Knockout size vs. fitting size - Electrician Talk - Professional Electrical Contractors Forum
Like Tree25Likes
Old 03-19-2010, 01:36 AM   #1
Default Knockout size vs. fitting size
A knockout for 1/2" conduit is 7/8", but the outside diameter of a 1/2" EMT fitting is about 3/4". 3/4" knockout is 1-3/32" (close enough to 1-1/8), and O.D. of 3/4" fitting is roughly 1". So basically 1/8" for fudging around? Otherwise your bends/etc would have to be ultra precise?
Would it be unwise to cut my hole for 1/2" conduit to exactly 3/4" with a unibit?
Are the O.D. of other fittings (PVC, GRC, etc) the same size?
Jhellwig likes this.
Conduit Phil is offline   Reply With Quote
Old 03-19-2010, 01:47 AM   #2
The outside diameter for emt is different than the rest. Metal rigid, pvc, flex etc..is all the same outside diameter. They reduce the innner wall on those to make it thicker.
PVC coated rigid I think has a bigger outside diameter but I don't know for sure since I have never worked with it.
If you drill your holes that tight you probably will almost have to thread them into knockout, by the way why do you ask such oddball questions about conduit all the time ? are you in school or something ?
user438 is offline   Reply With Quote
Old 03-19-2010, 01:49 AM   #3
Originally Posted by Rich R View Post
The outside diameter for emt is different than the rest. Metal rigid, pvc, flex etc..is all the same outside diameter. They reduce the innner wall on those space to make it thicker.
I know the OD of the actual pipe differs, but the fittings would have to be pretty similar in OD, otherwise they wouldn't fit in the same knockouts...
Old 03-19-2010, 01:52 AM   #4
ok I misunderstood, you mean the outside diametr of the threads, yeah they are the same no matter what type conduit, they have to meet the NPT standard
Old 03-19-2010, 01:53 AM   #5
Well the fact that all the different fittings can use the same steel locknuts just shows that all the fittings would have to have the same OD.. so I kinda just answered my own question
Old 03-19-2010, 01:54 AM   #6
yep, threads are all the same diameter no matter what conduit type
Old 03-19-2010, 02:00 AM   #7
Not in school right now but I always like to know the reason behind these things rather than just doing them.
Old 03-19-2010, 02:06 AM   #8
Good questions, just don't normally see them, I'm used to helpers/apprentices more concerned about texting on cell phone than outside asking about diameter of conduit threads.
That is the key to learning this trade, I always tell new guys "don't think you will memorize this stuff, you have to know the reason behind doing what you doing" Once you realize that, there will be no problem or job that you can't figure out
Old 03-19-2010, 02:14 AM   #9
Toronto Sparky's Avatar
Rewards Points: 1,008
Don't forget those thin-wall connectors from China that fall though the 7/8 hole..
Don't fight .. Play nice!
The Following 2 Users Say Thank You to Toronto Sparky For This Useful Post:
Jhellwig (10-23-2016), rlc3854 (03-19-2010)
Old 03-19-2010, 05:10 AM   #10
Fried Bologna um um good!
jwjrw's Avatar
If I'm drilling just a few holes I'll unibit em in a second. I get alot of use out of my unibit!
The Following 2 Users Say Thank You to jwjrw For This Useful Post:
jhartz (07-07-2015), Jhellwig (10-23-2016)
Old 03-19-2010, 07:01 AM   #11
mattsilkwood's Avatar
Rewards Points: 2,006
Me too.
And please DRILL ON LOW WITH MY UNIBIT!
The Following User Says Thank You to mattsilkwood For This Useful Post:
Old 03-19-2010, 02:18 PM   #12
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
a hole for a half inch emt connector is 7/8 inches. a hole for a 3/4 emt connector is 1 1/8 inches. that is the same for all connectors.
The Following User Says Thank You to electricalperson For This Useful Post:
Old 03-19-2010, 06:20 PM   #13
stop pickin on Peter D...
BP_redbear's Avatar
The outside diameter for emt is different than the rest. ...why do you ask such oddball questions about conduit all the time?
He is Conduit Phil. Why wouldn't he ask questions about conduit? That's one of the ways that some of us learn.
Why call someone 'oddball'?
Your answers are very informative, by the way.
BP_redbear is offline   Reply With Quote
The Following User Says Thank You to BP_redbear For This Useful Post:
Old 03-19-2010, 06:27 PM   #14
220/221's Avatar
Rewards Points: 3,564
Nothing to do with the bends. If a connector fit exactly into the hole it would be a PITA to install. We need wiggle room. The more the better.
First, a unibit has to take out too much material. A hole saw only cuts a small portion therefore takes less energy to do so.
Second, like I said, you need wiggle room.
The Following User Says Thank You to 220/221 For This Useful Post:
Old 03-19-2010, 06:48 PM   #15
Rewards Points: 1,464
When I was a boot,we had to carry a 1/2"-1 1/4" knockout set. Life before hole saws.
The Following User Says Thank You to bobelectric For This Useful Post:
Old 03-19-2010, 06:53 PM   #16
Rewards Points: 3,855
On a related note, here's a handy chart put out by the US Iron and Steel Institute a good many years ago. It's a knockout spacing chart, which takes into account the locknut and the bushing. It's the distance, center to center, of adjacent knockouts. You look up the one pipe size down the left hand side, and the adjacent pipe size along the top. Follow both into the chart where they intersect, and that's the spacing between their centers.
The Following 5 Users Say Thank You to MDShunk For This Useful Post:
Grogan14 (09-20-2014), Jhellwig (10-23-2016), shocksystems (05-17-2014), The Motts (03-19-2010), Triple Nickel (07-19-2010)
Old 03-19-2010, 07:31 PM   #17
BP_redbear's Avatar
That's good stuff!!
I am gonna print that out and keep it in my tool box!
Old 03-19-2010, 07:48 PM   #18
Rewards Points: 5,198
It's been a while but as I remember, the PVC coated rigid is only different in size by the thickness of the coating.When you have to thread it you just trim the PVC back the length of the thread. The couplings are PVC coated with the coating extending to both sides of the coupling in a form of a boot.
The Following User Says Thank You to RIVETER For This Useful Post:
Old 03-19-2010, 10:14 PM   #19
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Great tip I learned on here years ago.... dip the unibit in cold water after using it. Make it last longer.
Replies based on NEC 2014
The Following User Says Thank You to Magnettica For This Useful Post:
Old 03-19-2010, 10:22 PM   #20
Wont that change the temper?
What size GEC? This cannot be right. rdr General Electrical Discussion 25 12-18-2009 11:59 PM
what size ext ladder do you use the most? nysparky Tools, Equipment and New Products 25 11-30-2009 09:23 PM
box size IBEW501Ed General Electrical Discussion 24 10-16-2009 08:27 PM
Boot Size Help Mikeomo Off Topic (Non Trade) 20 09-17-2009 10:20 PM
Gutter size? J-box? te12co2w NEC Code Forum 17 08-27-2009 12:28 PM
