Interconnected motion lights - Electrician Talk - Professional Electrical Contractors Forum
Old 11-29-2008, 10:54 AM   #1
Rewards Points: 1,246
Default Interconnected motion lights
I have a customer that wants 4 motion lights, 1 on each corner of the house. They want them set up so if any one turns on, all the rest turn on at the same time.
Has anyone tried this?
Old 11-29-2008, 11:42 AM   #2
kbsparky's Avatar
Rewards Points: 1,000
I have done this, using 3-wire cable between them all. You will have to keep an eye on the total connected load, since one sensor may be switching on 8 bulbs at once.
If you are using 150 watt bulbs, that is 1200 connected watts.
More than most units are rated for, even the RAB's are only rated for 1000 watts, I believe.
If you stuck with 100 watt or smaller bulbs, then it should work.
Old 11-29-2008, 11:49 AM   #3
Speedy Petey's Avatar
Rewards Points: 2,404
It can be done. No way I'd do it with only one MD, just because of the load issue KB brought up.
If they insist you can always use a contactor.
Old 11-29-2008, 11:55 AM   #4
Petey, there will be 4 MDs, one at each fixture.
KB, so there is no problem when the line backfeeds into the load side of the other 3 MDs?
As for the connected load, I can use 45 watt lamps for a total of 360 watts. Additionally, I can use a dedicated circuit, as I did the service and there is lots of room.
Old 11-29-2008, 12:00 PM   #5
Stan Mason's Avatar
this is what i would do it could be wrong you can get a Md @ 600w and your first light would get the MD and you can use a a two wire to go from light to light cause all you need to take is the leg and the netural since the md would be powerd from the first light which would turn the rest of them on.
Just Waking up is a good start
Stan Mason is offline   Reply With Quote
Old 11-29-2008, 12:05 PM   #6
Yes that's a no brainer, but thats not what they want. They want FOUR MDs, FOUR fixtures, ALL fixtures to light when any ONE MDs sees motion.
Old 11-29-2008, 12:13 PM   #7
Stan Mason's Avatar
ok i miss read it . ok this is what i came up with he is going to have to power all his Md's and the load wire of the Md's to a relay he is going to use 4 relays and then series the legs from relay to relay so when any MD sees movment it will fire all the lights on and that should solve the back feed problems I hope this works smoke is comming out of my ears right now I am a hands on person If i had it in front of me i can do it but from reading this I am trying and this is all I came up with
Old 11-29-2008, 12:30 PM   #8
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
must use relay
Old 11-29-2008, 12:32 PM   #9
Stan Mason's Avatar
Originally Posted by nolabama View Post
must use relay
thats the only way i can see it working without backfeeding
Old 11-29-2008, 12:58 PM   #10
Nosparxsse's Avatar
Rewards Points: 150
That's the way to do it. Done this many times.
Nosparxsse is offline   Reply With Quote
Old 11-29-2008, 09:49 PM   #11
Rewards Points: 2,012
Why 4 relays? 1 control ckt to 1 relay.
Old 11-29-2008, 09:51 PM   #12
Stan Mason's Avatar
Lightbulb
you can with a 4pole relay the reason i would use 4 relays is that your load of your MD's would fire the coil of the relay to avoid back feed
Old 11-29-2008, 10:08 PM   #13
I'm confused now. with you r answer.
back feed to what? 4 switches in parallel to 1 relay coil. Done all the time.
If you fire four coils,there will be backfeed coz they will be parallel.
4 pole relay if they (loads) are on seperate ckts.
Still 1 control ckt to operate the coil.
Old 11-29-2008, 10:11 PM   #14
Stan Mason's Avatar
I see what your doing and that would work good thinking
Old 12-02-2008, 11:11 PM   #15
220/221's Avatar
Rewards Points: 3,582
No relay necessary.
3 wires.
Black hot, red switch leg, white neutral.
I have done it with two MD's.
Only issue is wattage.
Old 12-03-2008, 08:51 AM   #16
R.I.P. 2014
Wrong thought.
Old 12-03-2008, 08:52 AM   #17
R.I.P. 2014
The issues isn't the circuit load, it's the load on the md.
Old 12-03-2008, 09:30 AM   #18
The effect of One MD "feeding" the others seems to be the unknown and I sure don't know. I guess it wouldn't cost much to test a prototype. Seems to me,if it has been done with two, it can be done with four.
What the customer wants (sounds like) an "or" control of all four lights where the triggering of one MD will light all the lights, sort of like interwired smokes.
Motion controled light strobing naildriver General Electrical Discussion 3 11-28-2008 07:11 AM
motion sensors' captkirk General Electrical Discussion 8 10-23-2008 01:47 PM
Recommendation: AC lights off of Inverter, or DC rechargeable lights mhl General Electrical Discussion 4 09-30-2008 06:27 AM
brighest outdoor motion light Matt Lighting Design 11 02-17-2008 05:17 PM
Urgent: Interconnected Smoke Alarm Crabby UK Electrical Forum 5 11-25-2007 10:12 PM
