Old 07-05-2012, 10:05 AM   #1
Default interconnected smoke detectors
I cant find my book anywhere
I am doing a re-wire of all the outlets in a house, the lighting has already been done by someone else a few years ago. Is it required to install interconnected smoke detectors? It currently has battery operated ones.
Im thinking that if they aren't part of my scope then they are fine to leave how they are.
paul_arc is offline   Reply With Quote
Old 07-05-2012, 10:07 AM   #2
It's not an NEC issue. It would be covered by your building or fire codes. Here, it's under the state fire code and all fire alarm and smoke detectors are inspected by the local fire marshall or fire department. Check your municipal offices for the answer.
Old 07-05-2012, 10:23 AM   #3
okay thanks for the info. I will give them a call when they open up.
Old 07-05-2012, 02:09 PM   #4
Master Plumber
TOOL_5150's Avatar
In CA, if you are doing a service upgrade you are usually required to have battery smokes. If you have a certain percentage of wallboard removed, you are required to install interconnected. if you are just swaping out recepts, no IC smokes are needed.
Poor planning on your part does not constitute an emergency on my part.
Old 07-05-2012, 02:29 PM   #5
360max's Avatar
try to sell the customer the 120v interconnected ones, explain to them its to their advantage to have it done now.
360max is online now   Reply With Quote
Old 07-05-2012, 03:15 PM   #6
J. Temple's Avatar
Don't forget about the carbon monoxide detectors!!
J. Temple is online now   Reply With Quote
The Following User Says Thank You to J. Temple For This Useful Post:
360max (07-05-2012)
Old 07-06-2012, 12:18 AM   #7
I talked to the inspector this morning and yeah, not required for me to install interconnected smoke detectors. I did give a price if they would like them installed as well
Old 07-06-2012, 12:33 AM   #8
carryyourbooks's Avatar
i had a customer today who insisted on battery operated smokes only. after i mentioned that mom would wake to a detector that went off in her daughter's room (due to interlock), the customer quickly saw things my way. the only reason he wanted battery operated only is because his went off once and he couldn't get them to stop.
www.electriccitycontractors.com
carryyourbooks is offline   Reply With Quote
Old 07-06-2012, 10:35 AM   #9
There are wireless interconnected smoke/CO detectors should they really want to go that way.
KGN742003 is offline   Reply With Quote
The Following User Says Thank You to KGN742003 For This Useful Post:
J. Temple (07-06-2012)
Old 07-06-2012, 01:39 PM   #10
J. Temple's Avatar
I didn't know they had wireless one. That may be a great solution on some remodels!
Old 07-06-2012, 11:09 PM   #11
God-fearing Volt-head
janagyjr's Avatar
Send a message via ICQ to janagyjr Send a message via AIM to janagyjr Send a message via MSN to janagyjr Send a message via Yahoo to janagyjr Send a message via Skype™ to janagyjr
I installed some wired interconnected smoke/CO2 detectors on a new construction trim-out...easiest part of the whole job.
Around here, if you pull a permit EI mandates smoke detectors of some sort or he won't pass.
All original content licensed via the OWL (http://owl.apotheon.org) from date of post.
Electricity is like water: the smallest amount can kill you, it's hard to control, and life is impossible without it.
janagyjr is offline   Reply With Quote
Smoke detectors Salvatoreg02 NEC Code Forum 6 03-02-2012 03:26 PM
Smoke detectors All Current Other Codes and Standards 9 02-10-2012 12:53 PM
Smoke detectors? Teaspoon Residential Electrical Forum 3 10-16-2011 08:27 AM
Smoke Detectors / CO 2 detectors pjmurph2002 Residential Electrical Forum 12 03-27-2011 05:28 PM
Urgent: Interconnected Smoke Alarm Crabby UK Electrical Forum 5 11-25-2007 10:12 PM
