HPS fixture - Electrician Talk - Professional Electrical Contractors Forum
Old 09-11-2007, 12:10 PM   #1
shazam's Avatar
Default HPS fixture
Guys are out on the job repairing lamps and ballast in some wall packs.
They have 120v at the base of the lamp but the lamp is not starting.
First thought was, wrong lamp guys. Nope it is the right lamp.
How does this happen? 120v but still won't illuminate??
Just when you think youv'e seen everything...........
shazam is offline   Reply With Quote
Old 09-11-2007, 07:37 PM   #2
Joe Momma's Avatar
I'm no expert, but I'm pretty sure you need upwards of 300V to get a sodium light to start.
Perhaps a bad starter in the fixture, but it's likely it's wrapped inside the transformer, so you'll have to replace the entire ballast.
Joe Momma was here
Old 09-11-2007, 08:08 PM   #3
Proud Navy Veteran
Greg's Avatar
Rewards Points: 588
The cap (starter) could be external to the ballast. If the ballast is a multi-tap make sure they are hooked to the correct winding. Also make sure the cap and ballast are wired together correctly. I change alot of HPS, MH and Mercury Vapor lights in wall packs and parking lots. When one of the younger guys goes out and it doesn't work, nine times out of ten they wired the cap wrong. They other tenth is usually time clock and/or automation control.
Memorial Day: All gave some but some gave all.
Take the time to tell a Veteran Thank You, You owe him/her at least that much. After all Freedom is not Free.
Old 09-11-2007, 08:24 PM   #4
DGFVT
John's Avatar
Rewards Points: 168
I will second the motion that it's most likely the Capacitor.
Ever hear of the 48/48/4 rule concerning electricity?
R.E.D.
Old 09-12-2007, 08:06 PM   #5
shazam's Avatar
Well, I haven't been out to see the fixture myself yet.
When I go I will keep the cap and wiring in mind. Thanks
Old 09-12-2007, 10:01 PM   #6
Joe Momma's Avatar
So is this a guessing game John?
what's the 48/48/4 rule?
I have the funny feeling it has to do with percentages?
I've heard of the 90/10 rule of troubleshooting
which says 10% of the system/parts cause 90% of the problems
Joe Momma was here
Old 09-12-2007, 10:34 PM   #7
itsunclebill's Avatar
Rewards Points: 312
High pressure sodium fixtures have both a capacitor and an igniter. The igniter operates a "tickler" circuit that makes the ballest produce voltage spikes up around 2KV to 5KV until the lamp ignites. If you have a good ear you can hear the noise the igniter produces in the ballest when you have a bad lamp or open circuit. The igniter is typically a small circuit board with plug-on terminals, a plastic frame that plugs in - will have 3 or 4 small components, or a small (half dollar size) tubular part with 3 wires(usually) The igniter is visably smaller than the capacitor.
The first test is try a new HPS lamp. If this fails try a mercury or metal halide of the same wattage, or a 200-300 watt incandescent with a mogal adapter. If the lamp comes on the igniter is bad. Don't do this any longer than necessary to prove a good ballest.
After a HPS lamp has been used a long time it winds up producing an internal gas pressure that requires more voltage than the ballest can supply to maintain the arc. This causes "cycling" where the lamp comes on, heats up, then goes back out. The older the lamp is and the longer it has been in this mode the faster this will happen. If you are doing maintenance on a group of lights turn them on for 15 or 20 minutes to see if any are beginning to cycle.
DO NOT put a meter across the socket connections if the fixture won't light. If the lamp is bad you will see the 2-5KV spikes across your meter.
It's been a while, but if I recall there is a point around 150 watts where the voltage changes from around 88 volts (up to 150 watt) to 100 volts (150 watt up) nominal on the lamp, and the 150 watt is made in both voltages - double check the info on the ballest AND the lamp in these.
Again, it's been a while but it seems to me that the max the ballest will supply to the lamp is around 108 volts, and you can predict lamp failure by checking the voltage supplied to it. Since it's been a while, you can verify the voltages I gave by installing a new lamp in a fixture and checking the voltage after an hour or so, then install a lamp that cycles and check the voltage continuously till the lamp goes off. Anything up in the volt or two of the cut off voltage is a candidate for replacement.
