Originally Posted by hayan453
Separate homeruns so that the sensors are on different phasing im assuming?
I don't want to speak for Bryan but that is not my take on it. I believe he is suggesting a 3 wire cable back to the relay not the panels. The MS would kick in the relay and control the lights.
Never worked with relays either could you elaborate please?
There are different types of relay but the basic relay has line and load contact points that are activated by the MS (in this case). If 120v is brought to the coil on the relay the contacts will close- lights go on. When the MS times out then the voltage is gone and the contacts open-- lights go off.
