Normally Open Normally Closed ? - Electrician Talk - Professional Electrical Contractors Forum
Old 06-26-2010, 10:27 PM   #1
Rewards Points: 1,304
Default Normally Open Normally Closed ?
How do you define Normally Open and Normally Closed? No brainier not really.
Had this debate with a coworker. This is the scenario you have a sensor switch in a vessel and this has a sensor that is driven be a electronics package. How the sensor detects level flow is not important what is important is the state of the contacts that operate when a condition is detected.
Traditionally process control switches are hooked up to open a circuit when a condition is detected that way if a open in the wiring occurs the process is shutdown or a alarm is indicated (fail safe) .
The question is, is the normal state like it sits on the bench with no power applied or is it how it sits with power applied with a dry sensor or is there is no real standard and one should refer to the manufacturers instruction sheet on a switch by switch basis
Old 06-26-2010, 10:34 PM   #2
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Unless noted, it's referring to it's shelf state.
Old 06-26-2010, 10:37 PM   #3
Rewards Points: 150
unenergized-not pushed-just sitting there is its designation
if its normally closed its closed
Intel you operate it then it opens.
Wingnut is offline   Reply With Quote
Old 06-26-2010, 10:45 PM   #4
evil bastard
Rewards Points: 746
until not intel
Old 06-26-2010, 10:51 PM   #5
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Altronix relay terminals are N/O - N/C sitting on the shelf, before applying power.
Old 06-26-2010, 10:53 PM   #6
Rewards Points: 150
Plain, simple and correct
Ray Cyr is offline   Reply With Quote
Old 06-26-2010, 11:11 PM   #7
mattsilkwood's Avatar
Rewards Points: 2,006
That's right.
A man that will not read has no advantage over a man that can not read.-Mark Twain
Old 06-26-2010, 11:38 PM   #8
Generator Sales
yucan2's Avatar
And all in favor said aye!!! Motion Passed.
yucan2 is offline   Reply With Quote
Old 06-27-2010, 12:04 AM   #9
Rewards Points: 5,198
NO, or NC is the static state with no external influence on it.
Old 06-27-2010, 09:38 AM   #10
Bandwidth Conservator
Fredman's Avatar
Rewards Points: 504
Unless you were an alarm/security guy in another life.
The typical type of door/window contact used is a normally closed magnetic contact. The magnet holds the reed relay closed (i.e door shut) in what they consider its normal state.
Fredman is offline   Reply With Quote
Old 06-27-2010, 09:46 AM   #11
Rewards Points: 2,050
I will go with that as well.
That said sometimes when installed in equipment it's normal state has been reversed.
Old 06-27-2010, 09:57 AM   #12
Yes agreed. But consider a switch with a mechanical actuator or similar situation. The contact block may be NO but the unactivated status might be closed. An old convention for this is NO, HC (normally open, held closed. Or NC HO, NO,HO, etc ).
You might have a vessel with a float switch. The contact block is one thing but if you have set up how it works mechanically then it is up to you to document it's operation properly.
sirius0 is offline   Reply With Quote
Old 06-27-2010, 10:01 AM   #13
Mike in Canada's Avatar
When push comes to shove, if it's a switch that I haven't worked with before then I check it with my meter when I install it.
Mike
Mike in Canada is offline   Reply With Quote
Old 06-27-2010, 10:03 AM   #14
drsparky's Avatar
Rewards Points: 220
I worked with someone who's mouth is NO instead of NC. Had it put in ears plugs for the day.
Old 06-27-2010, 10:08 AM   #15
evil bastard
Rewards Points: 746
In that instance, the prints should show NC, mechanically held open
or vice versa
Old 06-27-2010, 10:54 AM   #16
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 250
In that instance, the prints should show NC, mechanically held open or vice versa
God do I wish that was always the case. I've come across schematics where they had NC (normally de-energized) and NC (normally energized) on the same bloody print, but they didn't tell you which was which. Multiply that by a couple dozen relays, and it was almost as bad as not having any prints at all.
-John
Old 06-27-2010, 11:40 AM   #17
or vice versa
Well derr.
But they often do not.
Old 06-28-2010, 11:55 AM   #18
That would be it's "supervised " state. Its static state is as McClary said..."shelf" state.
Old 06-28-2010, 09:06 PM   #19
Rewards Points: 2,012
Now that we've solved contacts, lets move on to 3-way valves.
miller_elex is offline   Reply With Quote
Old 06-29-2010, 06:32 AM   #20
evil bastard
Rewards Points: 746
A single solenoid valve returns to it's detent position with the removal of control power.
A double solenoid valve needs power to shift either way
Open vs. Closed Delta DkEnrgyFrk General Electrical Discussion 2 02-28-2010 05:15 PM
closed-loop and pre-closed-loop electricnut NEC Code Forum 0 10-14-2009 09:15 PM
delete post in closed thread te12co2w Site Help and Suggestions 1 02-05-2009 04:22 PM
Closed Post brian john General Electrical Discussion 4 05-31-2007 01:20 PM
