Old 08-12-2008, 05:12 PM   #1
Default load calc.
Using standard calculation for a residential single family dwelling would you consider a frig as a fixed appliance. on a calc I was doing i had 4 fixed appliances other than the frig. For example, 2 dishwashers,1 garbage disposal,and one instant hot. I know you are allowed a 75%demand factor on 4 or more appliances so would you include the frig or omit it.
rknrll813 is offline   Reply With Quote
Old 08-14-2008, 07:27 PM   #2
JohnJ0906's Avatar
Only if it was actually "fixed in place", i.e. a built-in, fastened in place fridge. I don't see that a standard fridge is fixed.
John from Baltimore
"One day at a Time"
Load Bank Generator Testing vs. Using Building Load to test generators. MR MAB Other Codes and Standards 15 03-16-2009 06:37 PM
cable calc software cheekivimto06 General Electrical Discussion 0 11-11-2008 12:46 AM
dwelling calc. rknrll813 General Electrical Discussion 0 10-07-2008 08:50 PM
Load Calc. for Old Single Family Dwellings Reseman Services and Service Equipment 5 05-31-2008 09:21 AM
heat calc. rll77 Services and Service Equipment 16 03-29-2008 05:58 PM
