Hooking Up A Two Phase Switch - Electrician Talk - Professional Electrical Contractors Forum
Old 11-30-2008, 08:33 PM   #1
Golden Arc's Avatar
Rewards Points: 160
Default Hooking Up A Two Phase Switch
Has anybody ever hooked up a two phase switch?
We are hooking up an exhaust fan which is located on the roof with a tank located below in a class room so a science class can do experiments. The switch is located in the class room on the tank and it has a line 1, line 2 and a t1. Weve hooked it up every possible way and nothing works. There are two fans in two class rooms and the other fan we just took the switch out and put a regular single pole switch in and it worked.
By the way the people that installed the thing took the manual with them.
Golden Arc is offline   Reply With Quote
Old 11-30-2008, 08:44 PM   #2
Speedy Petey's Avatar
Rewards Points: 2,258
Tim, what is a "two phase switch"?
Old 11-30-2008, 09:52 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
By his use of Line 1, Line 2 and T1, it sounds like it's a 3-way switch, only instead of sending one source of power over two terminals, it uses 2 terminals to toggle a load between two sources of power.
Tim, does the switch have an "On Off" or "O l" marks on it?
Old 11-30-2008, 10:01 PM   #4
? There is no such thing as a "2 Phase switch". You mean 2 pole? Line 1 and 2, power. T1 ground? I'm assuming the motor in the exhaust is 208/240 vac? Does the switch have 5 terminals? Our does it have 6 for ground? Need more info bud.
Lectritian is offline   Reply With Quote
Old 11-30-2008, 11:19 PM   #5
nap
a real PITA
sounds like maybe he has a manual motor starter.
Tim, give us the manuf and the model number of whatever it is you are using as a switch.
If anybody is wondering, this is what I suspect Tim may be talking about.
Old 12-01-2008, 05:46 AM   #6
calimurray's Avatar
Rewards Points: 250
Send a message via Yahoo to calimurray
yeah we use them all the time there double pole single throw switches , we use for disconnects and for lighting circuits.
Does it look like a four way switch but it says on and off the switch.
calimurray is offline   Reply With Quote
Old 12-01-2008, 05:04 PM   #7
Golden Arc's Avatar
Rewards Points: 160
It has an on and an off. It looks like what is pictured, im not sure of the manufacturer i would have to look like I say the manual has disappeared. If its supposed to work like a three way switch this still doesn't explain why a single pole switch doesn't work when we replaced the other one. Like I say there were two and the other one we just swapped it with a single pole switch since theyre not going to be using all the other controls but the fan on the equipment and it worked fine. The single pole switch worked and its hooked up exactly like this one.
Old 12-01-2008, 05:06 PM   #8
What's the voltage you're switching?
If it has on/off on it, then it's not a three-way. Sounds more like a 2-pole switch, and you're controlling 208, 240 or 480 volts.
Old 12-01-2008, 07:05 PM   #9
Golden Arc's Avatar
Rewards Points: 160
120. Yeah its not a toggle its either on or off no middle position.
Old 12-01-2008, 07:18 PM   #10
So there's only two wires to connect? Then that's why a regular toggle switch worked..... you're doing the same thing a standard switch does for lights in a home....turning it on and off.
As to why you are using such an 'exotic' switch like the one you describe is beyond me. Unless that's all they had on the truck, so that's what was left for you.
Old 12-01-2008, 07:47 PM   #11
nap
a real PITA
You're kidding, right? Seeing that this is a permanent install, there is to be overload protection so if it is not within the motor, the manual motor starter with overloads is required.
Tim did state it looks like the pic I provided. If so, I suspect the thermal is not installed or he may be not connecting it correctly. Here is a link that shows how these are connected. scroll to page 4. If yours is a 2 pole switch and you are runnning 120 volt, you would use the pic laleled: 2 pole. You do have to have the correct thermal unit though. The thermal mounts on the two screw holes (screws are with the thermal unit) on the left hand side of the switch in the pic
http://ecatalog.squared.com/pubs/Mot...2510CT9701.pdf
Old 12-01-2008, 08:48 PM   #12
Originally Posted by nap View Post
You're kidding, ....
Lessee.... 120v load. Switch marked 'On & Off' on it. Kinda sounds like a toggle switch, doesn't it? Tim says he put a standard toggle in, and it worked.
No, not kidding.....
