Old 09-25-2011, 11:32 PM   #1
Default Home Inspection.
Hi,Guys. I got a call from a customer who wants me to go do an inspection.The house got hit with lightning,so she contacts the insurance company.They instruct her to contact an electrician to make sure everything is ok.what exactly should I be inspecting?Im thinking on doing a panel check,checking grounding with a ground meter and voltages at all receps ect.Any suggestions will be helpful thanks again.
knowledge29 is offline   Reply With Quote
Old 09-25-2011, 11:35 PM   #2
Cletis's Avatar
Default Meg
Meg the whole house.
Old 09-25-2011, 11:58 PM   #3
Heavily Armed Member
HARRY304E's Avatar
Check for damage all over the house take out receptacles and inspect them same with switches and lights.
Old 09-26-2011, 09:19 AM   #4
This is a can of worms due to the danger of insulation damage to wires hidden in walls.
__________
Was born in HACKensack, NJ
CraigV is offline   Reply With Quote
Old 09-27-2011, 01:17 AM   #5
Exasperating Member
JohnR's Avatar
Remove all GFCI's before megging, also make sure everything is unplugged.
Old 09-27-2011, 06:14 AM   #6
chicken steve's Avatar
& shut off all the afci's
Old 09-27-2011, 06:56 AM   #7
976-EVIL
mcclary's electrical's Avatar
That's what a meggers for
You can't meg terminated wires. This is a common request from insurance companies dealing with lightning strikes. Every wire in the entire house must be megged.
Old 09-27-2011, 06:59 AM   #8
Fried Bologna um um good!
jwjrw's Avatar
Most all the insurance companies I have dealt with want you to visually inspect the panel and devices. I have yet to have an insurance company want the wiring meggered for a lightning SURGE which is what usually happens. Direct hits they usually require circuit meggering.
Old 09-27-2011, 08:11 AM   #9
Most insurance companies call because the homeowner has made a claim on damaged appliances. You can ring the crcuits affected and visually inspect the devices.
As for megging try this experiment. take a peice of romex 12/2 and meg it now lay a short section out flat and take a blow tourch to it until the coating is completly removed allow it to cool and the meg it again.
Mr Rewire is offline   Reply With Quote
Old 09-27-2011, 11:44 AM   #10
Phosphate Coated as of 05
dronai's Avatar
Rewire, I'll buy your megger
Old 09-27-2011, 11:49 AM   #11
HARRY304E's Avatar
How much are you willing to spend i can get you a real good one...
Old 09-27-2011, 12:14 PM   #12
dronai's Avatar
Originally Posted by harry304e View Post
how much are you willing to spend i can get you a real good one...
$10.00 !
Old 09-27-2011, 12:34 PM   #13
HARRY304E's Avatar
$10.00 !
$1,000?
Old 09-27-2011, 02:14 PM   #14
dronai's Avatar
Originally Posted by HARRY304E View Post
$1,000?
Joking, I sent you a PM
10 Surefire Ways to Fail a Home Inspection Magnettica General Electrical Discussion 7 08-22-2011 10:19 PM
Home electrical inspection check list wirenuter Business, Marketing, and Sales 3 05-25-2011 08:17 AM
Home Depot and the Home improvement Hack B4T General Electrical Discussion 180 12-31-2009 04:03 PM
Home Inspection Check List Amp1906 Business, Marketing, and Sales 1 12-21-2009 03:18 PM
Home inspection nightmares tr_rooster Code Violation Discussion 6 06-12-2009 04:13 PM
