Old 07-21-2008, 02:09 PM   #1
Default Most Basic Generator Load Calculation Formula
I know that to be precise you must calculate the load of all equipment being fed by a generator, with special attention given to motor LRA (start amps).
Though this wouldn't be realistic (100% pure resistive load), do I have the most basic load calculation formula for a generator correct?
Single Phase: Amps X Volts = Watts X1000 = Kilowatts
Three phase: Amps X Volts X 1.73 (Power Factor) = Watts X1000 = Kilowatts
Now, with generators being rated with kvA instead of kilowatts, it would be....
Single phase: Volts X Amps / 1000 = kvA
3 ph: Volts X Amps X 1.73 / 1000 = kvA
Are these formulas correct?
Randy L is offline   Reply With Quote
Old 07-21-2008, 08:07 PM   #2
I * E = W/1000 = kw.
DIVIDE not MULTIPLY
jagdep (03-18-2012)
Old 07-22-2008, 01:53 PM   #3
^^ oops...that's right! Brain fart.
Load Bank Generator Testing vs. Using Building Load to test generators. MR MAB Other Codes and Standards 15 03-16-2009 06:37 PM
Formula question waco General Electrical Discussion 89 03-02-2009 10:46 AM
formula stillirnin General Electrical Discussion 1 10-28-2008 06:45 PM
basic quots/invoiceing software advice journyman Business, Marketing, and Sales 2 08-12-2008 06:51 PM
UF-B load calculation crash63 General Electrical Discussion 1 04-23-2008 08:18 PM
