Ground clip installation - Electrician Talk - Professional Electrical Contractors Forum
Old 07-25-2009, 04:32 PM   #1
Chris Kennedy's Avatar
Rewards Points: 2,000
Default Ground clip installation
Does anyone have a picture or better yet a manufactures installation instructions for these?
Thanks
Bulldozers and Dirt
Old 07-25-2009, 04:35 PM   #2
drsparky's Avatar
Rewards Points: 312
What type of ground clip are you asking about?
Old 07-25-2009, 04:36 PM   #3
Rewards Points: 356
Here is what a found after a quick search-- now do your own dirty work.
Ground Clip, Side Mount, For Grounding #14 to #10 AWG Wire to Side of Box, Length 0.5 In, Width 0.5 In, Depth 0.5 In, Material of Construction Steel, Standards UL
Old 07-25-2009, 04:39 PM   #4
Rewards Points: 356
Try the raco site
Old 07-25-2009, 04:44 PM   #5
Yeah, thats what I'm looking for. What search words did you use, I tried 'ground clip installation' on google and got squat. Thanks for the little picture that old guys can't see.
Does anyone know who makes them?
Bulldozers and Dirt
Old 07-25-2009, 04:47 PM   #6
Rewards Points: 356
Race 975 that I linked to in the first post.
Here is a better image. I went to google and then choose image from the menu at the top and then typed in ground clip. The last picture I typed ground clip installation
Old 07-25-2009, 04:52 PM   #7
Thats it, perfect thanks. The reason I asked is today I noticed that two of my guys installed them two ways different than shown above. One looked like it was beaten onto the box with a shovel.
Bulldozers and Dirt
Old 07-25-2009, 05:18 PM   #8
Rewards Points: 356
That's what happens when Al has to work indoors. Any reason you didin't use ground screws. I have a nice set of bits that drill and tap (one bit) that is perfect for this. Plumber even borrowed it the other day.
Old 07-25-2009, 05:22 PM   #9
Rewards Points: 3,855
I even bought a special box of 8-32 green ground screws, since the ground screw holes in the old black boxes were tapped at 8-32 (if they had a tapped hole). If not, I use the Dtapkit too. I haven't used a ground clip in probably 10 years.
Old 07-25-2009, 06:22 PM   #10
Rewards Points: 2,002
I bought one of those little packages of six they sell at HD and Lowes. Since on average I use one every few years, I think I'm good for the next decade or so.
Old 07-25-2009, 06:56 PM   #11
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
That is nice.
Replies based on NEC 2014
Old 07-25-2009, 06:57 PM   #12
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
I use the ground clips a lot. I keep them in my pouch with the staples and ground screws.
Old 07-25-2009, 08:37 PM   #13
Rewards Points: 1,000
I haven't used a ground clip in forever, but I still run into them. I like that set of drills and tap combinations. Do they handle the torque from a driver okay?
I have a hand tap that has all the common sizes, fine and course, on two ends. It fits into a driver handle. I just broke the tip tapping some old Steel City boxes which had #8, untapped holes.
I use screws.
Old 07-25-2009, 10:57 PM   #14
I'm rewiring an install done in 1981. EMT and 1900 boxes shot to a concrete ceiling.
I don't care for them but I have little choice for this install.
Bulldozers and Dirt
Old 07-25-2009, 11:11 PM   #15
I own stock in FotoMat!
Rewards Points: 6,520
Here's another:
Old 07-25-2009, 11:25 PM   #16
JohnJ0906's Avatar
If you are not careful, you can snap them, especially the smaller sizes. Luckily, they can be purchased separately.
John from Baltimore
"One day at a Time"
Old 07-25-2009, 11:25 PM   #17
Here's another:
Still a little small. I want to print something that shows the teeth on the outside of the box, the wire in the slot for the wire and the pigtail facing into the box. A picture is worth...... when there is a language barrier.
Bulldozers and Dirt
Old 07-25-2009, 11:26 PM   #18
Or spread them until they are useless.
Bulldozers and Dirt
Old 07-25-2009, 11:34 PM   #19
Sorry, that and the one already posted is all I have in my arsenal. What's wrong with just showing them with your own hands & tools?
........ One looked like it was beaten onto the box with a shovel.
No digging for Al today?
Old 07-25-2009, 11:56 PM   #20
I'm losing my patience, tired of repeating myself, looking to post pictures around the job sites. Its not just this issue, many others. If we strapped MC at 1' and 4' on the last job, why would you think its OK to strap at 2' and 6' on this job. I could go on and on. Burned out.
Bulldozers and Dirt
Lightning Rod Installation? Jeff000 General Electrical Discussion 22 11-12-2009 10:47 AM
50 Volts Neutral to Ground and 50 Volt Hot to Ground... DarkDune Residential Electrical Forum 6 06-25-2009 09:56 PM
Leather tape measure clip dognutz12 Tools, Equipment and New Products 7 03-30-2009 09:49 PM
tape measure clip dognutz12 Tools, Equipment and New Products 12 05-07-2008 07:00 PM
Ground Fault Installation brian john Code Violation Discussion 4 05-29-2007 11:57 PM
