Main lug only panel - Electrician Talk - Professional Electrical Contractors Forum
Old 01-25-2012, 02:40 PM   #1
Default Main lug only panel
Hi all,
In a moment of stupidity I grabbed a 125A panel and had it mounted, piped in, and was in the middle of pulling wire before I realized it was main lug only. It's being fed exclusively by a 17kW generator. Since it will only be providing power when the generator is running, do I really need to have a main breaker in there? I'm sure there is a conversion kit I can pick up but I started to wonder if it was really necessary. The generator is manually turned on and off daily.
Interested to hear your opinions! Thanks in advance!
maryland is offline   Reply With Quote
Old 01-25-2012, 02:42 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Will there be only six breakers or less in it?
Old 01-25-2012, 02:48 PM   #3
No, we're looking at 10-12 once all is said and done.
Old 01-25-2012, 02:50 PM   #4
Rewards Points: 2,050
Default not
If there isn't 6 or less. Make it 6 and just put a sub panel off it for other stuff
Old 01-25-2012, 02:51 PM   #5
What brand / model of panel? Perhaps there's a main breaker kit you can put in.
Or, possibly buy a main breaker panel and swapping the guts.
Old 01-25-2012, 02:57 PM   #6
Rewards Points: 1,106
Put a disco in front of it or check into the ability to add the main like 480 said.
I know. The disco will cost more than a main breaker panel. I feel your pain.
Old 01-25-2012, 03:18 PM   #7
Rewards Points: 464
Not all panels can be converted into main breaker but if the panel is service rated then you could add a dp breaker with a lock down-- bolts the breaker in place.
John Valdes (01-26-2012)
Old 01-25-2012, 05:25 PM   #8
Going_Commando's Avatar
Rewards Points: 318
You could always buy a main breaker panel, take the MLO guts out of the first panel, drop it in the tub of the 2nd panel, and package it in the MLO box and return it. Usually the tubs are the same size no matter whether it is MLO or MB.
Old 01-25-2012, 05:28 PM   #9
Salvatoreg02's Avatar
Rewards Points: 1,002
Just buy the retaining hold down kit for a double breaker like Dennis said. Less then $30 bucks.
Sal
P.E.S
Salvatoreg02 is offline   Reply With Quote
Old 01-25-2012, 07:18 PM   #10
Rewards Points: 250
If your generator has a breaker in it and you are within line of site you don't need a m.b. Correct me if I'm wrong.
buddhakii is offline   Reply With Quote
Old 01-25-2012, 09:12 PM   #11
The panel is considered a separate structure. So a main is required And you need a 4 wire feeder with ground rods. The panel needs to have the neutral issolated with the GEC connecting to the growing bar.
PWC Chief is offline   Reply With Quote
Old 01-25-2012, 09:45 PM   #12
Thanks for all the help, guys.
The panel is Square D QO 125A. It is not within sight, unfortunately, of the generator, but I hear you guys about the conversion kit and will check and see if I can find one.
I like the idea of swapping out the guts... I can always use an MLO panel later for something else, I suppose. I hadn't thought of that. I was trying to avoid buying a disconnect, mostly just for financial and aesthetic reasons.
Where does the 6 circuits come from? The only thing I could find in the NEC pertaining to the situation was 445.18, and I was hoping that would be enough to get away with no disconnect or main breaker...
...but I'm planning on picking up the conversion kit or swapping out the guts. Thanks a lot, guys.
Old 01-25-2012, 09:48 PM   #13
kbsparky's Avatar
Rewards Points: 1,000
Most QO panels of that size are field convertible.
What is the whole catalog number??
-KB
Old 01-25-2012, 10:52 PM   #14
crispy critter
green light's Avatar
Rewards Points: 1,024
Default hold down kit
Get a hold down kit
I'm old enough to know better, but too young to care.
green light is offline   Reply With Quote
Old 01-26-2012, 01:04 AM   #15
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Originally Posted by green light View Post
Get a hold down kit
That's what I would too. 2-pole 80 amp circuit breaker with the tie down kit.
408.36 (D) Back-Fed Devices. Plug-in-type overcurrent protection
devices or plug-in type main lug assemblies that are
backfed and used to terminate field-installed ungrounded
supply conductors shall be secured in place by an additional
fastener that requires other than a pull to release the
device from the mounting means on the panel.
Replies based on NEC 2014
The Following 2 Users Say Thank You to Magnettica For This Useful Post:
green light (01-26-2012), HARRY304E (01-26-2012)
Old 01-26-2012, 02:15 AM   #16
Rewards Points: 1,464
I wouldn't want to see the rest of the installation if you didn't see the main panel was wrong.
The Following User Says Thank You to bobelectric For This Useful Post:
Old 01-26-2012, 07:09 AM   #17
Rewards Points: 1,222
The rule would be in 225.33(B), that is assuming that the generator is not in the building that has the panel. If the generator is in the building and has a OCPD at the generator a MLO panel would be fine.
The Following 2 Users Say Thank You to don_resqcapt19 For This Useful Post:
HARRY304E (01-26-2012), Magnettica (01-26-2012)
Sub-Panel next to main panel ground. rnichols General Electrical Discussion 16 10-04-2011 05:49 AM
The panel needs a main...... jwjrw General Electrical Discussion 16 09-20-2011 09:59 PM
Main breaker panel cheaper than main lug Shockdoc General Electrical Discussion 5 07-19-2011 08:51 PM
PVC Main Panel ? Cletis General Electrical Discussion 24 06-20-2011 03:07 PM
Sub-panel need Main breaker Xknob&Tube Residential Electrical Forum 11 07-08-2010 11:40 PM
