Charles, welcome to the forum!
You would have to check with Texas, as to there rules and requirements for taking the test. You may very well have to WORK in Texas for a period of time before being allowed to test.
There is a program, "Helmets to hardhats" I think it is called, which helps military veterans enter the construction industry.
You may do better, with your experience, doing control, alarm, or other "low voltage" type work.
John from Baltimore
"One day at a Time"
