your motocross riding pleasure.
mxslick is offline   Reply With Quote
Old 10-05-2011, 11:08 PM   #7
Had a friend call me because her GFI sounded an alarm in the middle of the night. Turns out it was actually the room's smoke detector going off when the incorrectly pigtailed aluminum wiring behind it burnt out in the box... and the house was built a decade after Al wiring was made illegal. Ugh.
cguillas is offline   Reply With Quote
Old 10-05-2011, 11:28 PM   #8
1,000,000th Poster
Big John's Avatar
Originally Posted by cguillas View Post
Had a friend call me because her GFI sounded an alarm in the middle of the night....
Smoke alarm goes off and she thinks her receptacles are making the noise. I gotta ask, is she blonde?
-John
That's It? (10-05-2011)
Old 10-05-2011, 11:42 PM   #9
dronai's Avatar
I will take a picture tomorrow, when I return to find the ground fault. But it looked just like a standard gfi, with a deeper backing, and a small audio hole in the front corner for an alarm.
It's not this
http://www.amazon.com/Leviton-7280-W.../dp/B001FB64JE
Old 10-06-2011, 12:18 AM   #10
Little-Lectric's Avatar
They make a "freezer" alarm. Not sure if it is a GFCI receptacle or something added to alarm if power is lost to the freezer.
Little-Lectric is offline   Reply With Quote
Old 10-06-2011, 12:26 AM   #11
Heavily Armed Member
HARRY304E's Avatar
It's not this
That looks good..
Old 10-06-2011, 12:31 AM   #12
dronai's Avatar
This is in the bathroom. I also found another one somewhere else in the house.
Thing was tripped, and screaming ! Cut the line side, and It died. GFi is probably fine. I installed another, and it tripped as well. So their is a ground fault, I will have to go back and find tomorrow. Could be something getting wet in this rain.
Old 10-06-2011, 05:41 AM   #13
Nah, but I'll cut her some slack- getting woken up from a deep sleep only to have the thing stop before you even realise what went off would probably confuse me too.
The Following User Says Thank You to cguillas For This Useful Post:
Big John (10-06-2011)
Old 10-06-2011, 05:47 AM   #14
chicken steve's Avatar
jandjpoolspa.com/pdf/GFCI_Alarm_Systems.pdf
Old 10-06-2011, 06:40 AM   #15
976-EVIL
http://jandjpoolspa.com/pdf/GFCI_Alarm_Systems.pdf
Old 10-06-2011, 03:21 PM   #16
dronai's Avatar
This is a first for me.
Old 10-06-2011, 04:42 PM   #17
1,000,000th Poster
Big John's Avatar
I'll be damned. Who on earth makes that? Doesn't look like any of the big names.
-John
Old 10-06-2011, 06:21 PM   #18
dronai's Avatar
-John
I was able to pull the back off !
Old 10-06-2011, 06:43 PM   #19
1,000,000th Poster
Big John's Avatar
Looks like these are the only folks who make them. This will now be my standard answer to everyone worried about their fridge or pump being GFCI protected.
Great find.
-John
Old 10-06-2011, 08:00 PM   #20
mxslick's Avatar
dronai, you find the weirdest things!! Save that, I'd like to dissect it and see what failed.
fire alarm jpimentel84 General Electrical Discussion 6 11-01-2010 10:07 AM
PLC car alarm help RoryJ PLCs, VFDs, Motors and Controls 3 09-17-2010 02:54 AM
Fire Alarm horsegoer General Electrical Discussion 17 08-28-2010 10:55 AM
Fire Alarm jkwallz General Electrical Discussion 2 07-24-2010 07:55 PM
Fire Alarm walkerj General Electrical Discussion 15 04-17-2010 10:17 PM
