Old 07-30-2008, 08:20 PM   #1
Default Outdoor E-stop
Installing an outdoor E-stop tommorrow.
The enclosure I got is rated IP65. Looking at the IP ratings, not really sure that it's meant for outdoor use. Is it?
Even if it is, it looks so flimsy, I'm going to Grainger and getting a NEMA 4X rated one.
heel600 is offline   Reply With Quote
Old 07-30-2008, 09:29 PM   #2
Former sparky
Sounds like the way to go with the NEMA4.
Old 03-26-2009, 06:13 AM   #3
What sort of contacts are you using example, NC early break
Gareth_Jeanes is offline   Reply With Quote
Old 03-26-2009, 07:03 AM   #4
Just depends...http://www.aquatext.com/tables/ip_ratings.htm
Old 03-26-2009, 01:36 PM   #5
Taking the first digit, which is for protection against solid objects, the
range is as follows:
0 - No protection against ingress from solid objects
1 - Protects against any object over 50mm
2 - Protects against any object over 12.5mm
3 - Protects against any object over 2.5mm
4 - Protects against any object over 1mm
5 - Protected from most dust ingress, enough to allow normal operation
6 - Complete protection from dust ingress
The second digit concerns protection from liquids:
0 - No protection against ingress from liquids
1 - Protected against vertically falling water drops
2 - Protected against vertically falling water drops when the enclosure is
tilted up to 15 degrees
3 - Protected against spraying water
4 - Protected against splashing water
5 - Protected against water jets
6 - Protected against powerful water jets/heavy seas
7 - Protected against temporary immersion in water
8 - Protected against continuous immersion in water
Old 03-26-2009, 11:08 PM   #6
redbeard43's Avatar
nema 12s are nice, moister, dust..almost everything.
You have the ring, and I see that your schwarz is as big as mine.May the schwartz be with you!
redbeard43 is offline   Reply With Quote
Old 03-26-2009, 11:28 PM   #7
I use the AB Bulletin 800 pushbuttons and the accompanying AB oiltight pushbutton box at automated fuel dispensers. I think that's about the only time I've ever had to put an e-stop outdoors. No, I take that back. There was this electric towing track thingy at a steel company that moved pallets of steel from building to building. I forget what that gizmo was called. Had a special name.
This is the enclosure I normally use, and it's NEMA 4 and 13 rated:
AFCI's won't stop this fire ! MDShunk General Electrical Discussion 10 02-06-2012 07:48 AM
Small 12-24 for outdoor JamesINla Services and Service Equipment 3 11-18-2008 12:10 AM
Pipe in top of an outdoor panel alselec General Electrical Discussion 9 10-26-2008 01:45 PM
Stop unpaying customers calimurray Business, Marketing, and Sales 10 07-16-2008 10:33 PM
Pool E-stop heel600 NEC Code Forum 17 06-05-2008 09:05 PM
