09-23-2011, 08:31 PM
The Grid as a Load Bank
Hey I just gave my generator a good hard load test. I went in parallel with POCO power by syncronising with a setup I made out of 4 120V incandescent lamps in series. After some fine adjustment to the governor and the field I got the lights to flash really slowly and when they went dark I closed the switch and adjusted the gov until I was pushing as hard as it would push.
I tweaked the timing and the mixture while watching the amp meter and I think I got close to another KW out of it.
You know this is better than a load bank, it's a shame I never thought of it before.
09-23-2011, 08:35 PM
1,000,000th Poster
Why wouldn't you just run the loads present in your house...?
-John
All generalizations are false, including this one.
09-23-2011, 08:41 PM
Registered Big Member
Most POCOs take a very dim view of unaccounted-for generation being tied into their system.
Not to mention that one hiccup on either end and you could have had generator shrapnel flying about.
As a very short term experiment, no harm no foul BUT you do need to be careful. The POCO grid can push back, hard.
Freshly manscaped for your motocross riding pleasure.
09-23-2011, 08:43 PM
I used to know an old electrician that worked on some large ships and would do the same with shore power until the power company came down on him hard. Being a government employee they just relocated him away from ships and onto a airfield.
09-23-2011, 08:45 PM
-John
Too hard to keep the house loads steady. Lots of stuff cycling on and off
09-23-2011, 08:50 PM
WTF I was trying to troll here and it backfired.
Although I have been present when that kind of thing has been done back in the day
09-23-2011, 09:00 PM
1,000,000th Poster
WTF I was trying to troll here and it backfired....
I wondered when I read the bit about the 4 lamps.
-John
09-23-2011, 09:01 PM
Any other of you guys prefer an analog meter for gen set work like a Simpson 210?
09-23-2011, 09:05 PM
-John
Oh, it can be done with 4 lamps in series when you want to paralell a couple of 240 V gen sets. although it is nice to have a second set hooked up so as one set goes dark, the other set gets bright. You never know when a bulb might fail using the dark only method.
09-24-2011, 12:23 AM
Exasperating Member
When I first read what you "did", I was  .
Then I thought, well cool idea with the lamps.
Just sounds crazy scary.
09-24-2011, 12:46 AM
I wish I could take credit for the lamp thing, But I read about it in a text book about 25 years ago. It was either an early edition of American Electrician's or else Electrical Machines Drives and Power Systems by T Wildi