Finally, a yellow iodine color on the inside of the lamp is evidence of a leaking gas tube.
Old 09-12-2007, 11:45 PM   #8
Thumbs up
Well, I agree with unclebill. It's the starter 9 times out of ten. You can get a universal starter at your supply house.
citysparky is offline   Reply With Quote
Old 09-13-2007, 03:42 AM   #9
Rewards Points: 658
Buy a ballast kit, less hassle and if another component fails where are the savings? Too lazy right now, but there are troubleshooting tips on the Advance Transformer website.
Norcal is offline   Reply With Quote
Old 09-13-2007, 06:27 AM   #10
Rewards Points: 312
A bit of experience with HID lighting allows effective troubleshooting. Installing a ballest kit when an igniter is the only problem is sorta like stealing from the customer isn't it?
Old 09-13-2007, 07:22 AM   #11
DGFVT
John's Avatar
Rewards Points: 168
As applied to when changing the lamp in a light fixture.
48% of the time the lamp will work.
48% of the time the Lamp will NOT work.
4% of the time the light fixture will go up in smoke
As applied to a service call to a residential customer
48 % chance that the wiring was never to code.
48 % chance that the wiring is just old work methods that was to code at one time and just needs to be updated.
4% chance that the wiring IS really FUBAR.
As applied to replacing a 3 phase electric motor
48% of the time, after the motor is hooked it will rotate in the correct direction.
48% of the time, after the motor is hooked it will NOT rotate in the correct direction.
4% of the time the motor will go up in a puff of smoke.
The list goes on……….
Add you own!
R.E.D.
Old 09-13-2007, 09:41 AM   #12
Rewards Points: 658
You replace the igniter and then later fixture quits working ,then what do you tell the customer? Kit it and you have almost the equiv. of a brand new fixture.
Old 09-13-2007, 08:05 PM   #13
Joe Momma's Avatar
If it aint broke, don't fix it.
Like Bill said, it's pretty much always the starter, so why replace the transformer under the notion that "it will fail one day". You could probably go through 5 capacitor's before xfmr fails.
I changed one last winter that was an all-in-one unit, the supply house 120 for the exact replacement, or 80 for the individual parts. I opted for the 80 to save the customer a few bucks. Installed it and as I was screwing in the bulb noticed it was Mercury Vapor lamp in a Sodium light.
Well so much for trying to save the customer money, lesson well learned for me anyhow.
Joe Momma was here
Old 09-13-2007, 11:15 PM   #14
Rewards Points: 312
Where do you draw the line on CYA parts replacement? Do you replace motors when the start cap is the only problem? A bearing could seize next week. This isn't any different and is very straightforward.
Outside luminaires of any kind are in a pretty harsh environment. Close lightning strikes will often shorten the life of that brand new kit in the
fixture to a few seconds or maybe a month or two. How do you deal with that?
If you educate your customers up front about the nature of HID lighting and build a trust you typically don't have to do much explaining to them. People who can get a good handle on the costs of lighting maintenance generally wind up with pretty loyal customers.
Do your homework. Megger the ballast to make sure those high voltage spikes don't have the opportunity to drill a hole that will eventually provide a low voltage short. Measure open circuit voltage to make sure the cap isn't bad or that windings haven't failed. Measure lamp voltage to do some lamp life prediction and verify cap status. Keep bad parts around so you can do hands on training with the help - a LOT of the issues with troubleshooting HPS fixtures are that people unfamiliar with them either don't believe what their test results tell them or misinterpret them.
My nickel's worth, anyway.
Replace k & t close to the light fixture mdcorreia General Electrical Discussion 10 10-13-2008 12:06 PM
Fixture & Fitting heights s6stu UK Electrical Forum 4 10-26-2007 06:01 PM
Question about installed light fixture & ceiling fan tallford78 General Electrical Discussion 3 07-07-2007 06:31 PM
Metal Halide fixture InControl General Electrical Discussion 8 04-16-2007 11:34 PM
Fixture straps I hate MDShunk Lighting Design 1 01-18-2007 01:05 AM
