Old 03-03-2010, 10:39 PM   #1
charlie Bob's Avatar
Default hot tub disconnect.
It's been a while since my last tub.(maybe 4 months, yeah, i forget easily)
I cant find the requirement forbidding disconnect being less than 5' from hot tub. Inspector says it'll be ok if i put closer than 5', but i thought there's was something about it in the NEC.
I may be confuse with the emergency shutt off requirement.
Disconnect i'm talking about is on of them Hot tub disconnect with the 50 amp. breaker in it.
Thank you all.
charlie Bob is offline   Reply With Quote
Old 03-04-2010, 07:05 AM   #2
Got it.
680.40 > Part I > 680.12.
Spa GFCI Disconnect Budman118 NEC Code Forum 26 09-24-2009 09:19 PM
Disconnect at meter katmgj NEC Code Forum 25 04-07-2009 08:07 AM
ac disconnect RODDBODD NEC Code Forum 38 02-11-2009 09:38 PM
Disconnect or not?? Nosparxsse NEC Code Forum 34 01-24-2009 10:31 AM
40 amp disconnect Absolutetruthz General Electrical Discussion 3 08-01-2008 10:08 PM
