Old 04-02-2008, 08:41 PM   #1
Default grounding
From time to time at shop where I work Im requested (by mach. Tech)to install a ground rod next to a piece of equipment (metal working mach.,mill) and ground control cabinet to it(this is to disipate static elec.believed to be problem w/cnc equip.),even though mach. is grounded at busway.Wouldnt this be incorrect to add g rod ? sorta like a sub panel with being tie in to a seperate g rod
stillirnin is offline   Reply With Quote
Old 04-02-2008, 08:49 PM   #2
nope....................... Meaning no ground rod.
bobelectric is online now   Reply With Quote
Old 04-02-2008, 08:53 PM   #3
thanx Ive always been curiuos about this situation. is there anything I could find this under in nec bobelec
Old 04-02-2008, 09:06 PM   #4
All this secret seperate grounding isolated dedicated circuit stuff never proved to me that if isolated grounding doesn't go to central point you'all get noise,ect.
Old 04-02-2008, 09:10 PM   #5
JohnJ0906's Avatar
See 250.54
Legal, but IMO unnecessary.
I think this is what Brian calls "voodoo grounding"
John from Baltimore
"One day at a Time"
Old 04-02-2008, 09:13 PM   #6
Look ,Man,N.E.C. art.250.One ground point out of many possibie choices.They all must go to it.
Old 04-02-2008, 09:23 PM   #7
and that isolated ground wire we had to pull always went back to the main ground point.
Old 04-02-2008, 10:34 PM   #8
chenley's Avatar
Installed a CNC setup at a machine shop about a year ago. The specs for the machine required (2) ground rods at a minimum of 25' from the machine, with both ground rods separated by 6' of course. I definitely didn't want that piece of equipment damaged in anyway by my installation, who knows how much that would cost.
Old 04-03-2008, 10:41 AM   #9
Ax grinder
raider1's Avatar
You are permitted to install a supplementary grounding electrode (Ground rod) for a piece of equipment and connect this GE to the equipment grounding conductor or the frame of the equipment. See 250.54.
This grounding electrode can't be installed in place of an equipment grounding conductor though.
Chris
Old 04-03-2008, 07:26 PM   #10
JohnJ0906's Avatar
When something like this is in the instructions, it is probably best to do it. If, God forbid, something happens, I could very well see the equipment manufacturer not honoring the warranty.
"See, the ground rods weren't installed, it's the electricians fault!"
CYA.
John from Baltimore
"One day at a Time"
Grounding panels.. waco General Electrical Discussion 42 12-19-2009 05:07 PM
Grounding jdeihs NEC Code Forum 3 08-24-2008 12:30 AM
Grounding? calimurray NEC Code Forum 13 04-29-2008 02:56 AM
parallel grounding rst34 General Electrical Discussion 4 11-16-2007 06:23 PM
Grounding foundation calimurray General Electrical Discussion 1 11-15-2007 06:33 AM
