Panel Schedule Template - Electrician Talk - Professional Electrical Contractors Forum
Old 12-02-2009, 08:26 PM   #1
Rewards Points: 81
Default Panel Schedule Template
Looking for a 3 phase Panel schedule template that I can print off and write in the description of what the circuit is energizing and when done, type it in and print off a finished copy to place in the panel. I tried making one in excel and it looked ok but wanting to see what is out there.
Thanks
jculber is offline   Reply With Quote
Old 12-02-2009, 08:35 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Here's mine.
The Following 3 Users Say Thank You to 480sparky For This Useful Post:
Kerry Schreiber (03-08-2013), MarkyMark (09-09-2013), Semi-Ret Electrician (08-26-2012)
Old 12-02-2009, 08:57 PM   #3
TheBrushMan007's Avatar
Rewards Points: 520
I like these Ken. Where are the one's with your logo on them.
TheBrushMan007 is offline   Reply With Quote
Old 12-02-2009, 09:32 PM   #4
Florida resident
ampman's Avatar
Location: Florida , if your not here you're somewhere else
Rewards Points: 1,604
i use a lable maker with black writing on white tape
ampman is offline   Reply With Quote
Old 12-02-2009, 09:38 PM   #5
Like these?
They're custom-made for the job.
Why would you want my logo on them?
Old 12-02-2009, 09:44 PM   #6
Professional Nit Picker
manchestersparky's Avatar
Rewards Points: 1,568
www.dcengineers.com/downloads.html
Has panel schedules in PDF and Excel
The Following User Says Thank You to manchestersparky For This Useful Post:
Old 12-02-2009, 09:49 PM   #7
Florida resident
ampman's Avatar
Like these?
i don't see your SABC listed for the kitchen
Old 12-02-2009, 09:55 PM   #8
kbsparky's Avatar
Rewards Points: 1,000
From that list, I believe that there are more panels located elsewhere in that particular dwelling. The SABCs would be fed from one of those....
-KB
Old 12-02-2009, 09:56 PM   #9
That was only half of the panels in the house.
Old 12-02-2009, 10:02 PM   #10
rdr
Expatriate in Training
rdr's Avatar
On the 480/277 ones B and C phase look an awful lot like the same colour
rdr is offline   Reply With Quote
Old 12-02-2009, 10:10 PM   #11
Rewards Points: 520
Like these?
Because I want to be just like you. Nah I just remembered liking your set up but couldn't remember where you attached your logo
Old 12-02-2009, 10:12 PM   #12
Florida resident
ampman's Avatar
i knew there was a logical answer
Old 12-02-2009, 10:37 PM   #13
JayH's Avatar
And orange is supposed to be identifying a stinger leg.
Upping my post count one mistake at a time!
JayH is offline   Reply With Quote
Old 12-03-2009, 08:40 PM   #14
JohnJ0906's Avatar
In some areas (like around here), orange is commonly used for B phase on a 480/277 system.
John from Baltimore
"One day at a Time"
Old 12-03-2009, 08:43 PM   #15
I can easily see the difference between orange and yellow.
Either you're color blind, or your monitor is screwed up.
Old 12-03-2009, 09:06 PM   #16
JayH's Avatar
It's exactly the same here and many of the spec books I review still list orange as an identifying color for 480V systems.
Old 12-04-2009, 01:16 AM   #17
rdr
rdr's Avatar
Monitor's just fine, and brand new about 2 months ago.
Old 12-04-2009, 03:55 AM   #18
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,114
Time to get a refund on that monitor then. Theres nothing wrong with that template.
~Matt
I HAVE THE RIGHT TO OFFEND ANYONE I PLEASE. YOU HAVE THE RIGHT TO BE OFFENDED, YOU DO NOT HAVE THE RIGHT TO SHUT ME UP.
Old 12-04-2009, 04:47 AM   #19
e57
New here - but not new.
e57's Avatar
I use the Excel one as well - with a few modifications. It can also be used as a quick calc, imports info from other sheets and simplfies changes... Has some quirks but good....
Depends on where you are.... It's purple here - for some reason????
120/240 volt 3-phase delta circuits -
"A" phase black,
"B" (high leg) phase purple,
"C" phase red
Visual indication that you're from out of town... Doesn't get confused with red like orange sometimes can - but often gets confused for blue.
e57 is offline   Reply With Quote
Old 12-04-2009, 09:28 AM   #20
Enlightened Rat
Grimlock's Avatar
Excel often screws up the color pallet in spreadsheets built in a different version than opened in. It's Microsoft, need I say more...
(My computer post of the day.)
BTW just to warn everyone; if you open the spreadsheet it runs the macros that 480 embedded in the spreadsheet. Luckily I had macros set to off and wasn't affected. I examined the code and upon triggering it causes all of your most loyal customers to convert to Code Electric evangelist zealots....
Last edited by Grimlock; 12-04-2009 at 09:51 AM. Reason: Had to warn about the embedded macros
Grimlock is offline   Reply With Quote
The Following User Says Thank You to Grimlock For This Useful Post:
chicken steve (08-26-2012)
120 V DC Panel fdew Vintage Electrical 3 03-31-2009 10:41 PM
Wet Panel AussieApprentice Off Topic (Non Trade) 6 03-06-2009 08:15 PM
400 Amp Panel ramsfield NEC Code Forum 4 02-20-2008 06:59 PM
A UK panel chrisb271 UK Electrical Forum 18 11-21-2007 06:02 PM
Draw Schedule K&R Business, Marketing, and Sales 8 03-23-2007 01:14 PM
