Old 06-11-2008, 09:22 PM   #1
Default Hot leg removal in a CT
I have a FSS and a panel that need to be replaced and are fed directly from a CT. I have already been given permission from BGE (local provider) to remove the hot legs and they are easily accessible. What tools are needed to do such a job? Tried to attach pic but my jscript driver has a bug.
skid is offline   Reply With Quote
Old 06-11-2008, 09:28 PM   #2
JohnJ0906's Avatar
FSS?
By the way, welcome to the forum! What part of Bawlmer are you from?
John from Baltimore
"One day at a Time"
Old 06-12-2008, 06:12 AM   #3
Originally Posted by JohnJ0906 View Post
FSS?
Only thing I could come up with is Fusible safety switch (let me know if I win and what I won)
wirenut1110 is offline   Reply With Quote
Old 06-12-2008, 07:18 AM   #4
JohnJ0906's Avatar
OK, that would make sense.
You win one free month membership here at ElectricianTalk!!!!
John from Baltimore
"One day at a Time"
Old 06-12-2008, 04:53 PM   #5
Default but seriously though . . .
I live in Catonsville.
Are there tools that are 'hot tools' rated for 'hot' work or with insulation that would allow me to remove these hot legs from the CT, or is the general consensus to have the local provider conduct the work?
Old 06-12-2008, 04:55 PM   #6
Yes FSS stands for fused safety switch, sorry for the unknown abb.
Old 06-12-2008, 05:06 PM   #7
Not Banned Yet
BryanMD's Avatar
I can't imagine any safe way (even with PPE) that I'd want to be doing that live.
410-685-0123
You might use this as an opportunity to sell them on a MAIN disconnect as part of the job. If you do that and plan it well by mounting that MDS first... the shutdown time could be reduced to a minimum. Then do the FSS and and MBP.
Too damned many acronyms flying around. LOL
March 2010: On the road with my RV. California is first primary destination then it is off to Eastern OR, Northern ID and Western MT for drycamping and fly fishing until Labor Day.
Old 06-12-2008, 05:18 PM   #8
nap
a real PITA
not sure what the heck you are doing there. call the POCO and have them pull the cutouts or if a pedestal transformer, pull the fuses on it. No reason to do it hot.
If you do not have the tools to pull, and reset the cutouts, don;t mess with the thing. Depending on if the cutouts are on the high side or if there are low side cutouts, would make a diff what voltage rating the hot stick would have to be
If you have ever seen a fuse blow in a cutout, you would understand one reason you do not want to do this unless trained.
Old 06-12-2008, 07:52 PM   #9
Local guy also, GET BG&E to PULL THE POWER>>>>>>
They do it for us all the time.
You screw up with the CT's there are multiple problems not just the obvious electrical hazards involved with the phase conductors.
Old 06-12-2008, 09:21 PM   #10
nap
a real PITA
worst case scenario (other than death)
you short out a phase and take half the city down.
Old 06-12-2008, 09:42 PM   #11
Good idea on the Main Disco pitch. Thanks for all the feedback. I figured getting BGE involved was going to be the way to go. No sense saving the customer money if I'm dead. Now I just need to get a proposal together. Thanks again I really appreciate the input.
