Old 10-21-2008, 12:07 AM   #1
Hefty's Avatar
Default Looking for switch
I am looking for a switch that I saw on some large fans in a manufacturing facility. They are toggle switches that allow the attachment of a pull chain. Pull once-on, pull again-off. They allow for very easy pulling with the chain perpendicular to the switch body. I have tried standard pull chain switches but have found that they do not work well at this angle. Due to space limitations the switch must be mounted this way. If someone can tell me where I can find these switches or if you have used a standard type pull switch with a very light action at 90 deg. I would appreciate the info.
Hefty is offline   Reply With Quote
Old 10-21-2008, 10:51 PM   #2
"A" inside wireman
randomkiller's Avatar
Try McMaster-Carr.
"One Nation Under God"
Old 10-21-2008, 11:15 PM   #3
I think what you are looking for is a Levolier switch by McGill.
Replace a 2 way switch by time lag switch emleray General Electrical Discussion 4 09-12-2008 04:18 PM
pressure switch kawaikfx400 General Electrical Discussion 6 08-02-2008 04:53 PM
Time switch sckeeth General Electrical Discussion 6 12-18-2007 10:02 AM
Very old toggle switch bigredc222 Vintage Electrical 9 10-28-2007 03:42 AM
Switch Box pinoa General Electrical Discussion 3 08-30-2007 04:59 PM
Electrician Talk © 2006 - 2010 The Building Network LLC
