inverse time breaker - Electrician Talk - Professional Electrical Contractors Forum
Old 08-24-2010, 06:31 PM   #1
Rewards Points: 526
Default inverse time breaker
I was recently looking over some specs. for a diesel exhaust removal system. the specs say the breaker must be a 60 amp inverse time breaker since it is a motor circuit, so i call supply house and ask for price on breaker and the guy says he's never heard of an inverse time breaker, in fact none of the counter people had, so i guess my question is when you buy a 60 amp 2-pole breaker is it an inverse time (are all breakers inverse time?) or is it something i'll have to go to the manufacturer for??
any info would help, thx
ohiosparky99 is offline   Reply With Quote
Old 08-24-2010, 06:49 PM   #2
Murphy's Avatar
Rewards Points: 254
Send a message via AIM to Murphy
I believe all breakers are now inverse time.. you dont buy a special breaker for your ac or other motor loads.. the normal breakers you buy should be qualified.. but im not a 100% on this
Murphy is offline   Reply With Quote
Old 08-24-2010, 06:54 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
Most off-the-shelf breakers have two modes used to trip it.
One is a magnetic system, which detects a gawd-awful amount of current (usually caused by a short circuit).
The other is a thermal system, which, depending on the amount of current, will take difference amounts of time to trip.
A 20a breaker will not trip at 20.000000000001 amps. It may not ever trip at 22 or 23 amps. It may trip in 5 minutes at 25 amps, 1 minute at 30 amps, 15 seconds at 40 amps, etc. This is what is meant by 'inverse time'.
Old 08-24-2010, 06:55 PM   #4
Jlarson's Avatar
Rewards Points: 2,792
Almost all molded case breakers are inverse time.
Old 08-24-2010, 07:00 PM   #5
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 258
I believe the only molded case breakers that aren't inverse time are ones that only have a magnetic-trip.
All "inverse time" means is that as the current goes up, the time to trip decreases. I may be talking out of my back-side, but I think any breaker with a "trip curve" qualifies as an "inverse time" breaker. That trip curve is nothing but a graph of how time decreases as the current increases.
-John
Big John is online now   Reply With Quote
Old 08-24-2010, 07:16 PM   #6
Rewards Points: 526
sounds good, you learn something everyday, thanks for the help
Old 08-24-2010, 07:24 PM   #7
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 358
what supply house was that ?
Old 08-24-2010, 08:10 PM   #8
Zog
Zog's Avatar
Rewards Points: 800
Everything that was said above is correct, I am shocked a supply house guy would not know that.
Old 08-24-2010, 08:31 PM   #9
Rewards Points: 526
State electric
Old 08-24-2010, 09:33 PM   #10
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 258
I ain't. A lot of suppliers are on the ball, but I've run into some serious yokels; the guy who thought a quad receptacle cover was called a "duplex," because "duplex" means "two" and a quad holds two "normal" receptacles.
-John
inverse breakers john salyards General Electrical Discussion 5 03-17-2011 07:40 AM
Long time viewer 1st time poster Brechi98 Introductions 8 05-29-2010 05:00 PM
Inverse time rogimor General Electrical Discussion 9 03-31-2010 05:57 PM
Long time listener - first time caller PJSkiboy Introductions 14 01-27-2010 11:08 PM
breaker on, wires have voltage; breaker off, wires have continuity. How can this Be? Weskey General Electrical Discussion 6 10-08-2009 09:47 PM
