mc to emt - Electrician Talk - Professional Electrical Contractors Forum
Old 08-17-2011, 02:58 PM   #1
Default mc to emt
being new to the site, and a little pc challanged, I hope I am going about this correctly...I do mostly Maintenance work at an old hydro plant. I don't get much field work so I am a little rusty when it comes to the code. I was wondering if there is a way to transition from mc cable to emt when comming from floor joists down a block wall for outlets and switches with no j box ? thanks
babber is offline   Reply With Quote
Old 08-17-2011, 03:10 PM   #2
Rewards Points: 958
what size mc to what size conduit?
if you are using MC that fits a 3/8" mc connector to 1/2 " emt there is connection just for , anything else say for 3/4" emt you would need a 3/4" rigid coupling with an RE to accept the MC connector
'I believe that banking institutions are more dangerous to our liberties than standing armies"
Thomas Jefferson
electricalwiz is offline   Reply With Quote
Old 08-17-2011, 03:11 PM   #3
Tabihu Juhar
76nemo's Avatar
Rewards Points: 2,000
Arrow
http://www.youtube.com/watch?v=HhwEwbgZFA4
The Following User Says Thank You to 76nemo For This Useful Post:
babber (08-17-2011)
Old 08-17-2011, 03:11 PM   #4
JDJ
Rewards Points: 547
connector ,rigid coupling,threaded mc connector, anti short, skin the mc long enough to go through conduit to first j-box or to point of termination.
JDJ is offline   Reply With Quote
The Following User Says Thank You to JDJ For This Useful Post:
babber (08-17-2011)
Old 08-17-2011, 03:13 PM   #5
A rigid coupling ,emt connector
Mr Rewire is offline   Reply With Quote
The Following User Says Thank You to Mr Rewire For This Useful Post:
babber (08-17-2011)
Old 08-17-2011, 03:28 PM   #6
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by Mr Rewire View Post
A rigid coupling ..........
Originally Posted by JDJ View Post
......,rigid coupling,.......
Originally Posted by electricalwiz View Post
.....rigid coupling......
110.3(B) violation.
Old 08-17-2011, 04:49 PM   #7
Electric Al
oldtimer's Avatar
Rewards Points: 2,306
Originally Posted by mr rewire View Post
a rigid coupling ,emt connector
Wrong!!!!
Steven Wright
The Following User Says Thank You to oldtimer For This Useful Post:
Island Electric (08-17-2011)
Old 08-17-2011, 04:51 PM   #8
JmanAllen's Avatar
That's against code. They sell an adt. At most supply houses we call them "from to" I don't no if that's what there really called for sure but the supply house always knows what we want
JmanAllen is offline   Reply With Quote
The Following User Says Thank You to JmanAllen For This Useful Post:
Old 08-17-2011, 04:54 PM   #9
JmanAllen's Avatar
110.3(B) violation.
Originally Posted by oldtimer
Wrong!!!!
Good to see that there are other people on here that no better then to do that
Old 08-17-2011, 06:32 PM   #10
Sasquatch
Rewards Points: 25
Ok so which item is not being used as it's labeled use? Maybe the rigid, coupling so replace with a pulling condulet. I have seen the above mentioned way of transitioning many times in inspected jobs and never seen it fail.
OHMsFolly is offline   Reply With Quote
The Following User Says Thank You to OHMsFolly For This Useful Post:
babber (08-17-2011)
Old 08-17-2011, 06:45 PM   #11
110.3(B) violation.
I don't see it
Listed or labeled equipment shall be installed and used in accordance with any instuctions included in the listing or labeling.
were does the listing exsist for rigid couplings that says you cant do this?
110.3 (B) does not require listing.
Old 08-17-2011, 07:07 PM   #12
Tabihu Juhar
76nemo's Avatar
Thumbs down
I'm sorry, I'm not one to be negative, but pulling out that card is a total crock. I am sorry. I'm not a smart man by any means, but I'd be the first to say BS right there.
That's worse than calling exposed SEU hazardous.
I understand listings, but you tell me you would never do it, and I'll call you ignorant or a liar.
Who's first?
Old 08-17-2011, 07:25 PM   #13
Can't Remember
Rewards Points: 1,322
Looking at a few products at Arlington and Bridgeport, most of what we traditionally use is either for NM or FMC. There was one for MC, but duplex.
babber (08-18-2011)
Old 08-17-2011, 07:33 PM   #14
Can't Remember
I think the rigid to emt coupler problem is rigid is used with tapered threads vs straight threads for emt/mc connectors.
babber (08-18-2011)
Old 08-17-2011, 07:38 PM   #15
I've never been called using a rigid coupling.
Anti-shorts not required unless required locally.
The Following User Says Thank You to knowshorts For This Useful Post:
babber (08-18-2011)
Old 08-17-2011, 07:45 PM   #16
Tabihu Juhar
76nemo's Avatar
Arrow
I'd honestly like to hear of anyone hit for that. Again, I understand the listings but give me a break on that one.........
babber (08-18-2011)
Old 08-17-2011, 07:48 PM   #17
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
What am I missing? A "from 2" connector would work here wouldn't hit? The MC jacket isn't the EGC so why not?
Replies based on NEC 2014
Old 08-17-2011, 07:51 PM   #18
Rewards Points: 530
I agree with most here, I don't see that as a violation using the rigid coupling but what do I know
Old 08-17-2011, 08:03 PM   #19
Rewards Points: 1,062
Then I guess you've never ran greenfield to EMT before. Thinking comes from not knowing.
ElectricJoeNJ is offline   Reply With Quote
Old 08-17-2011, 08:09 PM   #20
Can't Remember
I have done both flex and mc to emt and the question wasn't whether it will physically bolt together and work, but whether it was legal or not. If not, then what was the proper coupler to use. I don't think its a major transgression, but I try to use the right stuff if I can.
