neutral at switch box - Electrician Talk - Professional Electrical Contractors Forum
Old 11-17-2011, 08:40 AM   #1
Rewards Points: 25
Default neutral at switch box
This was brought up at the code update class I recently attended.
The instructor said that as long as there is access above the switch (attic/drop celing etc..), or if the switch was supplied with conduit/tubing, a neutral conductor would not be required.
I read some posts on here that infer that a neutral is required at all switch locations.
Whats your opinion?
Billy Bob is offline   Reply With Quote
Old 11-17-2011, 08:42 AM   #2
Chris1971's Avatar
Rewards Points: 222
Whats your opinion?
Are you cletis?
2014 NEC code
Chris1971 is online now   Reply With Quote
Old 11-17-2011, 08:58 AM   #3
Rewards Points: 25
Are you cletis?
Is that what you think?
Old 11-17-2011, 08:59 AM   #4
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
The inspector is right.
Old 11-17-2011, 09:08 AM   #5
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Whats your opinion?
AS long as the access is on the same floor.
404.2 Switch Connections.404.2(C) Switches Controlling Lighting Loads.
Where switches control lighting loads supplied by a grounded general purpose
branch circuit, the grounded circuit conductor for the controlled
lighting circuit shall be provided at the switch location.
Exception: The grounded circuit conductor shall be permitted
to be omitted from the switch enclosure where either
of the following conditions in (1) or (2) apply:
(1) Conductors for switches controlling lighting loads enter
the box through a raceway. The raceway shall have
suffıcient cross-sectional area to accommodate the extension
of the grounded circuit conductor of the lighting
circuit to the switch location whether or not the
conductors in the raceway are required to be increased
in size to comply with 310.15(B)(3)(a).
(2) Cable assemblies for switches controlling lighting
loads enter the box through a framing cavity that is
open at the top or bottom on the same floor level, or
through a wall, floor, or ceiling that is unfinished on
one side
Old 11-17-2011, 09:09 AM   #6
Rewards Points: 2,050
Default 4
You even have to run them to 4 ways "Just in Case".
Nice name btw
Old 11-17-2011, 09:09 AM   #7
Rewards Points: 25
Thats kinda what I was thinking.
2011 NEC article 404.2 (c) Ex(2), kinda leaves it open for interpretation.
We do mostly commercial, so, I usually pull a neutral anyway because so many owners want to add a wall mounted occupancy sensor.
Thanks Harry, you beat me by one second.
Old 11-17-2011, 09:11 AM   #8
Default yeah
You never know then someone is going to want to add a 4 way occupancy sensor...
Old 11-17-2011, 09:22 AM   #9
Rewards Points: 25
Harry,
The phrase, "same floor level" is kinda throwing me off a little.
Is an attic the same floor level?
Old 11-17-2011, 11:48 AM   #10
Rewards Points: 1,210
Harry,
If you would have to go above the floor above or the floor below the swtich location to fish the new wire, the exception does not apply. The attic is the floor above.
raider1 (11-17-2011)
Old 11-17-2011, 11:50 AM   #11
Rewards Points: 278
Harry,
IMO, the attic is not acceptable because it is not the same floor level however if one side of the wall is unfinished and there is access from the attic then that would be compliant.
The whole problem with that exception is the code makes no allowance that a neutral for that circuit is available in the ceiling or the attic. I made a proposal to nix the exception.
Old 11-17-2011, 01:03 PM   #12
B W E's Avatar
Rewards Points: 1,000
Isnt the ceiling unfinished on the attic side? so, couldnt you drop a switch loop in a 14/2 down from the attic, through the unfinished (attic) side of a ceiling, into the wall? It's a stupid code, and difficult to "word-out" any loopholes or exceptions.
More 404.2C (neutral req'd in switch boxes) questions gismo NEC Code Forum 1 10-17-2011 01:08 PM
Neutral in wall switch boxes czars NEC Code Forum 109 09-13-2011 01:02 PM
3-Way Switch. Take Neutral from another Outlet? swimmer NEC Code Forum 13 08-24-2011 07:50 PM
Broken Neutral, Connect Neutral to Box? JayWater General Electrical Discussion 45 08-19-2011 09:02 PM
one leg 130v to neutral the other 117v to neutral??? brooklyn General Electrical Discussion 3 01-07-2010 08:59 PM
