Closed Thread
Old 04-20-2008, 09:39 PM   #1
Default outlet
Do you think that it is dangerous to add outlets, not knowing how much of a load is already on that circuit?
katessa is offline
Old 04-20-2008, 09:42 PM   #2
"A" inside wireman
randomkiller's Avatar
Are you serious?
"One Nation Under God"
randomkiller is offline
Old 04-20-2008, 09:56 PM   #3
Only if that load happens to be energized at the time!
Joefixit2 is offline
Old 04-20-2008, 09:56 PM   #4
"Think and you will know"
dSilanskas's Avatar
Send a message via AIM to dSilanskas Send a message via Yahoo to dSilanskas
Dangerous no not dangerous
dSilanskas is offline
Old 04-20-2008, 11:00 PM   #5
It isn't dangerous, but if you know the loads already there, then you need to consider the loads you mean to add. Just adding more outlets (meaning receptacles, I guess) doesn't do anything except reduce the need for extension cords.
waco is offline
Old 04-20-2008, 11:23 PM   #6
Irish Sparky's Avatar
how many outlets are on your circuit now? What size is the circuit. If you have a 20 amp circuit and you have less than 14 outlets on it, then add away.
Figure that each outlet is rated at 1.1 amp and you are supposed to stay the 20% under.
Irish Sparky is offline
Old 04-20-2008, 11:53 PM   #7
gilbequick's Avatar
It doesn't matter how many receptacles are already on the circuit, it only matters about what is the intended purpose for which the new receptacle is for and how much normal load is already on the circuit.
20% is only for single loads.
gilbequick is offline
Old 04-21-2008, 02:57 PM   #8
You must not be an electrician...
DCsparks is offline
Old 04-21-2008, 05:14 PM   #9
gilbequick's Avatar
Who are you referring to?
Old 04-21-2008, 05:37 PM   #10
Super_33's Avatar
Super_33 is offline
Old 04-21-2008, 07:04 PM   #11
Cool oUTLETS
iT IS ONLY DANGEROUS IF YOU PLAN TO USE THEM. Dont forget to install tape on the lower half of the outlet so the juice doesn't fall out.
You keep doin' what you're doin, you will keep gettin' what you got.
Idaho Abe is offline
Old 04-21-2008, 07:25 PM   #12
Happy as a Goat herd.
Ecopat's Avatar
Shocking.
Ecopat is offline
Old 04-21-2008, 07:26 PM   #13
Ecopat's Avatar
Do NOT do....... Umm, no go on, do it!
Ecopat is offline
Old 04-21-2008, 08:08 PM   #14
"A" inside wireman
Doesn't it have to be foil tape?
Closed Thread
Putting In outdoor outlet.... thekoolcody General Electrical Discussion 5 10-08-2008 06:44 PM
installing outlet boxes heyhi NEC Code Forum 13 09-07-2008 04:25 PM
110v outlet in a bathroom? TimW NEC Code Forum 9 10-12-2007 06:28 PM
How to replace an Electrical Outlet daverose31 General Electrical Discussion 11 07-10-2007 12:11 PM
changing 240v outlet chiefdino General Electrical Discussion 1 02-11-2007 12:01 AM
