Closed Thread
Old 05-01-2009, 08:21 PM   #1
EMC
EMC's Avatar
Default KVAR energy saving
has anyone ever heard of kvar energy saving to reduce your power bill/consumption by correcting power factor? if so, i would like to hear your reactions and opinions
EMC is offline
Old 05-01-2009, 08:28 PM   #2
Crap, horse sh*t, junk, rip off, screwing your customer, criminally prosecutable sterling, snake oil, waste of money, bunk, road apples, black magic and if you really want my opinion well give me a few to get my thoughts together.
brian john is online now
Old 05-01-2009, 08:28 PM   #3
electrical scientist
drsparky's Avatar
No do tell!
drsparky is offline
Old 05-01-2009, 08:39 PM   #4
EMC
EMC's Avatar
but, its got a 12 year warranty and a 10% savings guarantee
EMC is offline
Old 05-01-2009, 08:39 PM   #5
Give Brian a gun! I am of the same opinion. Kvar can only be dealt with in large industrial and commercial settings, motors in particular.
Don't let fear be your guide!
Rockyd is offline
Old 05-01-2009, 08:40 PM   #6
Chris Kennedy's Avatar
So you didn't install one on your service?
Bulldozers and Dirt
Chris Kennedy is offline
Old 05-01-2009, 08:56 PM   #7
THis subject has been dealt with here and as noted before there is.
1. There is no penalty for poor residential PF.
2. The fixed capacitance of this device could be an improvement or too much or not enough correction.
3. As noted by others the best energy saver for residential is CFL's and turning down or up the stat depending on the season and turning off the lights.
4. There is no savings.
Old 05-01-2009, 09:04 PM   #8
EMC
EMC's Avatar
its not so much the power factor, as the lower amp/wattage use. does this make any difference?
EMC is offline
Old 05-01-2009, 09:06 PM   #9
REMOVED
robnj772's Avatar
ANOTHER KVAR thread ???????????????????
robnj772 is offline
Old 05-01-2009, 09:47 PM   #10
Well yes we have its part of the economic recovery plan in the good old usa today everyone is thinkin green !!
You see you pay to have it installed by a out of work electrician he comes in and changes the temp setting on your water heater next he puts in lower wattage bulbs ect ect you do save power ! and your helping out the working class trying to make a living by doing your part to save energy . take care think green turn down t stat and a lamp !
Now just come out and say it your selling these and your not sure of what your selling right or wrong ?
nick is offline
Old 05-01-2009, 10:08 PM   #11
william1978's Avatar
Its a four letter word JUNK.
william1978 is offline
Old 05-01-2009, 10:18 PM   #12
Originally Posted by emc View Post
its not so much the power factor, as the lower amp/wattage use. Does this make any difference?
that's a big no
Old 05-01-2009, 11:12 PM   #13
Chairman of the Bored
BuzzKill's Avatar
dude, c'mon! I saw the "sham wow" guy hawking that stuff on late night tv! It MUST work!
BuzzKill is offline
Old 05-02-2009, 12:53 AM   #14
redbeard43's Avatar
it only works with motors the best, reduces heat. google KVAR scam and see what you get. ill have to find my post I made about it a while back.. YES another thread but a newbie OP.
You have the ring, and I see that your schwarz is as big as mine.May the schwartz be with you!
redbeard43 is offline
Old 05-02-2009, 12:57 AM   #15
redbeard43's Avatar
AAAAAAAAAAhhhhhhhhhhaaa...i found it..here ya go it was under the thread "power saver"..
Ok its my turn.. I went into the supply house the other day and they had a dvd set up with some gadgets, so i am a man i had to look. They arent selling it but a salesman came in to set it up for all to see, its called a KVAR energy controller.
