Oregon supervisor's test - Electrician Talk - Professional Electrical Contractors Forum
Old 09-25-2010, 10:03 PM   #1
ServiceOrders.net
wrhammer's Avatar
Default Oregon supervisor's test
Anybody have any info on the Oregon Supervisor's test? What to focus on etc...
I took it once about 5 years ago and it was a BEAR!
Would appreciate a heads up on what to study
Thanks!
ServiceOrders.net Online work order management and communication tool
wrhammer is offline   Reply With Quote
Old 09-25-2010, 10:10 PM   #2
Rewards Points: 1,278
Supervisor's test WHAT
Old 09-27-2010, 12:45 AM   #3
PDX-SPARKY's Avatar
My advice would be prepared for a ton of calculations. From what I've heard there are a few of those....
Good luck.
PDX-SPARKY is offline   Reply With Quote
Old 09-27-2010, 01:53 AM   #4
Rewards Points: 2,012
Hardest test in the nation.
miller_elex is offline   Reply With Quote
Old 09-27-2010, 10:30 AM   #5
Rewards Points: 79
I took the test a few months ago and you will definately need to study commercial calcs in great detail, and multifamily also. There is quite a bit of specialty code mixed in with other code questions.
Ive taken several other tests in other states this was the hardest of all.
aksparky is offline   Reply With Quote
Old 09-27-2010, 02:03 PM   #6
Why is it called this?
Old 09-27-2010, 06:48 PM   #7
Jsmit319's Avatar
I can tell you it's the hardest exam I've ever taken. The test is geared so that only 20% will pass the first time. You spend 4 hrs on strictly code related questions that are the most difficult and arcane code interpretation questions you can imagine( mine had 75 questions). Alot of them you have to answer off the top of your head, because you simply don't have time to look them up if you don't know exactly where to find them. Then you get a break (mostly so you can pick up the pieces of your brain after it exploded). After the break you get the calculation part of the test. It could be a number of things, but the common theme is everything is related so that if you screw one up, the rest are all out of whack. Mine was modeled after Bill Gates' house and compound (34,000 sf home w/ numerous out-buildings, pools, spa's, etc., 3 phase 460 vac service) and you have 3 hours to finish. Amid the service calcs, you have pipe fill, sizing, motors, conductor sizing etc.) I barely finished on time and barely passed the first time with an even 75%. The best things to study are your calcs. You have to know them inside and out because you don't have time to reference them. If you have to look, your dishes are done. The other main issue is to know the code. Sounds silly, but you have to know what the code says, not what you think it says. But don't let me scare youI understand these days it's a bit easier.
You want to do what?
Jsmit319 is offline   Reply With Quote
Old 09-27-2010, 08:51 PM   #8
No engineer required, thats why.
Old 09-27-2010, 09:06 PM   #9
Are there separate masters test?
Old 09-27-2010, 11:56 PM   #10
PDX-SPARKY's Avatar
In Oregon it is 4 year apprenticeship ( Non-Union) 5 year if you go Union for general journeymans license. After 4 years of having a Journeymans License you can go for the Supervisors License, and after then you can take the Inspectors exam.
seeings how I am in my second year of apprenticeship, I have a long road ahead...
Old 09-28-2010, 12:17 AM   #11
erics37's Avatar
Rewards Points: 638
The Oregon Supervisor's license is, I believe, roughly equivalent to a Masters license in most other states. I don't know why the name is different.
I do understand that the test is brutal though.
Old 09-28-2010, 12:19 AM   #12
Brian, I think you should take the exam next time you're over here.
Old 09-28-2010, 07:09 AM   #13
Have not taken a test in 15 years, I really have to BRUSH UP.
And the next time I am in Oregon I will be testing the slopes on Mt Bachelor, Bend OR.
Old 09-29-2010, 02:29 AM   #14
erics37's Avatar
Rewards Points: 638
KILLER mountain, dude. Best in the state, one of the best in the region. If you have good weather, take the Summit lift. Goes all the way to the top.
Last time I was there I did a faceplant into a rock and haven't wanted to go back since. But the urge is building nonetheless.
Hello from Oregon Jsmit319 Introductions 2 09-23-2010 05:39 PM
new guy from Oregon jrg Introductions 14 10-21-2009 08:17 PM
Ola! New guy here from portland oregon joshsparky Introductions 6 09-29-2009 03:23 PM
Hi from Oregon and some questions baja Introductions 7 07-12-2009 12:11 AM
Greetings from Oregon erics37 Introductions 4 05-11-2009 09:29 PM
