Laundry circuit.. - Electrician Talk - Professional Electrical Contractors Forum
Old 02-06-2012, 08:04 PM   #1
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Default Laundry circuit..
(C) Dwelling Units.
(2) Laundry Branch Circuits. In addition to the number
of branch circuits required by other parts of this section, at
least one additional 20-ampere branch circuit shall be provided
to supply the laundry receptacle outlet(s) required by
210.52(F). This circuit shall have no other outlets.
I have a gas dryer next to the WM.. can I use that circuit to power the dryer receptacle..
Would a dryer receptacle be considered part of the "laundry" since it is in the same room/location..
Old 02-06-2012, 08:07 PM   #2
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Originally Posted by B4T View Post
(C) Dwelling Units.
I think the S on outlet(s) saves you.
The Following 2 Users Say Thank You to mcclary's electrical For This Useful Post:
BuzzKill (02-06-2012), Chris1971 (02-06-2012)
Old 02-06-2012, 08:11 PM   #3
caseyelectric's Avatar
Rewards Points: 154
I install a dedicated citcuit for washer. In your case i would install circuit for the motor on dryer-120v. I also usually install another cicuit for ironing in laundry room.
as far as I know gas dryer only needs 120v
caseyelectric is offline   Reply With Quote
Old 02-06-2012, 08:11 PM   #4
rexowner's Avatar
Rewards Points: 508
yes and yes.
rexowner is offline   Reply With Quote
Old 02-06-2012, 08:13 PM   #5
I own stock in FotoMat!
Rewards Points: 6,520
210.52(F)
210.52(F): Laundry Areas. In dwelling units, at least one receptacle
outlet
shall be installed for the laundry.
"Laundry" is not defined. In short, you can install another recep for such things as ironing boards, etc.
Old 02-06-2012, 08:16 PM   #6
B4T
B4T's Avatar
I don't want to add another circuit.. only use the laundry circuit to supply receptacle for gas dryer..
Old 02-06-2012, 08:16 PM   #7
BBQ
Salty Member
BBQ's Avatar
I agree with 480.
leland (02-06-2012)
Old 02-06-2012, 08:17 PM   #8
rexowner's Avatar
Rewards Points: 508
Not a problem. Do it all the time. Never had a problem.
The Following User Says Thank You to rexowner For This Useful Post:
BIGRED (02-07-2012)
Old 02-06-2012, 08:19 PM   #9
B4T
B4T's Avatar
210.52(F)
outlet
So you can use laundry circuit to supply power for an ironing board receptacle..
Old 02-06-2012, 08:20 PM   #10
Awg-Dawg's Avatar
Rewards Points: 338
Originally Posted by BBQ View Post
I agree with 480.
I agree with BBQ, who agrees with 480.
I feel sorry for people who don't drink, when they wake up in the morning, that's the best they will feel all day.
Awg-Dawg is offline   Reply With Quote
Old 02-06-2012, 08:23 PM   #11
B4T
B4T's Avatar
It says.. This circuit shall have no other outlets... now 480 is adding another receptacle off that circuit for an iron..
Old 02-06-2012, 08:25 PM   #12
Very Long Vacation
Rewards Points: 5,262
Id go by the ampacity draw of the two machines combined. My belief is that by the wording of the code its ok to share that circuit with the dryer.
Old 02-06-2012, 08:25 PM   #13
BBQ
Salty Member
BBQ's Avatar
No other outlets, as in no other outlets than laundry area receptacles.
fondini (02-07-2012)
Old 02-06-2012, 08:29 PM   #14
Awg-Dawg's Avatar
Rewards Points: 338
This is how I take it.
I think you can have more, but it has to be for the laundry.
An iron is laundry. No?
Old 02-06-2012, 08:31 PM   #15
B4T
B4T's Avatar
I got it.. but it seems like another gray area an inspector would have a problem with..
Old 02-06-2012, 08:36 PM   #16
How many outlets do you need for your washer & dryer, fer cryin' out loud?
Again.... "laundry" is not defined. So it is not defined as "to serve the washing machine & gas dryer only."
Old 02-06-2012, 08:38 PM   #17
So it goes for bath circuits. And SABCs. Do you install a single receptacle for each circuit on those?
BBQ (02-06-2012)
Old 02-06-2012, 09:05 PM   #18
Rewards Points: 2,000
deleted, don't want sybil saying I stole something. hope it helped clear up things B4T
Mr Rewire is offline   Reply With Quote
The Following User Says Thank You to Mr Rewire For This Useful Post:
B4T (02-06-2012)
Old 02-06-2012, 09:06 PM   #19
Chris1971's Avatar
Rewards Points: 222
That's compliant.
2014 NEC code
Old 02-06-2012, 09:08 PM   #20
Chris1971's Avatar
Rewards Points: 222
Originally Posted by Mr Rewire View Post
Stealing copyrighted material I see.
2014 NEC code
Laundry Ckt, be aware. Mr. Sparkle NEC Code Forum 37 10-18-2011 09:58 AM
Who needs a laundry machine? Magnettica Off Topic (Non Trade) 12 07-19-2010 10:30 PM
Laundry receptacle s.kelly Residential Electrical Forum 18 03-28-2010 01:20 PM
Laundry Areas Shubey NEC Code Forum 19 11-06-2009 01:54 AM
Panel in laundry room lagaceelectric NEC Code Forum 16 10-13-2009 09:21 PM