Its supposed to reduce electrical waste by electromagneticity and reduces the NON-productive current in the electrical system. It is supposed to increase euip. life by reducing heat around the motor and wiring caused by reactive current...blah blah blah...
here is a sight to check out
www.youtube.com/watch?v=efG2-yk3ZK0
Or read crap here:
http://www.globalgreensavings.com/
Opinion of this crap, let me digress,
The electric meter does not register reactive current, only watts. The
KVAR Energy Controller is a capacitor that reduces I squared R line loss.
By improving the power factor of the electric distribution system or an
individual motor, the KVAR unit reduces excessive reactive current that
produces heat, heat is watts, and watts through the meter are reduced. It
is easy to demonstrate how a capacitor can slow down the electric meter
when it is installed on the load side of the electric company's cash
register.
Follow your instincts, search or try it yourself.
Here is an idea, raise your hand, close your fist, stick out you index finger and turn the switch off, save power....... tadaaaaaaaaa..
Old 05-02-2009, 08:03 AM   #16
Master Village Idiot
Greg's Avatar
What worries me is he screen name is EMC. If he is Navy, he is giving the rest of us a bad name by even mentioning kvar scam.
If You Can Read This, Thank A Teacher. If You Can Read It In English, Thank A Veteran
Greg is offline
Old 05-02-2009, 10:54 AM   #17
redbeard43's Avatar
probably a salesman like the past hiding under a name or some original that has more than 1 screen name
Old 05-02-2009, 05:35 PM   #18
Well you can not sell one unit meaning one size fits all homes for power factor correction . Each home would need a study done on that home . what home owner would pay to do that ?
The kvar needed on each motor needs to be at that motor not down stream at the service outdoors !
Lets look inside a few capacitors one or two metal oxide varistors and a choke coil for back feeds online . a coil its a ripple filter for what ? we need ac not dc power in our home .
Question how come GE does not make these for single dwellings ?
What about your computer or all your electronics at the house do you really need a capacitor increasing you voltage at that outlet up to say 160 volts ? because when you add caps thats going to give ya more volts .
Lets look at a short or a appliance with a problem whats that extra voltage stored going to do ?
Does it effect a GFI meaning trip time or maybe burn out or limit some devices in your home meaning limit the warranty of its life span running at higher voltage ?
Best part is all your electronic power supplies will be hotter running as ther internal dc voltage regulators will need to disapate that extra dropped voltage of the correction caps now attached to your service . Take care be safe but dont take the bait !!!
Last edited by nick; 05-02-2009 at 06:34 PM. Reason: SPEND A FEW DOLLARS TO SAVE A PENNY SPEND THOUSANDS TO FIND OUT IT DONT WORK
nick is offline
Old 05-04-2009, 05:08 PM   #19
EMC
EMC's Avatar
Nick, thank you for explaining, that helps it make sense to me why this is not a great idea. Let me clear the air and say that i am not a salesman and do not believe in these. It sounds like a get rich quick type of thing to me. Greg, let me apologize to you for "making you look bad" by using my initials as my screen name, next time I'll try to be more creative. This was brought to me by someone I know and I said I would look into it. Thanks to all for your help.
EMC is offline
Old 05-04-2009, 07:08 PM   #20
Well we understand that its just there are some who come on and are trying to sell it to us folks and i do like to debate with them for fun ! We can say they kinda do work but its not much just pennys .
I will not go running out and purchase one but id like to test one in a controlled kinda load take it to the test bench !! You can only use energy wisely energy used is energy lost law of physics . EMC GEEZEE i dont know anything about electric stuff i was just helping out Greg with that Navy comment !!! Take care best to ya
nick is offline
Closed Thread
Energy saving box or hoax? kbsparky General Electrical Discussion 49 01-19-2010 02:53 PM
KVAR Power Save 1200 lorddrago General Electrical Discussion 2 03-09-2009 06:05 PM
Energy Saving Information Murray Ritchie General Electrical Discussion 1 02-20-2009 09:58 AM
Energy saving house! jonny_know_it UK Electrical Forum 8 10-18-2008 02:23 PM
Saving password frank Site Help and Suggestions 12 03-10-2007 08:21 PM
