Ground bushings and ground locknuts? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-23-2010, 02:15 AM   #1
I saw a guy do it once.
SparkYZ's Avatar
Rewards Points: 506
Default Ground bushings and ground locknuts?
Ok, I'd like to clear up some rumors I've heardfrom various bosses. Here is what I've heard/what I know/what I do:
  • GEC armored cable, I always use a grounding locknut in the panel/service.
  • When using armored ground, and going into a concentric knockout, I use a ground bushing.
  • Conduit ground above 20A, grounding locknut, or a bushing in a concentric knockout.
  • I've heard concentric knockouts are suitable for 20A.
So, when do you use a locknut, when do you use a bushing, when do you not have to?
And one more question, I always use plastic bushings on any connector with 277V and above, and I've heard you use plastic bushings on 120/208 above 4000Watts....What are the rules for these?
SparkYZ is offline   Reply With Quote
Old 02-23-2010, 05:33 AM   #2
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,126
I hate to ask a stupid question, but what is a grounding locknut? Is it the same as a grounding washer? How are they both used?
I have only heard of, and used grounding bushings.
~Matt
Old 02-23-2010, 06:42 AM   #3
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,290
Its a locknut with a pointy set screw.
BTW, I dont use bond bushings on feeders.
Old 02-23-2010, 07:39 AM   #4
"Boozer"
Innovative's Avatar
Plastic bushing on any wires #4 or larger however we use them on any pipe 1" or larger
ground locknut.... hmm you mean a meg bushing???? If it is a meg bushing you are talking about, we use them on any metallic conduit with service conductors in them, but we still always run a grounding conductor in all conduits.
www.IEC-Electric.com
www.Hivoltage.biz
"The impossible, is usually the untried"
Innovative is offline   Reply With Quote
Old 02-23-2010, 07:51 AM   #5
jsb
Rewards Points: 154
i never use grounding bushings unless i have to. grounding locknuts are way easier.
jsb is offline   Reply With Quote
Old 02-23-2010, 08:36 AM   #6
Rewards Points: 358
You cannot insert a bonding conductor on a grounding locknut but you can in the grounding bushing.
Here is a grounding locknut.
Here is a grounding bushing
Old 02-23-2010, 02:24 PM   #7
"Boozer"
Innovative's Avatar
Wow, I have never seen a grounding locknut.......
www.Hivoltage.biz
Old 02-23-2010, 05:09 PM   #8
220/221's Avatar
Rewards Points: 3,564
In my 33 years working, I've never seen a grounding locknut either.
Code says bond bushing if concentric and over 250v to ground.
POCO here says bond bushing on locknutted rigid nipples if they contain service conductors.
Old 02-23-2010, 06:07 PM   #9
william1978's Avatar
Rewards Points: 2,000
Here we call them bonding locknuts and bond bushings.
Old 02-23-2010, 06:17 PM   #10
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
the better description for it's actual purpose
Old 02-23-2010, 06:17 PM   #11
Default Missed
These are great when you screw up and forgot. Or as they say up here "Pulled a Homer".
JohnSham is offline   Reply With Quote
Old 02-23-2010, 06:26 PM   #12
I have never seen one like that. How much does it cost compared to a regular bond bushing?
Old 02-23-2010, 06:30 PM   #13
Default Cost
I think it was 7,10,12,14, etc....1/2,3/4,1,etc..
I wish I would of known about these oh, 5 yrs ago. How many times have we all had to take the whole dag gone thing apart. Small price difference really.
I found these at http://www.seanelectrical.com/ under split collar ground choke.
Old 02-23-2010, 06:37 PM   #14
Just once here. Got really mad when I failed a inspection and haven't had a issue since. Sorta one of those bought lessons ya know.
Old 02-23-2010, 07:05 PM   #15
Default ?
Anymore, I don't assume I know anything. We had one Indian (Native that is) inspector made us put a grounding locknut and bushing?? That was an all day affair. We had to do an outage/reconnect on building. They were in the CT's. Another inspector made us put bonding bushings on the 1/2-1" EMT going into the main panels with the branch circuit wiring. Each had 4-8 circuits times about 7-10 conduits. Basically, most of day. If I had known about those bushings then that would of saved a boatload of money. Maybe 3 or 4 other times we had to do that over the years.
Old 02-23-2010, 07:12 PM   #16
The inspector made you put a bonding lock nut and a bond bushing on the same conduit?
Old 02-23-2010, 07:49 PM   #17
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
Good to see our friend from montana back around.
ďDammit, Smithers, this isnít rocket science, itís brain surgery!Ē
Old 02-23-2010, 08:56 PM   #18
Default Bonding
That job we went down to nebraska. He said in his county you needed a backup bonding system. The surface area of the set screw was small and more prone to corrode. With the additional bonding bushing with twice as many threads and the bonding jumper you would have more bonding "Backup" is what he said. We just did what he said so he would pass us. Never heard of it since. I guess that was one of those Shirt Pocket inspectors you all talk about.
Well, I won't be doing as much electric now. It's onion season coming up. I need to get the fields ready for the spring onions.
Old 02-23-2010, 09:14 PM   #19
Rewards Points: 5,198
Default Bushings
What if they are EMT nipples?
Old 02-23-2010, 09:26 PM   #20
Default Bushings
I think you are right; They are for BONDING, not grounding.
How does the ground actually act as a ground? foolios General Electrical Discussion 90 09-13-2014 09:00 PM
To ground or not to ground? delsol Linework 13 03-29-2010 06:13 PM
50 Volts Neutral to Ground and 50 Volt Hot to Ground... DarkDune Residential Electrical Forum 6 06-25-2009 09:56 PM
No Ground? I Wonder why? drm General Electrical Discussion 4 02-01-2009 08:21 PM
Ground or not to ground? chenley Services and Service Equipment 5 05-06-2008 11:38 PM
