The cap (starter) could be external to the ballast. If the ballast is a multi-tap make sure they are hooked to the correct winding. Also make sure the cap and ballast are wired together correctly. I change alot of HPS, MH and Mercury Vapor lights in wall packs and parking lots. When one of the younger guys goes out and it doesn't work, nine times out of ten they wired the cap wrong. They other tenth is usually time clock and/or automation control.
As applied to when changing the lamp in a light fixture.
48% of the time the lamp will work.
48% of the time the Lamp will NOT work.
4% of the time the light fixture will go up in smoke
As applied to a service call to a residential customer
48 % chance that the wiring was never to code.
48 % chance that the wiring is just old work methods that was to code at one time and just needs to be updated.
4% chance that the wiring IS really FUBAR.
As applied to replacing a 3 phase electric motor
48% of the time, after the motor is hooked it will rotate in the correct direction.
48% of the time, after the motor is hooked it will NOT rotate in the correct direction.
4% of the time the motor will go up in a puff of smoke.
The list goes on……….:jester:
Add you own! :thumbsup:
:001_huh: High pressure sodium fixtures have both a capacitor and an igniter. The igniter operates a "tickler" circuit that makes the ballest produce voltage spikes up around 2KV to 5KV until the lamp ignites. If you have a good ear you can hear the noise the igniter produces in the ballest when you have a bad lamp or open circuit. The igniter is typically a small circuit board with plug-on terminals, a plastic frame that plugs in - will have 3 or 4 small components, or a small (half dollar size) tubular part with 3 wires(usually) The igniter is visably smaller than the capacitor.
The first test is try a new HPS lamp. If this fails try a mercury or metal halide of the same wattage, or a 200-300 watt incandescent with a mogal adapter. If the lamp comes on the igniter is bad. Don't do this any longer than necessary to prove a good ballest.
After a HPS lamp has been used a long time it winds up producing an internal gas pressure that requires more voltage than the ballest can supply to maintain the arc. This causes "cycling" where the lamp comes on, heats up, then goes back out. The older the lamp is and the longer it has been in this mode the faster this will happen. If you are doing maintenance on a group of lights turn them on for 15 or 20 minutes to see if any are beginning to cycle.
DO NOT put a meter across the socket connections if the fixture won't light. If the lamp is bad you will see the 2-5KV spikes across your meter.
It's been a while, but if I recall there is a point around 150 watts where the voltage changes from around 88 volts (up to 150 watt) to 100 volts (150 watt up) nominal on the lamp, and the 150 watt is made in both voltages - double check the info on the ballest AND the lamp in these.
Again, it's been a while but it seems to me that the max the ballest will supply to the lamp is around 108 volts, and you can predict lamp failure by checking the voltage supplied to it. Since it's been a while, you can verify the voltages I gave by installing a new lamp in a fixture and checking the voltage after an hour or so, then install a lamp that cycles and check the voltage continuously till the lamp goes off. Anything up in the volt or two of the cut off voltage is a candidate for replacement.
Finally, a yellow iodine color on the inside of the lamp is evidence of a leaking gas tube.:sweatdrop:
Buy a ballast kit, less hassle and if another component fails where are the savings? Too lazy right now, but there are troubleshooting tips on the Advance Transformer website.
A bit of experience with HID lighting allows effective troubleshooting. Installing a ballest kit when an igniter is the only problem is sorta like stealing from the customer isn't it?
You replace the igniter and then later fixture quits working ,then what do you tell the customer? Kit it and you have almost the equiv. of a brand new fixture.
:wacko: Where do you draw the line on CYA parts replacement? Do you replace motors when the start cap is the only problem? A bearing could seize next week. This isn't any different and is very straightforward.
Outside luminaires of any kind are in a pretty harsh environment. Close lightning strikes will often shorten the life of that brand new kit in the
fixture to a few seconds or maybe a month or two. How do you deal with that?
If you educate your customers up front about the nature of HID lighting and build a trust you typically don't have to do much explaining to them. People who can get a good handle on the costs of lighting maintenance generally wind up with pretty loyal customers.
Do your homework. Megger the ballast to make sure those high voltage spikes don't have the opportunity to drill a hole that will eventually provide a low voltage short. Measure open circuit voltage to make sure the cap isn't bad or that windings haven't failed. Measure lamp voltage to do some lamp life prediction and verify cap status. Keep bad parts around so you can do hands on training with the help - a LOT of the issues with troubleshooting HPS fixtures are that people unfamiliar with them either don't believe what their test results tell them or misinterpret them.
My nickel's worth, anyway.
Related Threads
Electrician Talk
2.3M posts
93.3K members
Since 2007