Old 12-01-2008, 11:14 PM   #13
nap
a real PITA
sure, it will work but it isn't right. He stated the pic I posted was what the electricians installed. I would suggest if they installed a near $100 manual motor starter, there was a reason for not installing the $2 toggle switch.
There be rules we follow and an overload on a motor be one of them.
Is there some reason you believe a starter with overloads is not required here?
Old 12-02-2008, 05:28 AM   #14
Mountain Electrician's Avatar
Rewards Points: 238
Sounds like you have a 1 pole manual starter w/o the overload installed. Maybe a toggle switch is fine, maybe not. Read NEC 430.32 which tells you about overcurrent protection for continuous duty motors.
Old 12-02-2008, 04:18 PM   #15
Ok, for the record, it's an exhaust fan. Which kind is it? (since I don't see anywhere in the thread it's been revealed) Let me know which one it is:
A:
B:
C:
Old 12-02-2008, 04:34 PM   #16
Golden Arc's Avatar
Rewards Points: 160
A:
B:
C:
The type of exhaust fan is B although there is no switch or receptacle on the side like that one. We havent been able to fool with it in a couple of weeks because its in a class room where they are still conducting class. I believe ive told you wrong the switch we replaced it with was just a normal three way because I was thinking about it and there are two switches that control the fan one on each side. I might also add that they replaced the fan and it wasnt the motor.
Old 12-02-2008, 05:53 PM   #17
nap
a real PITA
code
over 1 hp;
requires one of the following.
seperate overload
thermanl protection
integral protection
under 1 hp if permanently installed 430.32 D- refers back to 430.32 B
under 430.32 B, one of the following
seperate overload
thermal protection
integral protection
impedance protected.
so, unless this is a little fart fan (which is impedance protected), which I doubt (and has been confirmed),since this is a school science classroom, it has to have protection. Unless it is internal, the motor starter I posted is what is typically used. Since the electricians did leave this much higher cost than a toggle style switch, I suggest it is wht is needed in this app.
Every school I have worked on used a mushroom style ex fan for the science classrooms so I was guessing this was the type of fan we were dealing with from the beginning where Tim said it was a science classroom.
So, with Tims last post, it appears that the room has two switch stations to control the fan. If this is the case, there is a bit of a problem because to do this, you would need a magnetic starter with the swithes as control switches. (presuming the overloads are needed in this app)
So Tim, it's up to you. You need to tell us if there is integral protection in this motor and if so, is it simply internal thermal protections or is it a thermal protection that runs the "P" labeled leads into the peckerhead.
If the latter, you can use those and a magnetic starter or ignore them and use a system like the electricians left.
If there is simply internal thermal protection, you can get away with horsepower rated switches (switches used for this purpose MUST be HP rated for the motor being controlled. It will state it right on the switch if it is rated) and get rid of the unit the electricians left.
So, once we know something about the motor, we can work on the two station starting.
Old 12-02-2008, 10:54 PM   #18
220/221's Avatar
Rewards Points: 3,564
Yeah...that^
Are there a couple of threaded open holes on the side of the switch
Old 12-03-2008, 08:27 PM   #19
I ran into two-phase several years ago. An old time motor winder told me that two-phase is actually two different circuits, like two coils. One set of leads will have a different voltage than the other, and you should be able to ring the two "circuits." That's all I remember about it, and glad I forgot the rest!
Uncle Jim 725
Unclejim725 is offline   Reply With Quote
Old 12-03-2008, 09:05 PM   #20
Golden Arc's Avatar
Rewards Points: 160
code
over 1 hp;
seperate overload
thermanl protection
integral protection
seperate overload
thermal protection
integral protection
We kind of put this on the back burner so I cant really dont have time to go back and look at it for awhile. Not sure about the thermal protection, I believe the same set up was on the motor T1, T2, and P. I do remember it was multi tap 120/277. What would bet the neutral in this case P? Thats how we hooked it up.
2 phase elevator switch bigredc222 Vintage Electrical 25 09-08-2009 08:39 PM
Replace a 2 way switch by time lag switch emleray General Electrical Discussion 4 09-12-2008 04:18 PM
three phase to single phase convertion. brick General Electrical Discussion 2 07-29-2007 07:55 PM
question about hooking up a Generator? aarons600rr General Electrical Discussion 1 04-17-2007 07:16 PM
two phase or single phase jorge General Electrical Discussion 9 03-27-2007 01:06 PM
