Old 02-03-2010, 06:58 PM   #1
Default Liquid tight/taping wire
Hi guys
I have a couple questions that I can’t find in the code book and did not know if they are.
I have always heard that you can not tape (identifying a ground or neutral or hot) wire under a #6 and also when identifying the wire at the termination you have to tape it 6" back is any of this stuff code because I am having a hard time finding it.
The common way to mark 480 is brown orange yellow but I can’t find that either I know that is how it is done but from what I am getting in the code book you can do whatever but it just has to be marked that lets say you use black red blue for 480. Is that right.
I have heard you can not run flexible conduit for more then 6' if it is exposed. I found that it said that in the code book for Greenfield but I did not see that for seal tight. Can you run seal tight as long as you want.
Thank you
Just some stupid things that we were talking about at work.
ToddH is offline   Reply With Quote
Old 02-03-2010, 07:16 PM   #2
Master Plumber
TOOL_5150's Avatar
>> Nothing under #4 - unless it is part of a cable assembly. 3 bands encircling the conductor, is what I remember from the code.
>> The code is quiet on this matter - Other than taping the wild leg orange. Basically as B, O, Y or BK, R, BL - But what ever the color coding is on the premise, its wise to keep it the way it is.
>> You can run FMC or LFMC for as long as you want. However, some localities only allow 6'. The CODE says you cannot use it as an EGC on a 20A circuit if it is longer then 6', you need to run an EGC IN the conduit.
~Matt
Poor planning on your part does not constitute an emergency on my part.
Old 02-03-2010, 07:40 PM   #3
Thank you, I was looking to see if anyone knows the code #
Old 02-03-2010, 07:51 PM   #4
PGW Professional
Magnettica's Avatar
200.6 (A) & (B) for the 6 AWG question.
Old 02-03-2010, 07:53 PM   #5
Fried Bologna um um good!
jwjrw's Avatar
Originally Posted by ToddH View Post
Hi guys
Thank you
Ok art 210.5 talks about identifying different phases and no there is no NEC requirement about colors other than neutrals and grounds.
Im working on the reidentifying smaller than #4 I know its true looking for art. Dont think it says 6" back, 3 stripes will do you.
See art 338 on fmc it can be run as long as you want if conditions are met.
Old 02-03-2010, 07:55 PM   #6
jwjrw's Avatar
What year you looking under?
Old 02-04-2010, 06:55 PM   #7
Tapeman's Avatar
You are required to tape or mark (I normally use a black felt tip marker) the hot or common on three way switches when using a three wire (e.g. 14-3 or 12-3 NM) and the white is the hot.
I doubt that the OP was refering to this.
Tapeman is offline   Reply With Quote
Old 02-05-2010, 04:28 AM   #8
Article 348 is about FMC.
Article 338 is about SE and USE.
eric7379 is offline   Reply With Quote
Old 02-05-2010, 07:38 AM   #9
jwjrw's Avatar
Cant a guy fat finger a key without getting slammed?
Old 02-05-2010, 07:46 AM   #10
jwjrw's Avatar
250.119(a) talks about conductors larger than #6 being identified with at least 3 stripes for equipment grounding. Not sure if that was what I was looking for.
And 200.6 is for grounded conductors like someone above said.
Old 02-05-2010, 08:08 AM   #11
210.5 C talks about the colors. In Wisconsin, Comm. 16 adds a Fine Print Note that recommends BOY for 480/277 and BkRBlu for 120/208., but it's just a recommendation. We have some GE plants in the area, and they spec just the opposite. Kinda freaky your first time in a panel.
350.30 A Exception 2 talks about the 3, 4, or 5 foot lengths for flexibility of sealtite.
ralpha494 is offline   Reply With Quote
Taping wirenuts 3phase General Electrical Discussion 20 10-11-2010 06:22 PM
phase taping conductors cal General Electrical Discussion 42 01-15-2010 02:53 PM
Liquid Oxygen InPhase277 Off Topic 7 04-26-2009 04:21 PM
liquid tight question new_electric NEC Code Forum 4 03-19-2008 08:51 AM
Tight space JohnJ0906 Services and Service Equipment 16 04-16-2007 05:28 AM
