07-06-2011, 12:47 PM
Hanging ceiling fans.
Just got a call from nursing home to install ten ceiling fans in their hallways, all drop ceilings. Someone else had installed some before, fans were mounted to a 2x4 sitting on tile. I informed that that we had to hang the new fans more securely. I planned on threaded rod, from either beams or strut. Do you think 1/4 rod enough or should I use 3/8?
07-06-2011, 01:19 PM
976-EVIL
How long will the rods be?
07-06-2011, 01:30 PM
Are you stuck on allthread? If not here is a good option the turnbuckle allows for easy adjutment.
07-06-2011, 03:27 PM
Rewire's suggest gadget is also made by Arlington Industries.
07-06-2011, 03:53 PM
The length of rods would be 24". But i definetly like the arlington system. Looks a whole lot quicker. Thanks guys.
07-06-2011, 04:02 PM
24" is a bit long unless you have stabilizer bars at the grid. Also, be sure the ceiling wires are plentiful if you decide to hang them from the grid.
07-06-2011, 05:24 PM
Hanging a fan from just the grid bars is NOT an option.
Time flies when you're goin' fast.
The Following User Says Thank You to Speedy Petey For This Useful Post:
07-06-2011, 05:30 PM
I remember doing the 2x4 across the main grids 30 years ago and they are still their.
The Following User Says Thank You to Mr Rewire For This Useful Post:
07-06-2011, 05:37 PM
That does not make it compliant. I say a ceiling fan hung from a pop in box and it lasted for years-- so what.
07-06-2011, 06:09 PM
I think that the plywood installation is the most secure method.
A piece of plywood 2x2 or 2x4, layed right on top of the tile. There is about 1/2" of grid above the tile and the ply sits snugly. Screw it to the grid if you are so inclined. Bolt a fan/pan thru the ply and throw on a support wire to stay legal.
That space is designed to hold a troffer, it will hold a fan.
07-06-2011, 06:14 PM
Did i say anything about compliant? You tying to stir up trouble?
07-06-2011, 06:16 PM
Plywood lacks grid clips like a troffer would be the only problem I see
07-06-2011, 06:20 PM
ET Road Warrior
I know about code compliant.. but if I can put (4) layin fixtures in a ceiling without any problem with the amount of weight.. then a ceiling fan should have no problem being supported by the same grid using the right hardware..
07-06-2011, 06:23 PM
With a fan the weight is in one spot but with troffers the weight is dispersed.
07-06-2011, 06:30 PM
ET Road Warrior
I agree.. better to use chain and strut to make it to code ..
07-06-2011, 06:52 PM
Get a kit, follow the directions, cya. Pretty simple.
07-06-2011, 06:56 PM
That's the beauty of plywood.
07-06-2011, 06:58 PM
#18
No just trying to get you to give compliant info. Anyone can offer non compliant means.
07-06-2011, 07:08 PM
#19
Can't Remember
You have to support and clip the troffer too. Whats the difference?
