Heat tape on fuel line - Electrician Talk - Professional Electrical Contractors Forum
Old 10-12-2013, 08:14 AM   #1
Rewards Points: 14
Default Heat tape on fuel line
Have a customer with an outside oil tank. The line that goes into the house occasionally freezes when temps reach 0. All of the heat tape I have come across says water line only not for fuel or gas. Any ideas?
oakleyrdc is offline   Reply With Quote
Old 10-12-2013, 08:16 AM   #2
BBQ
Salty Member
BBQ's Avatar
http://rolliesystems.com/lineheater.pdf
The Following 2 Users Say Thank You to BBQ For This Useful Post:
guest (10-12-2013), oakleyrdc (10-12-2013)
Old 10-12-2013, 09:44 AM   #3
Service Call's Avatar
Rewards Points: 6
You can count on BBQ to provide.
The Following User Says Thank You to Service Call For This Useful Post:
hardworkingstiff (10-12-2013)
Old 10-12-2013, 09:55 AM   #4
Rewards Points: 77
I have a diesel tractor that is stored outdoors all the time in Pennsylvania. I use a supplement added to the fuel to prevent jelling during the winter. Actually I use it year around and have never had a problem. Only takes a few ounces. I am not sure if they use it in home fuel oil tanks, maybe check with the fuel supply people on adding something to prevent jelling. Also posted a link to what I use. I get it at a truck stop. Just an idea for ya.
http://www.powerservice.com/dfs/
CyberKnight is offline   Reply With Quote
The Following User Says Thank You to CyberKnight For This Useful Post:
Old 10-12-2013, 10:00 AM   #5
Rewards Points: 2,310
Thermon BSX line would work.. Raychem BTV would also work.. Just get the right power and end kits, wire it up with a GFI breaker and you won't freeze...
The Following 2 Users Say Thank You to glen1971 For This Useful Post:
Celtic (10-12-2013), oakleyrdc (10-12-2013)
Old 10-12-2013, 10:07 AM   #6
Rewards Points: 14
Originally Posted by CyberKnight
I have a diesel tractor that is stored outdoors all the time in Pennsylvania. I use a supplement added to the fuel to prevent jelling during the winter. Actually I use it year around and have never had a problem. Only takes a few ounces. I am not sure if they use it in home fuel oil tanks, maybe check with the fuel supply people on adding something to prevent jelling. Also posted a link to what I use. I get it at a truck stop. Just an idea for ya. http://www.powerservice.com/dfs/
She says that she already uses an additive. I guess one of the problems was when it was installed the line should have been coming out of the top of the tank rather then the bottom. I was told that sediment on the bottom will get into the line and mixed with the cold weather could cause a very thick gel.
Old 10-12-2013, 10:20 AM   #7
Rns
Rewards Points: 29
http://www.emersonindustrial.com/en-...s/default.aspx
Rns is offline   Reply With Quote
The Following User Says Thank You to Rns For This Useful Post:
Old 10-12-2013, 10:27 AM   #8
Rewards Points: 77
Yep on the sediment problem. I have seen some home fuel oil tanks with a filter at the tank but those are basement tanks. With it outside does not help with the cold and fuel oil jelling. I do not work on those systems only engines but its the same fuel more or less with the same cold problems. Maybe a good filter/ water separator at the tank plus additive may help. The filter/separator usually have a little drain in the bottom of the filter to drain crap out every once in awhile.
I would talk with the oil delivery people about it. Heat tape may help if ya can get the whole line wrapped, it only takes one little spot to plug things up.
Good luck hope ya figure it out for her.
Old 10-12-2013, 10:30 AM   #9
BBQ
Salty Member
BBQ's Avatar
Don't re-invent the wheel, use a product designed to work with home heating fuel oil tanks.
glen1971 (10-14-2013), hardworkingstiff (10-12-2013)
Old 10-12-2013, 12:14 PM   #10
s.kelly's Avatar
Originally Posted by BBQ View Post
They said that heating oil can gel in temperatures as "high as 10 degrees". I realize that in some parts of the country as HIGH as makes sense. But it sounds funny from the south. 10 degrees makes the news here.
s.kelly is offline   Reply With Quote
Old 10-12-2013, 08:42 PM   #11
Rewards Points: 926
Most any of the industrial grade, oil resistant HEAT TRACING should work for this application. You would need to add an line voltage, ambient sensing thermostat. Yes, put this on a GFI circuit.
240v line to line,line to nuetral Quiksilver22 General Electrical Discussion 36 10-11-2013 09:19 PM
NYC New Subway Line Being Built (new 2nd ave line) 360max Off Topic (Non Trade) 7 03-26-2013 09:15 PM
Line to line or line-line-ground m sleem NEC Code Forum 4 06-27-2012 11:55 PM
frost protection/heat tape chrisg UK Electrical Forum 18 11-10-2009 10:46 PM
pipe frost protection/heat tape chrisg General Electrical Discussion 0 11-03-2009 01:19 PM
