Old 09-22-2008, 08:09 AM   #1
Default The holes in the prongs of a male attachment plug
A customer asked me why there are those 2 holes in the prongs of the male 15 amp plug, and why do some not have them? Is there a real answer to this question? I had to say "I don't know"
bcsparks4 is offline   Reply With Quote
Old 09-22-2008, 11:49 AM   #2
Seen your member
  • If you were to take apart an outlet and look at the contact wipers that the prongs slide into, you would find that they have have bumps on them. These bumps fit into the holes so that the outlet can grip the plug’s prongs more firmly. This detenting prevents the plug from slipping out of the socket due to the weight of the plug and cord. It also improves the contact between the plug and the outlet.
  • Electrical devices can be "factory-sealed" or "locked-out" by the manufacturer or owner using a plastic tie or a small padlock that runs through one or both of the prong holes. Construction projects or industrial safety requirements may require this type of sealing. For example, a manufacturer might apply a plastic band through the hole and attach it to a tag that says, "You must do blah blah blah before plugging in this device." The user cannot plug in the device without removing the tag, so the user is sure to see the instructions.
  • There also is a small savings in raw materials (metal) for the manufacturer of the actual plug prong. Every little bit helps!
Old 09-22-2008, 12:54 PM   #3
Default holes in the prongs
I believe the holes in the prongs of the & female caps are there for a testing company such as UL to randomly put a pull test on the cap to see if it meets their standard and receives their listing.
Joe Penachio is offline   Reply With Quote
Old 09-22-2008, 03:00 PM   #4
Podagrower's Avatar
I thought it was for hooking up the stripped out 14G romex.
http://joecartoon.atom.com/cartoons/channel/6-
press_n_splode/page/2/order/rating
Bring back the classics........
Podagrower is online now   Reply With Quote
Old 09-22-2008, 03:03 PM   #5
Seen your member
Why limit it to just 14?
Old 09-24-2008, 11:24 AM   #6
According to NEMA WD-6 (page 17), the standard for dimensional standards for wiring devices, the holes are optional and are intended for manufacturing purposes only.
ssdd is offline   Reply With Quote
Old 09-24-2008, 04:38 PM   #7
HAHAHAHAH gezz, I HAVE watched some workers from south of the border do that crap....
All_amped_up is offline   Reply With Quote
Old 09-24-2008, 08:03 PM   #8
Seen your member
The holes also make it easy to attach zip/lamp cord as well.
Old 09-24-2008, 09:16 PM   #9
mattsilkwood's Avatar
the only thing i see is they forgot the tape
mattsilkwood is online now   Reply With Quote
Old 09-24-2008, 09:21 PM   #10
Seen your member
It's stealth tape, product of the Reagan years. You can't see it, but trust me, it's there....
Old 09-24-2008, 09:30 PM   #11
thats too funny does that stuff work on motor leads?
Old 09-24-2008, 09:46 PM   #12
Seen your member
It works on anything. Bet ya didn't notice that F101 parked in your driveway....
Old 09-25-2008, 06:30 PM   #13
Podagrower's Avatar
Allright, how about we use the hole in the prong for a screw and nut. Then we could use sta-cons on the wire.
30 year old male in need of some guidance... tony8404 Introductions 11 10-26-2009 04:45 PM
What male plug to use ? Seattle John Introductions 3 10-31-2008 10:47 PM
Drilling holes... twintask Tools, Equipment and New Products 28 04-07-2008 10:31 PM
Receptacle Prongs HOYTUSA General Electrical Discussion 14 04-02-2007 11:51 PM
Working around the need for big holes itsunclebill Code Violation Discussion 3 01-21-2007 12:55 PM
