How *not* to install floor outlets... - Electrician Talk - Professional Electrical Contractors Forum
Old 07-27-2010, 12:13 AM   #1
Never Used Scotchkote
JoeKP's Avatar
Rewards Points: 2,032
Send a message via AIM to JoeKP Send a message via Skype™ to JoeKP
Thumbs down How *not* to install floor outlets...
This was at the Public access station I made a topic about before.
These are floor outlets that have been in the building for a while. When they changed the hardwood floors to carpet upstairs, the local High School students that were doing the electrical in the building just poped off the plates, loosened the devices a bit, and put the covers back on. This is what it looks like after I think 3 or 4 years... I was unable to find where the power was comming from (It was already dead, and they never used the outlets.) I put the box extensions on the boxes,and blanked them off, There was 3 in a row. If I ever find the power I am going to put the middle outlet in with some sort of protective cover.
Is there a better cover that can be used on this, I'm sure that these will become all scratched and bent out of shape pretty soon...
Before:
During:
The Outlets and plates from the floor (The plates were bent more than this, but I tried to bend them back into shape):
I am heading back on Wednesday, I will remember to grab a pic of all three the way they are now.
Don't believe me? too bad....
JoeKP is offline   Reply With Quote
Old 07-27-2010, 12:19 AM   #2
JLA
I would put a solid plate underneath the carpet, then cut a couple pieces of carpet from inside a closet or under a desk and patch over the holes.
JLA is offline   Reply With Quote
Old 07-27-2010, 12:24 AM   #3
I own stock in FotoMat!
Rewards Points: 6,520
I would replace them with listed floor receptacles.
BIGRED (07-27-2010)
Old 07-27-2010, 12:26 AM   #4
JoeKP's Avatar
I may try that. But I tried to pull up a section of the carpet to see if i could put the current single gang cover plates under the carpet, and that stuff feels like it is super glued down, and there is no closets to cut carpet from, and they move furniture a lot...
Old 07-27-2010, 12:29 AM   #5
JoeKP's Avatar
is there any that will fit in a single gang old work box, this is a historical building, and I am very limited on cost, and what I can cut into and move... I'm thinking that if I can cut some carpet from somewhere, I will unscrew the old work boxes, and pull the wires, and replace them with string for future use.
Old 07-27-2010, 01:27 AM   #6
Bkessler's Avatar
Rewards Points: 2,000
Can you put a deeper box in, if so a single outlet floor receptical will work. I use a deep single gang gem box when I install a floor outlet in a house.
When ls lunch?
Old 07-27-2010, 01:31 AM   #7
JoeKP's Avatar
there is about an inch -or more- of carpet and padding, I think I can raise the boxes, i'm not sure
Old 07-27-2010, 07:17 AM   #8
drsparky's Avatar
Rewards Points: 222
dito
Old 07-27-2010, 08:32 AM   #9
I believe it's either Leviton, or Cooper that makes a relatively inexpensive floorbox/plate that mounts onto a conventional old-work style box. I don't remember part numbers or anything, but I know the supply house I used to work at sold em, and most of our devices were Leviton or Cooper. I know it wasn't Steel City or Wiremold/Walker. If memory serves it is a single receptacle, and the plate only comes in a brass finish.
Wiredude is offline   Reply With Quote
Old 07-27-2010, 08:58 AM   #10
Rewards Points: 586
What is the issue?
Old 07-27-2010, 09:02 AM   #11
Rewards Points: 2,050
No good.
314.27(C) Floor Boxes. Boxes listed specifically for this application shall be used for receptacles located in the floor.
Exception: Where the authority having jurisdiction judges them free from likely exposure to physical damage, moisture, and dirt, boxes located in elevated floors of show windows and similar locations shall be permitted to be other than those listed for floor applications. Receptacles and covers shall be listed as an assembly for this type of location.
Old 07-27-2010, 09:34 AM   #12
"Boozer"
Innovative's Avatar
You need different customers. Every time you have an issue, it needs to be done cheap. Cheap is not the best solution, nor is it the code compliant solution. As an EC, your job is not to do it cheap, but to do it correct.
www.IEC-Electric.com
www.Hivoltage.biz
"The impossible, is usually the untried"
Innovative is offline   Reply With Quote
Old 07-27-2010, 09:35 AM   #13
Carlon
Old 07-27-2010, 10:13 AM   #14
JoeKP's Avatar
I wish I could, but this is a friend, and they have had me do all their other work. And I think I may have worked it out that the local high school kids wont be doing any more electrical in that building. They are having to do it cheap, because they are a non-profit company, and dont have that big of a budget.
Old 07-27-2010, 10:29 AM   #15
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 292
EC ? I thought Joe was an apprentice doing illegal side work ?
Old 07-27-2010, 10:45 AM   #16
"Boozer"
Innovative's Avatar
I dunno...... too hard to keep track of on here.
At least when my guys want to do side work, they pay me to get a permit and give me a cut of the job. This is limited to friends and family of the employee tho........and at my discretion.
www.Hivoltage.biz
Old 07-27-2010, 10:54 AM   #17
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
You take a "cut" from the poor bastards?...Great guy.
Old 07-27-2010, 10:56 AM   #18
JLA
You take a cut to pull a permit for your employee's friends and family work??
Edited, I just saw NoleTigaBait's posts after making mine, apparently we are on the same page.
Old 07-27-2010, 11:26 AM   #19
Why would he pull the permit for free?
Old 07-27-2010, 11:36 AM   #20
I_get_shocked's Avatar
Rewards Points: 516
whats a permit
I_get_shocked is offline   Reply With Quote
Tags
floor outlets
Office outlets iamcarbman NEC Code Forum 8 04-01-2010 04:45 PM
garage outlets tonytonytony Residential Electrical Forum 18 12-07-2009 11:25 PM
outlets not working!! jeff funk General Electrical Discussion 72 10-20-2009 11:09 PM
Outlets sacco1010 General Electrical Discussion 3 10-02-2009 12:20 AM
Max # outlets subelect NEC Code Forum 22 06-03-2008 10:20 AM
